Home » Archived » BIRT » Birt Parameter Error(Cannot read property "length" from null)
Birt Parameter Error [message #1126962] Sun, 06 October 2013 01:14 Go to next message
Hi friends,
I needed to create a set of parameters on a BIRT report that allowed the user to select
from a list of items. The selection had to allow for just a single item to be selected, or for a range or multiple, non-contiguous ranges or items to be selected.
Plus I wanted to allow the user to click a single check box to select all items if
required.
But when I try to run this report I get this error.
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.3.2.r232_v20090211
Error Code:data.engine.BirtException
Error Message:A BIRT exception occurred: There are errors evaluating script "__bm_beforeOpen()":
TypeError: Cannot read property "length" from null (<inline>#8).. See next exception for more information.
Please assist..
My First DataSet
sqlText = with rasheem as(
select invbalances.curbal curbal, issuetype ,matusetrans.itemnum itemnum,matusetransid ,
description ,CONVERT(date,transdate ) as transdate,transdate act_transdate
,storeloc ,refwo ,matusetrans.binnum binnum,quantity ,p1.displayname enterby,
memo ,p2.displayname issueto
from matusetrans
join invbalances on matusetrans.itemnum =invbalances.itemnum
join person p1 on matusetrans.enterby=p1.personid
join person p2 on matusetrans.issueto =p2.personid )
select itemnum, matusetransid
from rasheem
and fetch
row["itemnum"] = maximoDataSet.getString("itemnum");
row["matusetransid"] = maximoDataSet.getInteger("matusetransid");
return (true);
My Second Data Set
sqlText = with mokkai as(
select invbalances.curbal curbal, issuetype ,matusetrans.itemnum itemnum, matusetransid,
description ,CONVERT(date,transdate ) as transdate,storeloc ,refwo ,matusetrans.binnum binnum,quantity ,p1.displayname enterby,
from matusetrans
where issuetype ='issue' and enterby in('oommenj'))
select curbal, issuetype , itemnum, matusetransid,
description ,transdate,storeloc ,refwo ,binnum,quantity , enterby,
memo ,issueto from mokkai where transdate > = '08/22/13'
and transdate < = '08/22/13'
and fetch
row["curbal"] = maximoDataSet.getDouble("curbal");
row["issuetype"] = maximoDataSet.getString("issuetype");
row["description"] = maximoDataSet.getString("description");
row["storeloc"] = maximoDataSet.getString("storeloc");
row["refwo"] = maximoDataSet.getString("refwo");
row["binnum"] = maximoDataSet.getString("binnum");
row["quantity1"] = maximoDataSet.getString("quantity");
row["transdate1"] = maximoDataSet.getDate("transdate");
row["enterby"] = maximoDataSet.getString("enterby");
row["memo1"] = maximoDataSet.getString("memo");
row["issueto1"] = maximoDataSet.getString("issueto");
row["matusetransid"] = maximoDataSet.getString("matusetransid");
return (true);
on the second data set on beforeOpen event I've created this
//Get the report parameters
ParamItem = reportContext.getParameterValue("Item");
ParamAllItems = reportContext.getParameterValue("AllItems");
//Generate comma seperated list of customers
ItemList ="";
i = 0
for
(i; i<ParamItem.length; i++)
ItemList += ParamItem[i] +","
//Remove final comma
ItemList=ItemList.substring(0,ItemList.length-1);
//If all customers was not selected then add the customer list to the query
if
(ParamAllItems==false)
this.queryText +=" WHERE matusetransid IN ("+ ItemList +")" ;
When I try to execute it I get this error..
All your assistance will be highly appreciated.
Re: Birt Parameter Error [message #1129088 is a reply to message #1126962] Tue, 08 October 2013 05:20 Go to previous message
firstly here is a small tip to simplify your script, rather than a loop we can build itemList with a simple function:
ItemList = ParamItem.join(",");
It appears the ParamItem is empty in the beforeOpen event of the second dataset when it is triggered. If users select the checkbox the ParamItem remains undefined, you should at first check the value of allItems, something like this:
if(ParamAllItems==false){
}else{
  if (ParamItem!=null){
    this.queryText +=" WHERE matusetransid IN ("+ ParamItem.join(",")+")" ;
With this code, note if users don't select any value in ParamItem, then all values are returned.
Where the second dataset is invoked? In the report body or as a datasource of another parameter?
Previous Topic:Global Variables not working in Web Viewer
Next Topic:Package with uri "ChartModel" not found
Current Time: Sun Jul 27 09:04:16 EDT 2025
Powered by FUDForum. Page generated in 0.03288 seconds
