Home » Eclipse Projects » e(fx)clipse » ESelectionService(Can we use the ESelectionService in e(fx)clipse)
ESelectionService [message #1128157] Mon, 07 October 2013 07:57 Go to next message
Looking at e(fx)clipse's contacts demo, I notice that it uses code like the following to hand over a selected item from one widget to another:
listView.getSelectionModel().selectedItemProperty().addListener(new ChangeListener<Object>() {
   public void changed(ObservableValue<? extends Object> arg0, Object arg1, Object arg2) {
      application.getContext().set(Object.class, arg2);
Could we use the ESelectionService as well? I tried to inject it into the relevant parts of the code but no instance was available. Can this service be used with e(fx)clipse?
Uwe
Re: ESelectionService [message #1128213 is a reply to message #1128157] Mon, 07 October 2013 09:01 Go to previous messageGo to next message
Yes it should be available. IIRC the ESelectionService is provided by
the e4-framework so we should get it for free, not sure why you don't
get one. Can you enter a bug for it.
Tom
> @Override
> Uwe
Re: ESelectionService [message #1128991 is a reply to message #1128213] Tue, 08 October 2013 03:25 Go to previous messageGo to next message
Here's the bugzilla entry: Bug 418881
Re: ESelectionService [message #1129042 is a reply to message #1128991] Tue, 08 October 2013 04:23 Go to previous messageGo to next message
Looks like the creation of the ESelectionService was modified in Kepler,
in former versions it was created through a ContextFunction and now it
is done in the E4Application bootstrapping.
Fixed in master
Tom
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=418881
Re: ESelectionService [message #1129046 is a reply to message #1129042] Tue, 08 October 2013 04:28 Go to previous message
Cool, thanks!
Previous Topic:How to build Test Project
Next Topic:e4 dynamic menu contributions not work?
Current Time: Sat Jul 26 20:32:48 EDT 2025
Powered by FUDForum. Page generated in 0.03834 seconds
