Home » Modeling » EMF » How to Generate (Model) Code deleting prev. gen. code?
How to Generate (Model) Code deleting prev. gen. code? [message #1123569] Wed, 02 October 2013 14:03 Go to next message
Is there a way to have Generate (Model) Code deleting all prev. gen. code?
Some flag on the *.genmodel... or would this be possible with a custom Facade Helper Class?
I do understand that all the magic @generated merge "feature" would be lost - never mind.
Or is this an Enhancement? Bugzilla welcome, or waste of time?
Just a thought.
Re: How to Generate (Model) Code deleting prev. gen. code? [message #1124068 is a reply to message #1123569] Thu, 03 October 2013 02:37 Go to previous messageGo to next message
You may want to have a look at EMF loophole https://github.com/mbarbero/emf-loophole. It lets you define a model on top of genmodel. It adds some nice features like generation of custom classes and what you want: deleting the generated files each time you re-generate.
Hope this helps.
[Updated on: Thu, 03 October 2013 02:40] by Moderator
Re: How to Generate (Model) Code deleting prev. gen. code? [message #1124373 is a reply to message #1124068] Thu, 03 October 2013 09:16 Go to previous messageGo to next message
Hi Mikael
Thanks for the reference.
You could make it clearer that the URLs are update sites.
Unfortunately I think the limitation that it doesn't work for
cross-referencing genmodels is a killer for me.
It would help to see an example and know what will happen before
installing something that may interfere with genmodel.
Ed Willink
On 03/10/2013 02:37, Mikael Barbero wrote:
> Have a look at EMF loophole https://github.com/mbarbero/emf-loophole.
> Hope this helps.
Re: How to Generate (Model) Code deleting prev. gen. code? [message #1124542 is a reply to message #1123569] Thu, 03 October 2013 12:43 Go to previous message
Michael,
Does your code contain any hand written changes? If not, you could just
delete the Java packages involved. If so, what are you expecting to
happen to that? If you define the model in Xcore (you can export your
existing *.genmodel to *.xcore) and generate to the default src-gen
folder, a clean build will delete all the generated code...
> code?
> lost - never mind.
> Just a thought.
Previous Topic:EMF-Databinding and associated attributes
Next Topic:EMF Installation
Current Time: Thu Nov 06 17:59:01 EST 2025
Powered by FUDForum. Page generated in 1.04208 seconds
