| Java int[] Array [I@24a1a602] [message #1125692] |
Fri, 04 October 2013 15:58  |
Hello all, I'm having an immense amount of trouble creating integer arrays.
I try to declare them like this:
int[] intArray = new int[5]
And when I try to print the output to the console, I receive this:
I'm not sure what this means, if I'm doing something wrong, or what's happening.
I'm very sorry if this is in the wrong section, or if this has been answered before. I tried doing some searches but nothing seemed to have come up.
Thank you in advance for any help you can provide!
| Re: Java int[] Array [I@24a1a602] [message #1126154 is a reply to message #1125692] |
Sat, 05 October 2013 03:54   |
Preston,
Comments below.
> arrays.
> [I@24a1a602]
Yes, that's expected. The toString implementation of any array is not
all that pretty. It follows the basic default pattern of
<class-name>@<system-hash-code>. In this case, because it's an array
class, it starts with [, and because it's "int" the special short name
for that is I so you see "[I" as the class name.
> happening.
Nothing is wrong.
> have come up.
| Re: Java int[] Array [I@24a1a602] [message #1126478 is a reply to message #1126154] |
Sat, 05 October 2013 12:09   |
Use Arrays.toString(intArray) to get the behavior you probably want.
On 10/5/2013 3:54 AM, Ed Merks wrote:
> Preston,
> Comments below.
>> [I@24a1a602]
> Yes, that's expected. The toString implementation of any array is not all that pretty. It follows the basic default pattern of <class-name>@<system-hash-code>. In this case, because it's an array
> class, it starts with [, and because it's "int" the special short name for that is I so you see "[I" as the class name.
> Nothing is wrong.
FUDForum. Page generated in 0.11193 seconds
