Home » Modeling » TMF (Xtext) » Xbase + Inferrer in Eclipse Editor
Xbase + Inferrer in Eclipse Editor [message #1123549] Wed, 02 October 2013 13:34 Go to next message
Hello
I am trying a simple Xbase example, but it wont work in Eclipse.
First, i am creating a Xtext Project with Eclipse (4.3), removing the greeting example and using this grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.xbase.Xbase
generate myDsl "h__p://www.xtext.org/example/mydsl/MyDsl"
SomeModel :
   'test' ':' expressionValue = XExpression
After generating everything, i am adding the following code to the inferrer:
class MyDslJvmModelInferrer extends AbstractModelInferrer {
   @Inject extension JvmTypesBuilder
   def dispatch void infer(SomeModel element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
      // assuming:  test: 1 + 1
      val returnType = element.newTypeRef(Integer.TYPE)
      acceptor.accept(element.toClass("ClassName")).initializeLater [
         documentation = element.documentation;
         members += element.toMethod("method", returnType) [
            body = element.expressionValue
Finally, adding some UnitTest
@RunWith (XtextRunner)
@InjectWith (MyDslInjectorProvider)
class TestInferrer {
   @Inject extension ParseHelper<SomeModel>
   @Inject extension ValidationTestHelper
   @Inject extension CompilationTestHelper // deps:  org.eclipse.xtext.xbase.junit / org.eclipse.jdt.core
   @Test
   def void test() {''' test : 1 + 1'''.parse.assertNoErrors}
   @Test
   def javaGen() {
      '''test : 1 + 1'''
      .compile[
         print (generatedCode)
         compiledClass
So far, everthing works as expected. The output from the print is also as expected:
{ClassName=@SuppressWarnings("all")
public class ClassName {
  public int method() {
    int _plus = (1 + 1);
    return _plus;
Now i want to test the grammar in the Eclipse Editor, so starting Eclipse, creating a new file and adding the test code. But now i am getting this error:
The method +(int) is undefined
Well. Adding the xbase.jar to the project removes the error, but this cannot be the solution. Also jumping with F3 on the '+'-Sign works goining to the IntegerExtension. Cleaning out the Method body of the infer Method and the error also disappears.
I have no idea what could be wrong.
Maybe anybody has a hint.
Thanks in advance for any idea
Roman
Re: Xbase + Inferrer in Eclipse Editor [message #1123606 is a reply to message #1123549] Wed, 02 October 2013 14:58 Go to previous messageGo to next message
it is intended that you have to put xbase.lib to the classpath of the model project.
Re: Xbase + Inferrer in Eclipse Editor [message #1123632 is a reply to message #1123606] Wed, 02 October 2013 15:32 Go to previous messageGo to next message
Thanks for your fast reply.
Whats somehow strange to me is the reason, that the code works without any complaint as long as i dont use the + Operator.
for example
// works
test : 1
test : "string".toLowerCase.length
test : Integer.valueOf(1)
test : if (true) 1 else 2
// does not work
test : 1 + 1
So as long, as i am only using Methods its ok without the lib, even ifelse. The int + int Operation only works with the xbase lib around (same for Strings).
Re: Xbase + Inferrer in Eclipse Editor [message #1123636 is a reply to message #1123632] Wed, 02 October 2013 15:38 Go to previous messageGo to next message
yes,
if you dont use any stuff from the lib you wont need it.
Re: Xbase + Inferrer in Eclipse Editor [message #1123658 is a reply to message #1123636] Wed, 02 October 2013 16:01 Go to previous messageGo to next message
Thank you so far. That enought for me at the moment.
At the first glimpse, this involves xxxExtensions (String concat, Boolean Operations, etc..). I have to take a closer look at it some time. I thought things like (true || false) or ("asd" + "dsa") would not touch the xbase lib Extensions. So i was irritated that some Expressions worked and some others not.
Thanks again for your fast responses.
Re: Xbase + Inferrer in Eclipse Editor [message #1123664 is a reply to message #1123658] Wed, 02 October 2013 16:09 Go to previous message
the clue is: Everything is api: even a simple + or ||
Previous Topic:Code Generator in java
Next Topic:Code generation error messages
Current Time: Sun Jul 27 02:16:19 EDT 2025
Powered by FUDForum. Page generated in 0.05252 seconds
