Re: maven archetype catalog requires authentication [message #1124246 is a reply to message #1124131] |
Thu, 03 October 2013 06:33   |
Hi Tanmoy,
At this stage I am using the New > Project > New Maven Project wizard inside Eclipse. I attach a screenshot of the preference page configured for the new URL you mentioned and in the background you can see that no archetypes are found still.
However, I can confirm that using a browser I do get access to the new URL you mentioned (is it possible that you could update the references to the sungard on the wiki page?). Furthermore using this command line I am able to generate a project ok:
mvn -DarchetypeArtifactId=tc6-ipp-portal-war -DarchetypeGroupId=org.eclipse.stardust.deploy.jee.archetypes -DarchetypeVersion=1.0.1 archetype:generate
I then cd into the project directory and ran mvn package which produced this error in finding the tomcat60-ipp-portal-war pom:
[ERROR] The build could not read 2 projects -> [Help 1]
[ERROR]
[ERROR] The project com.knowprocess:stardust2-ipp-portal:1.0-SNAPSHOT (/Users/timstephenson/tmp/stardust2/ipp-portal/pom.xml) has 2 errors
[ERROR] Non-resolvable import POM: Failure to find org.eclipse.stardust.deploy.jee.server:tomcat60-war:pom:1.0.1 in http://archive.eclipse.org/stardust/maven/3rdparty/eclipse was cached in the local repository, resolution will not be reattempted until the update interval of stardust-3rdparty-eclipse-repo has elapsed or updates are forced @ line 26, column 21 -> [Help 2]
[ERROR] Non-resolvable import POM: Failure to find org.eclipse.stardust.deploy.jee.rtenv:tomcat60-ipp-portal-war:pom:1.0.1 in http://archive.eclipse.org/stardust/maven/3rdparty/eclipse was cached in the local repository, resolution will not be reattempted until the update interval of stardust-3rdparty-eclipse-repo has elapsed or updates are forced @ line 33, column 22 -> [Help 2]
[ERROR]
[ERROR] The project com.knowprocess:stardust2-custom:1.0-SNAPSHOT (/Users/timstephenson/tmp/stardust2/custom/pom.xml) has 1 error
[ERROR] Non-resolvable import POM: Failure to find org.eclipse.stardust.deploy.jee.server:tomcat60-war:pom:1.0.1 in http://archive.eclipse.org/stardust/maven/3rdparty/eclipse was cached in the local repository, resolution will not be reattempted until the update interval of stardust-3rdparty-eclipse-repo has elapsed or updates are forced @ line 18, column 22 -> [Help 2]
It looks like those artefacts are in the download.eclipse.org rather than archive.eclipse.org repository but I am not able to find what is directing Maven to the wrong place.
Thanks in advance,
Tim
Re: maven archetype catalog requires authentication [message #1124453 is a reply to message #1124279] |
Thu, 03 October 2013 10:51   |
Next error:
[ERROR] Failed to execute goal on project stardust2-custom: Could not resolve dependencies for project com.knowprocess:stardust2-custom:jar:1.0-SNAPSHOT: The following artifacts could not be resolved: stax:stax-api:jar:1.0.1-eclipse01, rhino:js:jar:1.7R2-eclipse01, javax.activation:activation:jar:1.1-eclipse01, commons-jxpath:commons-jxpath:jar:1.3-eclipse01, aopalliance:aopalliance:jar:1.0-eclipse01, org.icefaces:icefaces:jar:1.8.2-r33557, commons-logging:commons-logging:jar:1.1.1-eclipse01, org.icefaces:icefaces-comps:jar:1.8.2-r33557, org.icefaces:icefaces-facelets:jar:1.8.2-r33557-eclipse01, log4j:log4j:jar:1.2.15-eclipse01, org.slf4j:slf4j-api:jar:1.5.11-eclipse01, javax.ws.rs:jsr311-api:jar:1.1.1-eclipse01, com.google.code.gson:gson:jar:1.6-eclipse01, backport-util-concurrent:backport-util-concurrent:jar:3.1-eclipse01, commons-collections:commons-collections:jar:3.2-eclipse01, commons-lang:commons-lang:jar:2.4-eclipse01, javax.mail:mail:jar:1.4-eclipse01, org.icepdf:icepdf-core:jar:4.3.2, net.sourceforge.htmlcleaner:htmlcleaner:jar:2.1, com.sun.media:jai_imageio:jar:1.1-eclipse01, org.apache.cxf:cxf-api:jar:2.6.1-eclipse01, com.sun.xml.bind:jaxb-impl:jar:2.1.12-eclipse01: Failure to find stax:stax-api:jar:1.0.1-eclipse01 in http://download.eclipse.org/stardust/maven/releases was cached in the local repository, resolution will not be reattempted until the update interval of stardust-3rdparty-eclipse-repo has elapsed or updates are forced -> [Help 1]
Analysing the pom with the Maven POM Editor's dependency tool shows that the carnot-engine 1.0.1 depends on this version of stax suffixed -eclipse01. A number of the other ipp dependencies seem to have similar dependencies on the other -eclipse01 variants.
And I am not able to locate these -eclipse01 dependencies in the eclipse maven repo.
Tim
FUDForum. Page generated in 0.09359 seconds
