Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem
Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem [message #112457] Sat, 16 February 2008 07:43 Go to next message
Hi Daniel,
See inline (MT>>>).
gr. Martin
Daniel Gerlach wrote:
> org.eclipse.emf.teneo.TeneoException: The dbid
http://docs.active-endpoints.com/activebpel/sample/wsdl/flig htTrackerService/2006/07/flightTrackerService.wsdl/DocumentR oot/FlightHistory
> and nsuri:
> does not resolve to an epackage
> Is there a possible workaround to grab the EObjects which don't belongs
> to an registerd EPackage and save them as BLOBs in the database in a
> special table.
MT>> No this is currently not possible, Teneo assumes that all eobjects belong a registered
epackage. If you enter a bugzilla for this then I can see what I can do. But to be realistic, it is
a fair amount of work so it will take a while (> 1 month) before I can pick this up.
> 2. Because im am not tied to a special OR-Mapper, i tried JPOX 1.19 with
> Teneo, which according to elver.org supports "xsd:any". But here, i get
> an exception when i am creating the corresponding package.jdo for the
> given ecore. The exception happens when i programmaticly create the
> mapping and also from the eclipse/JPOX plugin- menu.
MT>> Hmm, I would need to debug this to see what happens. For one reason or another my news reader
(thunderbird) gets confused by your post. So I see the attachment content inline and can't download
them. Can you send them to me directly (mtaal@elver.org)?
But for jpox the same limitation as for hibernate applies, the epackage to which you refer should be
registered with Teneo.
> 523 [main] DEBUG
> org.eclipse.emf.teneo.annotations.mapper.OneToManyReferenceA nnotator -
> EReference + correlation/Correlations does not have a onetomany
> annotation, adding one
> 523 [main] DEBUG
> Setting indexed and unique from ereference because otm was not set manually!
> 523 [main] DEBUG
> org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator - Creating
> mapping for eclass CorrelationSet
> 523 [main] DEBUG
> org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator - Adding
> default annotations for EClass: CorrelationSet
> 524 [main] DEBUG
> org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator - Setting the
> superentity of the eclass
> 524 [main] DEBUG
> org.eclipse.emf.teneo.annotations.mapper.SingleAttributeAnno tator -
> Adding default annotations for EAttribute name
> 524 [main] DEBUG
> org.eclipse.emf.teneo.annotations.mapper.OneToManyAttributeA nnotator -
> EAttribute properties/CorrelationSet needs a onetomany
> 524 [main] DEBUG
> One to many not present adding one
> Exception in thread "main" java.lang.NullPointerException
> at
> org.eclipse.emf.teneo.util.EcoreDataTypes.getTargetTypeName( EcoreDataTypes.java:117)
> at
org.eclipse.emf.teneo.annotations.mapper.BaseEFeatureAnnotat or.getTargetTypeName(BaseEFeatureAnnotator.java:168)
> at
org.eclipse.emf.teneo.annotations.mapper.OneToManyAttributeA nnotator.annotate(OneToManyAttributeAnnotator.java:100)
> at
> org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator.a nnotate(EFeatureAnnotator.java:135)
> at
> org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator.ann otate(EClassAnnotator.java:223)
> at
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator .processPackage(AnnotationGenerator.java:167)
> at
> org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator .map(AnnotationGenerator.java:135)
> at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:142)
> at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:66)
> at
> org.eclipse.emf.teneo.jpox.JpoxHelper.generateMapping(JpoxHe lper.java:162)
> at
> org.eclipse.emf.teneo.jpox.JpoxHelper.generateMapping(JpoxHe lper.java:153)
> at test.TestJpox.genMappingFile(TestJpox.java:54)
> at test.TestJpox.main(TestJpox.java:21)
> I have debugged a little bit and it seems the list of eClassifiers in
> the EcoreDataTypes.class has one entry which is set to null. But i
> haven't any clue what's happening here.....
> 3. One last little question:
> Hibernate offers to load an object from the database with the objectID:
> Code:
> session.load(objectID);
> or
> session.get(objectID);
> The context here is, that i work with detached objects and after the
> work is done, i want to reload these objects. I get the ID with
> IdentifierCacheHandler.getID(), but how can i load the objects with it.
> Is this possible in Teneo, or should i use a normal query to get the
> objects again?
MT>> The id which you get back from the IdentifierCacheHandler can be used as a normal id in
hibernate. Note the identifiercachehandler only works if your objects have stayed in-memory all the
time. So for example if you send them over the wire (in a client-server scenario) and get them back
then it won't work (as the object is a different instance in memory).
> Thanks in advance,
> Daniel Gerlach
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem [message #112470 is a reply to message #112457] Sat, 16 February 2008 08:04 Go to previous messageGo to next message
Hi Martin,
i have send you the files to your eMail.
Daniel Gerlach
Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem [message #112482 is a reply to message #112470] Sun, 17 February 2008 07:23 Go to previous messageGo to next message
--------------060108050803070505060106
now after a little bit of testing, i understand that Teneo only persists
EObjects which are registered EPackages in the DataStore.
But what about the EObjects which are resolved as EMF AnyTypes (see
http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava)?
Is there any possibility to save them as BLOB in the database in a
special table?
I have created a simple example which describe my problem:
- i have 2 XSDs person.xsd and the children.xsd.
- i have also 2 xml files which should be persisted in the database:
normalPerson.xml and the PersonWithUsedXSD_AnyElement.xml.
(All files are attached to this eMail)
The person.xsd has an "xsd:any" element. Now i created an EPackage from
the person.xsd, a hibernate mapping file with teneo and exported the
schema to the database.
After that i wanted to persist the normalPerson.xml. Everything works.
But when i wanted to persisted the PersonWithUsedXSD_AnyElement.xml, i
got an error, because the children.xsd hasn't got a corresponding EPackage.
It would be nice, if you could look into it. Perhaps there is a manually
workaround. At the moment i delete all EMF AnyTypes manually in order to
save them into the database, but that is not really a solution....
Greetings
Daniel Gerlach
person.xsd:
<xs:schema xmlns="www.gerry.de"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
targetNamespace="www.gerry.de" elementFormDefault="qualified"
attributeFormDefault="unqualified">
<xs:element name="person">
<xs:annotation>
<xs:documentation>Comment describing your root element</xs:documentation>
</xs:annotation>
<xs:complexType>
<xs:sequence>
<xs:element name="lastname" type="xs:string"/>
<xs:element name="firstname" type="xs:string"/>
<xs:any namespace="##any" processContents="lax" minOccurs="0"/>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
children.xsd:
<!-- edited with XMLSpy v2008 sp1 (http://www.altova.com) by Daniel
Gerlach (Uni Ger) -->
<xs:schema xmlns="www.gerrry.com"
targetNamespace="www.gerrry.com" elementFormDefault="qualified"
<xs:element name="children">
<xs:annotation>
</xs:annotation>
<xs:complexType>
<xs:sequence>
<xs:element name="childname" type="xs:string" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
normalPerson.xml:
<person xmlns="www.gerry.de"
xsi:schemaLocation="www.gerry.de person.xsd">
<lastname>Gerlach</lastname>
<firstname>Daniel</firstname>
</person>
PersonWithUsedXSD_AnyElement.xml:
xsi:schemaLocation="www.gerry.de person.xsd www.gerrry.com children.xsd">
<lastname>tommy</lastname>
<firstname>jkerov</firstname>
<children>
<childname>cecile</childname>
</children>
</person>
Content-Type: application/zip;
name="exampleFiles.zip"
Content-Disposition: inline;
filename="exampleFiles.zip"
UEsDBBQAAAAIABxfUTg5eWuXXQEAAIECAAAMAAAAY2hpbGRyZW4ueHNkdVG7 bgIxEKwTKf+w
cQXFcZA0CEEogkiTRxGQ0hrfwlny4/CDu/v7rHmEEJTOO7s7M54dTxutYIfO S2smbNDrM0Aj
bCHNZsKWi3k2ZNOnu9vxfZYBFjJgAbUMJXy9vX5WLewe+v0h+GoAnTKEapTn dV33uAp2x3vC
6i6sWphxI1HBCzrFRQmdpZGp6EKWJerGj7woUXMgL8ZPWKLYoHOuTRTsAI8a 6vzSqB971m1y
0h/kycyegUHgboPhnWv0FRd4TYYKNZowt07PcM2jChO2jVzJtcSCAQ/ByVUM eDEQzXmELN8k
z0ciMFyTjCilKhyafXvf58bYwAPlmqADVlgRaekIP1u9ZyjQCxKlyKG10YGz Npx8jvO/aweB
/ELhR5S+WClsFm2FZ1WP20hHPSL/mU9Pyq+tCEhLwZEhBpo3H0JE51MKKxtN QRnkR/L8kj0h
VyYIOwtSTeXp4FR9A1BLAwQUAAAACACuZFE4n2p9GOQAAABPAQAAEAAAAG5v cm1hbFBlcnNv
bi54bWxVT71uwyAQnlup73BlSgbAbpfIwslStUs6tZG6UqA2EgYLkLHfvhCn VbLdfXffHzvM
g4FJ+aCdbVFNKgTKCie17Vp0+nzFO3TYP9yzR4xBSR2VhKRjD1/vx49xgemp qnYQxho2fYxj
Q2lKiXAT3cSJcMMWvhd44VYrA2/KGy562JysLssWMC7SY3Z3FnIQG1pU+J3y fiFSoRVs5qBb
dKWfnonzHc3eNS1BRK8GjrUNkVuRWfm/CWfw6ASPudqtLqyWZA4S5QR3zPAQ LR/U/pKR0T/k
fP7R/rKtVRj9R0oBusrl8RdQSwMEFAAAAAgA12FROBfq6tg/AQAAgwIAAAoA AABwZXJzb24u
eHNkjVLLTsMwEDyDxD9Y5kySwgVVDT0U9cTjQJG4GmebWooftdck+XvWSR9q AYmbd9azM7P2
bN7phn2BD8qakk+ygjMw0lbK1CV/Xy1v7vn84epy1oVpkBvQghHBhJK3bZvV 4H2fVcBHcNoR
vkF00zxP7fYus77Ob4tikn88P70NfM5Q+BrwRWgITkg4HwUNaDC4tF4/wlrE Bku+jaJRawUV
ZwLRq8+IcHIhmuMVsnuR/O4GMSM0iTjKaM3QHLrCGIsCKXaCRqyyMhJlBy+s HvgVBEmStBHW
2+iZtxb3Lmf5OW0UyE8UDqLSatdAt+odHFUDbCPtfIf8Yr0RAdOJVtc7qhMH Pfnh+Z+ctfL/
IQnTE+HwEtfXBHDmvJUQwsIapIkhOeg408q8Shk91cU4JAU9DZCQHzkJO/qj msr9b6LqG1BL
AwQUAAAACAC0ZFE4JwtWQAYBAAClAQAAIAAAAFBlcnNvbldpdGhVc2VkWFNE X0FueUVsZW1l
bnQueG1sVU+7TsMwFJ1B4h8untohcQNLFTntgmApE1RiNc4lMTh2ZFt5/D22 m0K7+TzuOcds
P3UKBrROGl2RIt8QQC1MLXVTkeP7c7Yl+93dLbvPMsBaeqxhlL6Fj9fDWz/D 8LDZbMH1Baxa
7/uS0nEcc668GXguTLeGzxmeuJao4AWt4qKF1VHLCNaQZTG6D+1GQxiiXUXi fYPWznmN5ESW
k5MVucgfH3NjGxq6CxqHiBY7nkntPNciXAV/6RJ5MIL78LXrXDhV5pOrYeGD EPeCaKWqLSaN
hHU3THHnNe9w503XzYyecRK/pF3Q9w9aMzAamX/9HBfBgpImUEiFjCbmz00v 7IymkfH5C1BL
AQIUABQAAAAIABxfUTg5eWuXXQEAAIECAAAMAAAAAAAAAAAAIAAAAAAAAABj aGlsZHJlbi54
c2RQSwECFAAUAAAACACuZFE4n2p9GOQAAABPAQAAEAAAAAAAAAAAACAAAACH AQAAbm9ybWFs
UGVyc29uLnhtbFBLAQIUABQAAAAIANdhUTgX6urYPwEAAIMCAAAKAAAAAAAA AAAAIAAAAJkC
AABwZXJzb24ueHNkUEsBAhQAFAAAAAgAtGRROCcLVkAGAQAApQEAACAAAAAA AAAAAAAgAAAA
AAQAAFBlcnNvbldpdGhVc2VkWFNEX0FueUVsZW1lbnQueG1sUEsFBgAAAAAE AAQA/gAAAEQF
AAAAAA==
--------------060108050803070505060106--
Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem [message #112494 is a reply to message #112482] Sun, 17 February 2008 08:39 Go to previous messageGo to next message
Hi Daniel,
There is currently no manual workaround for this. Can you open a bugzilla for this and attach your
example to it? As said in the other post it can be some work and I am not sure if I have time to do
this before eclipsecon but I will do my best.
gr. Martin
> special table?
> Greetings
> Daniel Gerlach
> person.xsd:
> <xs:annotation>
> </xs:annotation>
> <xs:complexType>
> <xs:sequence>
> minOccurs="0"/>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> children.xsd:
> <xs:annotation>
> </xs:annotation>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> normalPerson.xml:
> </person>
> <children>
> </children>
> </person>
The Netherlands
Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem [message #112507 is a reply to message #112494] Sun, 17 February 2008 09:25 Go to previous message
Thank you for looking at it!
I need this for my Diploma Thesis, and i only implement a prototype, thus
how it works now, it is ok, so it isn't urgent. But it would be a nice
feature if one can persist every "xsd:any" element from a given XML-Schema
without registering it with an EPackage.
I will open a bugzilla. I hope this isn't hard, cause this is my first
one:)
Greetings
Daniel Gerlach
Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem [message #615502 is a reply to message #112457] Sat, 16 February 2008 08:04 Go to previous message
Hi Martin,
Daniel Gerlach
Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem [message #615503 is a reply to message #112470] Sun, 17 February 2008 07:23 Go to previous message
special table?
Greetings
Daniel Gerlach
person.xsd:
<xs:annotation>
</xs:annotation>
<xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
children.xsd:
<xs:annotation>
</xs:annotation>
<xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
normalPerson.xml:
</person>
<children>
</children>
</person>
AAAAAA==
Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem [message #615504 is a reply to message #112482] Sun, 17 February 2008 08:39 Go to previous message
Hi Daniel,
gr. Martin
> special table?
> Greetings
> Daniel Gerlach
> person.xsd:
> <xs:annotation>
> </xs:annotation>
> <xs:complexType>
> <xs:sequence>
> minOccurs="0"/>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> children.xsd:
> <xs:annotation>
> </xs:annotation>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> normalPerson.xml:
> </person>
> <children>
> </children>
> </person>
The Netherlands
Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem [message #615505 is a reply to message #112494] Sun, 17 February 2008 09:25 Go to previous message
one:)
Greetings
Daniel Gerlach
Previous Topic:Re: [Teneo] Hibernate xsd:any support / JPOX genereate MappingFile problem
Next Topic:error in initializing data store
Current Time: Sat Jul 19 10:31:37 EDT 2025
Powered by FUDForum. Page generated in 0.05406 seconds
