Home » Eclipse Projects » Remote Application Platform (RAP) » Client error: TypeError: ObjectManager.getEntry(...) is undefined(Client error after press keys.)
icon8.gif  Client error: TypeError: ObjectManager.getEntry(...) is undefined [message #1122623] Tue, 01 October 2013 15:29 Go to next message
On RAP 2.1 application, I pressed several keys quickly on page and "client error" occurred.
Stack trace shows the error occurs at rap-client.js line 71046. The method is rwt.remote.RemoteObjectFactory._initRemoteObject.
Code is:
var handler = ObjectManager.getEntry( id ).handler;
Is this a bug or something is wrong in my application? I am stuck for the error occurs repeatedly. I really need help on this.
[Updated on: Fri, 04 October 2013 16:06] by Moderator
Re: Client error: TypeError: ObjectManager.getEntry(...) is undefined [message #1123296 is a reply to message #1122623] Wed, 02 October 2013 08:15 Go to previous messageGo to next message
Hi.
I will need some more info to help you:
Do you have a custom widget? (Based on JavaScript.)
What widget is focused while you type?
Do you use a key listener somewhere, or keyboard shortcuts, mnemonics,
accelerator, display event filter?
If yes, what does it do?
Did you try RAP 2.1.1?
Can you provide a code snippet to reproduce this error? (Would be most
helpful.)
Greetings,
Tim
Am 01.10.2013 21:56, schrieb Jacob He:
> Code is:
Tim Buschtöns
Twitter: @EclipseRAP
Re: Client error: TypeError: ObjectManager.getEntry(...) is undefined [message #1125696 is a reply to message #1123296] Fri, 04 October 2013 16:01 Go to previous messageGo to next message
Hi, Tim,
Thanks for response.
The base idea of my application is:
1. use RWT.ACTIVE_KEYS to accept some shortcut key strike from web page;
2. the key strike will signal a back end thread to run some business logic;
3. the back end thread will update widgets on web page, like deleting old widgets, creating new widgets, updating exist widgets, etc., at the end of its process.
The attachment is a prototype project for such idea. The entry point of it is "/demo". After opening a new editor, just press one of following keys quickly enough, the client error will occur always.
Keys: "ENTER", "BREAK", "PAGE_DOWN", "PAGE_UP", "F1", "F2", "F3", "F4", "F5", "F6", "F7", "F8", "F9", "F10", "F11", "F12", "SHIFT+F1", "SHIFT+F2", "SHIFT+F3", "SHIFT+F4", "SHIFT+F5", "SHIFT+F6", "SHIFT+F7", "SHIFT+F8", "SHIFT+F9", "SHIFT+F10", "SHIFT+F11", "SHIFT+F12"
One of my customer's tester tried this scenario during UAT extremely by pressing a key without releasing, and then filed this error as critical and unacceptable. I have to deal with it now.
Jacob
  • Attachment: Demo.zip
    (Size: 22.96KB, Downloaded 183 times)
Re: Client error: TypeError: ObjectManager.getEntry(...) is undefined [message #1125698 is a reply to message #1122623] Fri, 04 October 2013 16:05 Go to previous messageGo to next message
BTW, this error occurs on both RAP 2.1 and 2.1.1.
Re: Client error: TypeError: ObjectManager.getEntry(...) is undefined [message #1128181 is a reply to message #1125696] Mon, 07 October 2013 08:26 Go to previous messageGo to next message
Hi.
Okay, I can reproduce it. It looks like there is a bug in the Text
widget that causes it to render a the selection while it looses focuses
even though the widget is about to be disposed. Please open a bugzilla
entry about this issue, add the demo application and a link to this
thread. We will then continue the discussion there.
Greetings,
Tim
Am 04.10.2013 22:01, schrieb Jacob He:
> Hi, Tim,
> Regards,
> Jacob
Tim Buschtöns
Re: Client error: TypeError: ObjectManager.getEntry(...) is undefined [message #1128182 is a reply to message #1128181] Mon, 07 October 2013 08:26 Go to previous message
Sorry, I saw too late that you already opened a bug in the other thread.
Never mind.
Am 07.10.2013 14:26, schrieb Tim Buschtöns:
> Hi.
> Greetings,
> Tim
>> Hi, Tim,
>> logic;
>> Regards,
>> Jacob
Tim Buschtöns
Previous Topic:Loading local html in browser widget
Next Topic:Client error: TypeError
Current Time: Thu Jul 24 23:17:04 EDT 2025
Powered by FUDForum. Page generated in 0.32422 seconds
