Home » Modeling » OCL » Checking an OCL constraint before actually setting the value
Checking an OCL constraint before actually setting the value [message #1129273] Tue, 08 October 2013 09:17 Go to next message
is there a way to check an OCL constraint before you actually set the value?
Example: (or see the exported project as zip)
You have a class Person
- with the attribute age and
- a reference father to another person.
- Of course a father should be older than his child
in pseudo-code:
Person child = new Person(age=60)
Person father = new Person(age=50)
Constraint con = Person.getFatherIsOlderConstraint()
con.testIfWouldBeAccepted(child, father)
As far as I got with code to try checking at all:
(with help of http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.ocl.doc%2Fhelp%2FOCLInterpreterTutorial.html)
private void validateBeforeSet(Person p) throws ParserException {
		OCL ocl = OCL.newInstance();
		OCLHelper helper = ocl.createOCLHelper();
		helper.setContext(SimplemodelPackage.Literals.PERSON);
		Constraint invariant = (Constraint) helper.createInvariant("father.age < age");
		Query invEval = ocl.createQuery(invariant);
		invEval.getEvaluationEnvironment().add("father", p.getFather());
		Object result = invEval.evaluate(p);
		System.out.println(result);
But the result is always "invalid", even if I change the invariant to "father.age > age"
Eclipse:
Version: Kepler Release
Build id: 20130614-0229
OCL End User SDK 4.1.1.v20130916-1423
OCL Examples and Editors 3.3.1.v20130916-1423
Thank you for your time and help,
Tom
  • Attachment: SimpleOCL.zip
    (Size: 43.46KB, Downloaded 135 times)
[Updated on: Tue, 08 October 2013 09:54] by Moderator
Re: Checking an OCL constraint before actually setting the value [message #1129308 is a reply to message #1129273] Tue, 08 October 2013 09:59 Go to previous messageGo to next message
If you want to test a hypothetical state, you will need to create that
hypothetical state. Possibly by creating a deep clone and then applying
your mutation.
A deep clone can be very expensive and may have unexpected side effects.
If your hypothesis is limited to a couple of features you could
re-implement getXXXX to conditionally return your hypothetical value.
If you want to have many changes, it may be possible to have your model
extend HypothesizedEObject in which you re-implement some part of the
eGet() flow; this could work withe the OCL interpreter but would fail
with the OCL to JHava Code Generator that generates duirect getXXX
rather that eGet(XXX) accesses.
Much the easiest would be to do the real change live and perhaps
roll-back, possibly with the help of EMFt, but I can see that in many
scenarios this might be unacceptable.
When I finally get round to implementing @pre for accurate postcondition
execution, the difficulties of maintaining a smart system copy for @pre
and maintaining a smart system copy for a hypothesis might not be so
very different, so please raise an enhancement Bugzilla. I'm afraid that
the response may be over a year away.
Ed Willink
On 08/10/2013 14:17, Thomas Steinbach wrote:
> Hello,
> in pseudo-code:
> private void validateBeforeSet(Person p) {
> Constraint x = null;
> try {
> x = (Constraint) helper.createInvariant("father.age > age");
> } catch (ParserException e) {
> e.printStackTrace();
> Object r = ocl.check(p, x);
> System.out.println(r);
> Tom
Re: Checking an OCL constraint before actually setting the value [message #1129335 is a reply to message #1129308] Tue, 08 October 2013 10:26 Go to previous messageGo to next message
Thank you for this fast answer,
so as far as I could understand, (sorry if I don't have the right naming/terms)
internally a "Constraint" doesn't use a kind of "parameter" where I could "bind" my "TestValue"
Example in pseudo-code:
Constraint FatherIsOlder
     checks if Person father is older than Person child
     -> so it uses 2 parameters:
     parameter1: father
     parameter2: child
con1 = new FatherIsOlder()
con1.setFather(person1)
con1.setChild(person2)
-> expecting result
result = con1.validate();
I'm sorry if you feel this as repeating, it's only because I am not sure if I did understand your answer right or if I could explain my aim.
Thank you,
Tom
Re: Checking an OCL constraint before actually setting the value [message #1129374 is a reply to message #1129335] Tue, 08 October 2013 11:08 Go to previous messageGo to next message
A Constraint is an invariant on the current state. So to use a
constraint you must have the requisite current state.
You can of course write you own operations with whatever arguments you
like with OCL bodies to compute any query that you are interested in.
Ed Willink
> naming/terms)
> parameter1: father
> parameter2: child
> -> expecting result
> Thank you,
> Tom
how a newbie (mis)interpretes OCL [message #1129463 is a reply to message #1129374] Tue, 08 October 2013 12:52 Go to previous messageGo to next message
maybe I misinterprete OCL, because the above solution would mean to have the condition twice, first in the constraint where needed and second in the operation you mentioned before, in order to check if setting the value would be allowed?
What I've expected is the following (in words, see my try with code below and the corresponding markers):
- The framework creates something out of the pure OCL-String "father.age > self.age",
maybe a generated class which contains the code representing the condition "father.age > self.age" (* Code 1)
- this "element" knows _how_ to determine if the result is true or not,
but just needs the two parameters father and self
- now I can provide several objects for the parameter father and ask this "condition"-element for its result (* Code 2)
Is the code below going in this direction, or did I misunderstand it at all?
	OCL ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
	Constraint condition = (Constraint) helper.createInvariant("father.age < age");  <--- (* Code 1)
	invEval.getEvaluationEnvironment().add("father", p.getFather()); 	<--- (*Code 2), bind the Condition element to the current father-parameter
	Object b = invEval.evaluate(p);   <--- evaluate if this father-element would match the condition
--> System.out.println(b); results in "invalid"
With best regards,
Tom
[Updated on: Tue, 08 October 2013 13:04] by Moderator
Re: how a newbie (mis)interpretes OCL [message #1129477 is a reply to message #1129463] Tue, 08 October 2013 13:14 Go to previous message
I cannot really follow your message beyond the complaint about duplication.
Operations are a common approach to support reuse.
You can provide an operation that performs the hypothetical validation
with custom parameters and code the invariant to invoke the same
operation with state values.
Ed Willink
> What I expected is the following (in words, see my try with code below
> Quote:
>> - The framework creates something out of "father.age > self.age",
> at all?
> With best regards,
> Tom
Previous Topic:getStereotype() always return "invariant"
Next Topic:Using OCL for creating (temporary) object
Current Time: Fri Jul 25 23:47:59 EDT 2025
Powered by FUDForum. Page generated in 0.05040 seconds
