Home » Eclipse Projects » EclipseLink » BUG : postgresql @NamedStoredProcedureQuery call
BUG : postgresql @NamedStoredProcedureQuery call [message #1120996] Mon, 30 September 2013 02:50 Go to next message
I created a simple function in postgresql
  CREATE OR REPLACE FUNCTION simpletest()
  RETURNS bigint AS
$BODY$
BEGIN
   return 10;
END;
$BODY$
  LANGUAGE plpgsql
when I try to run it with eclipse link I get this exception
ERROR: syntax error at or near ")"
  Position: 20
Error Code: 0
Call: EXECUTE simpletest()
Query: DataReadQuery(name="simpletest" )
I assume this is eclipselink bug and this is how I define and run the function.
@NamedStoredProcedureQuery(name="simpletest", procedureName="simpletest")
public class Student
public void exec()
        Query createNamedQuery = entityManager.createNamedQuery("simpletest");
        System.out.println(createNamedQuery.getResultList());
is this a bug ?
Re: BUG : postgresql @NamedStoredProcedureQuery call [message #1121017 is a reply to message #1120996] Mon, 30 September 2013 03:18 Go to previous messageGo to next message
I realized this is related to org.eclipse.persistence.platform.database.PostgreSQLPlatform
public String getProcedureCallHeader() {
        return "EXECUTE ";
based on http://www.postgresql.org/docs/8.0/static/plpgsql.html. it should return "SELECT " not EXECUTE
Re: BUG : postgresql @NamedStoredProcedureQuery call [message #1121392 is a reply to message #1121017] Mon, 30 September 2013 11:20 Go to previous messageGo to next message
How have you set the PostgreSQLPlatform so that it is used? The PostgreSQLPlatform class overrides the buildProcedureCallString() method, so getProcedureCallHeader() on the DatabasePlatform class shouldn't get used.
Try setting the eclipselink.target-database property to "PostgreSQL" if you haven't already:
http://eclipse.org/eclipselink/documentation/2.4/jpa/extensions/p_target_database.htm
Best Regards,
Chris
Re: BUG : postgresql @NamedStoredProcedureQuery call [message #1124425 is a reply to message #1121392] Thu, 03 October 2013 10:23 Go to previous messageGo to next message
thank you Chris,
if you mean
yes I have used it as target database and it is "EXECUTE" in getProcedureCallHeader() method not SELECT anyway Do you know why direction is deprecated ?
I have a function with two input arguments and two output arguments which is defined as follow
@NamedStoredProcedureQuery(name = DocumentAccess.CONTAINS_DOC_BY_ANOTHER_OWNER, procedureName = "contains_doc_by_another_owner", parameters = {
                @StoredProcedureParameter(queryParameter = "commaSeparatedIds", type = String.class, direction=Direction.IN),
                @StoredProcedureParameter(queryParameter = "uid", type = Long.class, direction=Direction.IN),
                @StoredProcedureParameter(queryParameter = "has_another_owner", type = Boolean.class, direction= Direction.OUT),
                @StoredProcedureParameter(queryParameter = "doc_id", type = Long.class, direction= Direction.OUT)}, resultSetMappings = { DocumentAccess.CONTAINS_DOC_BY_ANOTHER_OWNER }),
but the query is select contains_doc_by_another_owner(?,?) . it should be
select has_another_owner, doc_id from contains_doc_by_another_owner(?,?)
Re: BUG : postgresql @NamedStoredProcedureQuery call [message #1125564 is a reply to message #1124425] Fri, 04 October 2013 12:54 Go to previous messageGo to next message
Looks like 'direction' was deprecated and replaced with 'mode' to be inline with javax.persistence.StoredProcedureParameter from the JPA 2.1 specification.
I'm not sure why it is calling execute instead of select. Please provide the full stack from the error as that might give an indication as to why the wrong code path is being used.
Re: BUG : postgresql @NamedStoredProcedureQuery call [message #1126061 is a reply to message #1125564] Sat, 05 October 2013 01:26 Go to previous message
I had it fixed by extending Postgresql platform
public class PostgresqlPlatform extends PostgreSQLPlatform
        return "SELECT * FROM ";
    public boolean shouldPrintStoredProcedureArgumentNameInCall()
        return false;
Previous Topic:Reverse Engineering Legacy Database
Next Topic:second level cache without persistence.xml
Current Time: Sat Jul 26 10:46:11 EDT 2025
Powered by FUDForum. Page generated in 0.07418 seconds
