Home » Newcomers » Newcomers » Installed the standard version of eclipse, Do I have to install jre else?(standard, jre,)
icon1.gif  Installed the standard version of eclipse, Do I have to install jre else? [message #1128096] Mon, 07 October 2013 06:31 Go to next message
I have installed the standard version of eclipse, Do I have to install jre else for developing java?
or say, does standard version involve jre?
or can standard version do all what jre can do ?
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1128103 is a reply to message #1128096] Mon, 07 October 2013 06:40 Go to previous messageGo to next message
You need a JRE to run Eclipse itself. Can you run your installation
yet; if not, see the stick post for this forum.
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1128300 is a reply to message #1128103] Mon, 07 October 2013 10:55 Go to previous messageGo to next message
Ed Merks wrote on Mon, 07 October 2013 06:40
In the past I used it with jre, but now I nearly forget them all. all is stating from beginning.
at my new machine, I haven't yet installed jre, but it seems no problem to vist java pages and files.
why?
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1128316 is a reply to message #1128300] Mon, 07 October 2013 11:10 Go to previous messageGo to next message
If Eclipse starts, there's definitely a JRE installed and available.
Within the IDE itself you might want to use a specific one which you'd
configure in your Java -> Installed JREs preference.
>> install > jre else for developing java?
> why?
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1128334 is a reply to message #1128300] Mon, 07 October 2013 11:26 Go to previous messageGo to next message
as the file does not install, just extend to a certain fold. so I han't yet found any problem. but when run it, it shows that the jre is lack.
or need jdk.
now the question is why the standard version does not include jdk?
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1128339 is a reply to message #1128334] Mon, 07 October 2013 11:34 Go to previous messageGo to next message
Comments below.
What file?
I'm not sure what you're trying to say.
Sounds fine then.
How does it show that?
> or need jdk.
I find that I always want to configure a JDK with source so I can debug
into the JRE code easily.
Because the JDKs are licensed by their providers with their own specific
rules about how they are distributed. So you'll have to get one from an
appropriate source and use it.
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1128378 is a reply to message #1128339] Mon, 07 October 2013 12:21 Go to previous messageGo to next message
Ed Merks wrote on Mon, 07 October 2013 11:34
Comments below.
What file?
Sounds fine then.
> or need jdk.
the elipse does not need install like other software did, just depress to some folder.
it shows need jre or jdk.
does ide for java develper include jdk?
or can I install ide for java developer without standard version?
[Updated on: Mon, 07 October 2013 12:33] by Moderator
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1129100 is a reply to message #1128378] Tue, 08 October 2013 05:33 Go to previous messageGo to next message
I can't parse statements nor your questions... In any case, you need at
JRE to run Eclipse itself, you also need a JRE if you're going to use
Eclipse to develop Java applications (it could be a different one), and
no package comes with a JRE so you have to just get that yourself.
>> Comments below.
>> What file?
>> Sounds fine then.
>> > or need jdk.
>> debug into the JRE code easily.
>> specific rules about how they are distributed. So you'll have to get
>> one from an appropriate source and use it.
> to some folder.
> or do I have to install ide for java developer without standard version?
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1129131 is a reply to message #1129100] Tue, 08 October 2013 06:11 Go to previous messageGo to next message
I can get the newest version of jre7 from java page. but when install it, there is something wrong with it.
data can not write into....
I shall tell you all when I solve it.
I delete the standard 4.3version and going to install ide for java dev.
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1129143 is a reply to message #1129131] Tue, 08 October 2013 06:27 Go to previous messageGo to next message
the problem has been solved. and jre has been successful installed.
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1129164 is a reply to message #1129143] Tue, 08 October 2013 06:58 Go to previous messageGo to next message
But when I run eclipse ide for java dev, I was prompted
"failed to create the java virtual machine" what's matter?
I test jre and all is runing well.
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1129192 is a reply to message #1129164] Tue, 08 October 2013 07:31 Go to previous message
ah, solution is change 256 to 128.
ok.
Previous Topic:What is different between Standard version and IDE for developer?
Next Topic:How Install Spring in Eclipse 3.7
Current Time: Mon Jul 28 10:32:42 EDT 2025
Powered by FUDForum. Page generated in 0.13929 seconds
