ClassCastException & JobReconcilier [message #1125503] |
Fri, 04 October 2013 11:32  |
Hi everybody,
I'm working with the new Papyrus Xtext integration, with celleditor developped for the ModelExplorer, but in my case, I open them in the Papyrus nattable integration.
I manage myself the string error (without using alf).
I'm working with Kepler, using the Xtext integration done for Luna (Xtext 2.4.2).
I get this error when the typed string is not valid, any ideas?
java.lang.ClassCastException: org.eclipse.xtext.nodemodel.impl.LeafNode cannot be cast to org.eclipse.xtext.nodemodel.impl.CompositeNode
at org.eclipse.xtext.nodemodel.impl.NodeModelBuilder.replaceAndTransferLookAhead(NodeModelBuilder.java:338)
at org.eclipse.xtext.parser.impl.PartialParsingHelper.reparse(PartialParsingHelper.java:168)
at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.doReparse(AbstractAntlrParser.java:136)
at org.eclipse.xtext.parser.AbstractParser.reparse(AbstractParser.java:48)
at org.eclipse.xtext.resource.XtextResource.update(XtextResource.java:220)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.doReconcile(XtextDocumentReconcileStrategy.java:125)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.reconcile(XtextDocumentReconcileStrategy.java:55)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.doRun(XtextReconciler.java:329)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.access$3(XtextReconciler.java:316)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:273)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:36)
at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.modify(AbstractReadWriteAcces.java:81)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.modify(XtextDocument.java:201)
at org.eclipse.xtext.ui.editor.model.XtextDocument.internalModify(XtextDocument.java:98)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.run(XtextReconciler.java:270)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
FUDForum. Page generated in 0.03734 seconds
