Home » Eclipse Projects » Virgo » Start VTS in Debian as process - define execution user(possibility to configure process user in virgo)
Start VTS in Debian as process - define execution user [message #987855] Wed, 28 November 2012 07:10 Go to next message
Is it possible to configure the username for the user, under which the process should be running, e.g. in the config.ini? Or somehow pass an command line argument to the startup.sh script with the username?
we are currently using:
su - uname -c /opt/vts/bin/startup.sh
But we would prefer to be able to configure it wihtin config.ini or any of the configuration files within virgo.
Any hints are appreciated.
Regards Dani
[Updated on: Wed, 28 November 2012 07:11] by Moderator
Re: Start VTS in Debian as process - define execution user [message #1125074 is a reply to message #987855] Fri, 04 October 2013 02:10 Go to previous message
see this post for an answer [has an init script attached]
Previous Topic:using autbind on linux for virgo tomcat server to bind on ports < 1024
Next Topic:InfoQ interview on Virgo
Current Time: Sun Jul 27 14:05:05 EDT 2025
Powered by FUDForum. Page generated in 0.06304 seconds
