[ETL] Error "Property 'stereotype' not found in object Class [...]" [message #1125128] |
Fri, 04 October 2013 03:20  |
Hello all,
in my ETL module, I want to restrict transformations to elements with a certain stereotype. Hence, I need to determine the stereotype of the elements. I do this using an own operation called "hasStereotype", see the following code.
operation Source!Class hasStereotype(name:String):Boolean {
return self.stereotype.exists(st:Class!Stereotype|st.name=name);
rule CopyProblemStatement
transform sps : Source!Class
to tps : Target!Class{
guard : sps.hasStereotype("Problemstatement")
Unfortunately, when I try to run this transformation, I receive an error, see the attached screenshot of the code and the error message.
I provide a detail description and minimum example concerning my project in a note and a zip file besides the screenshot of the code and the error message in the attachment to this message.
Any helpful hint is very much appreciated.
Kind regards, Alexander
FUDForum. Page generated in 0.07387 seconds
