Home » Eclipse Projects » Remote Application Platform (RAP) » Application Freeze occasionally(Application freeze with thread deadlocks)
Application Freeze occasionally [message #1102123] Thu, 05 September 2013 07:48 Go to next message
This is related to a forum topic earlier - http://www.eclipse.org/forums/index.php/t/378202/
There has been no resolution to that and we also face the same issue now. From the thread locks below I notice a deadlock with the UIThread. There are no errors on the server logs. We use JBOSS EAP6 and RAP1.4. Anyone who faced the same issue or know of any actions that could help me identify the root cause is greatly appreciated.
Deadlock Detection:
Found one Java-level deadlock:
"Thread-5338":
waiting to lock Monitor@0x00007fcf3455e8d0 (Object@0x00000007b9840650, a java/lang/Object),
which is held by "UIThread [qOPWJHhgYk1JbITv-IKJoq+y]"
"UIThread [qOPWJHhgYk1JbITv-IKJoq+y]":
waiting to lock Monitor@0x00007fcf480016e0 (Object@0x00000007b988c380, a com/speedware/imodernize/rapclient/StatusThread),
which is held by "Thread-5338"
Found a total of 1 deadlock.
Thread 3169: (state = BLOCKED)
- sun.misc.Unsafe.park(boolean, long) @bci=0 (Compiled frame; information may be imprecise)
- java.util.concurrent.locks.LockSupport.parkNanos(java.lang.Object, long) @bci=20, line=196 (Interpreted frame)
- java.util.concurrent.SynchronousQueue$TransferStack.awaitFulfill(java.util.concurrent.SynchronousQueue$TransferStack$SNode, boolean, long) @bci=174, line=424 (Compiled frame)
- java.util.concurrent.SynchronousQueue$TransferStack.transfer(java.lang.Object, boolean, long) @bci=102, line=323 (Interpreted frame)
- java.util.concurrent.SynchronousQueue.poll(long, java.util.concurrent.TimeUnit) @bci=11, line=874 (Interpreted frame)
- java.util.concurrent.ThreadPoolExecutor.getTask() @bci=62, line=955 (Compiled frame)
- java.util.concurrent.ThreadPoolExecutor$Worker.run() @bci=23, line=917 (Compiled frame)
- java.lang.Thread.run() @bci=11, line=662 (Interpreted frame)
Thread 25461: (state = BLOCKED)
- java.lang.Object.wait(long) @bci=0 (Interpreted frame)
- com.speedware.imodernize.rapclient.StatusThread.run() @bci=24, line=41 (Interpreted frame)
Re: Application Freeze occasionally [message #1103071 is a reply to message #1102123] Fri, 06 September 2013 06:54 Go to previous messageGo to next message
I have no answer to your question, but what is this thread -
com/speedware/imodernize/rapclient/StatusThread?
Best,
Ivan
On 9/5/2013 6:06 PM, Ramesh Pank wrote:
> Hello,
> Deadlock Detection:
> "Thread-5338":
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Application Freeze occasionally [message #1129099 is a reply to message #1102123] Tue, 08 October 2013 05:33 Go to previous messageGo to next message
Hello!
I have this long-standing problem, too.
There was an RAP-Update which changed the timeout/retransmit-handling which improved the situation, but it's still there.
To me it seems that it could be a problem at HTTP-level, because the problem occurs more often when I have the RAP-application behind a reverse proxy. I'm using Apache's mod_proxy, and the situation seems to improve if I turn the "flushpackets"-parameter (see http://httpd.apache.org/docs/2.2/mod/mod_proxy.html#proxypass) on.
A thread-dump doesn't reveal anything special, at least to my eyes. It looks similar as in http://www.eclipse.org/forums/index.php/mv/msg/378202/918894/#msg_918894 .
I was always hoping it would "just go away" with some RAP-update and have never had the time to investigate deeper. On the other hand, I didn't really think that I was the only one having this problem.
Re: Application Freeze occasionally [message #1130211 is a reply to message #1129099] Wed, 09 October 2013 06:18 Go to previous messageGo to next message
Hi Seb,
do you have a simple snippet to reliably reproduce the hang? Does it
happen with all borwsers - IE8-10, Chrome, Firefox, Opera?
Best,
Ivan
On 10/8/2013 12:33 PM, Seb L wrote:
> Hello!
> looks similar as in
> Regards
Ivan Furnadjiev
Re: Application Freeze occasionally [message #1132929 is a reply to message #1130211] Fri, 11 October 2013 09:40 Go to previous message
Hi Ivan!
Unfortunately I don't. It's hard to reproduce and occurs very sporadically. Happens in Safari and FF. Of course I can't rule out that it's a problem with our code.
When I know more, I'll let you know.
[Updated on: Fri, 11 October 2013 09:45] by Moderator
Previous Topic:Label textsize
Next Topic:Using Preferences in RAP
Current Time: Fri Jul 25 22:54:49 EDT 2025
Powered by FUDForum. Page generated in 0.04220 seconds
