Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » HbResourceImpl
HbResourceImpl [message #112732] Wed, 20 February 2008 13:30 Go to next message
I read that the HbResourceImpl replaces the HibernateResource in case
that I want to close the session each time.
I changed my code to use the HbResourceImpl, but it does not support
lazy loading.
Does any one knows how to fix this?
Sample code or new version? (i'm using 0.8.0)
Yigal
Re: HbResourceImpl [message #112787 is a reply to message #112732] Wed, 20 February 2008 14:00 Go to previous messageGo to next message
Hi Yigal,
To be honest, this resource implementation is not used very often (afaik). What happens with your
lazy loaded lists, do you get an exception or is everything eagerly loaded?
Why not use the standard HibernateResource?
gr. Martin
> lazy loading.
> Thanks
> Yigal
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: HbResourceImpl [message #112812 is a reply to message #112787] Wed, 20 February 2008 14:52 Go to previous messageGo to next message
When the lazy load for the list is activated, it calls a method called
getSessionWrapper from the HbResourceImpl. This method is not
implemented and returns a null that causes a null exception
Yigal
Martin Taal wrote:
> Hi Yigal,
> (afaik). What happens with your lazy loaded lists, do you get an
> gr. Martin
>> lazy loading.
>> Thanks
>> Yigal
Re: HbResourceImpl [message #112838 is a reply to message #112812] Wed, 20 February 2008 16:13 Go to previous message
Can you enter a bugzilla for this then I can look at it? I am not sure if it solves your issue though.
gr. Martin
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> gr. Martin
>>> lazy loading.
>>> Thanks
>>> Yigal
The Netherlands
Re: HbResourceImpl [message #615526 is a reply to message #112732] Wed, 20 February 2008 14:00 Go to previous message
Hi Yigal,
gr. Martin
> lazy loading.
> Thanks
> Yigal
The Netherlands
Re: HbResourceImpl [message #615528 is a reply to message #112787] Wed, 20 February 2008 14:52 Go to previous message
Yigal
Martin Taal wrote:
> Hi Yigal,
> gr. Martin
>> lazy loading.
>> Thanks
>> Yigal
Re: HbResourceImpl [message #615530 is a reply to message #112812] Wed, 20 February 2008 16:13 Go to previous message
gr. Martin
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> gr. Martin
>>> lazy loading.
>>> Thanks
>>> Yigal
The Netherlands
Previous Topic:Too many join - issue with the HibernateMapping file
Next Topic:[CDO] Questions about 0.8.0M5
Current Time: Wed Jul 23 02:39:34 EDT 2025
Powered by FUDForum. Page generated in 0.31606 seconds
