Home » Language IDEs » ServerTools (WTP) » XML catalog and schema imports
XML catalog and schema imports [message #112637] Sun, 19 June 2005 07:01 Go to next message
Originally posted by: thhal.mailblocks.com
I have a user defined XML schema catalog with several entries. It works
just fine when I edit XML files that are instances of the schemas but I
can't get the XML-Schema <import namespace="xxx"/> to work property. It
seems that the XML-Schema editor itself doesn't use the XML catalog. Is
that the case?
Thomas Hallgren
Re: XML catalog and schema imports [message #113373 is a reply to message #112637] Thu, 23 June 2005 12:38 Go to previous messageGo to next message
On Sun, 19 Jun 2005 07:01:30 -0400, Thomas Hallgren <thhal@mailblocks.com> wrote:
> It
> that the case?
I should ... if you can not get to work with recent build (e.g. 6/24 I-build),
please open a bug with small sample files and schemas, that would be very
helpful and much apprecitated.
Re: XML catalog and schema imports [message #113462 is a reply to message #113373] Thu, 23 June 2005 20:14 Go to previous messageGo to next message
I could not get the XSD editor to use the catalog to resolve URI for
imported schema. I would like to use this while creating a new schema that
imports and extends a standard schema from the catalog.
I am running the 17 June I-build of WTP with Eclipse 3.1 RC2
See bugzilla with attached test schemas:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=101574
Dave Carlson
"David Williams" <david_williams@us.ibm.com> wrote in message
news:op.sst0izqdac05ss@news.eclipse.org...
> wrote:
>> It
>> that the case?
> I-build),
Re: XML catalog and schema imports [message #113635 is a reply to message #113462] Fri, 24 June 2005 10:36 Go to previous message
Originally posted by: ebelisar.ca.ibm.com
Dave, thanks for logging the defect. We are investigating it and will
update bug comments.
Best regards, Ella
> Cheers,
> Dave Carlson
>> wrote:
>>> It
>>> that the case?
>> I-build),
Previous Topic:Run Web Services Explorer outside of WTP
Next Topic:Error creating "New Dynamic Web Project"
Current Time: Sun Jul 20 21:10:15 EDT 2025
Powered by FUDForum. Page generated in 0.25408 seconds
