Re: Cannot install plug-in through the update site I have created using Eclipse [message #1136988 is a reply to message #1123595] |
Mon, 14 October 2013 03:35  |
Hi everyone,
I have solved the problem. I don't know exactly how, however here are some steps that I hope will help other people for solving or debugging similar problems.
First, debugging:
It really helps you to understand the problem better (since the error message does not tell anything about it), if you add plug-in to your feature one-by-one. Your feature will be broken, however if there is a plug-in that has a missing dependency, then you can detect it along the way. Up to some point (the point where you add the problem plug-in), your feature will install correctly through the update site and then it will start failing. This was not the case with my problem.
While debugging, I tried to double check the dependencies that my plug-ins and features require. Along the way, I did:
Break down my feature into two features. It was already like this conceptually. I was quite happy (and frustrated) when I see that my smaller feature installed without any problems
Double check the dependent plug-ins for each plug-in in my feature. Although I try to be quite careful while adding dependencies, I still found a few inconsistencies during this time. I do not know whether this was the main problem, but in any case, it is a good thing to do.
Finally, I realized that in my main feature, under the "Dependencies" tab, I have not selected "Recompute when feature plug-ins change" and the list of dependencies were empty! I highly believe that this was the main problem, but I do not have a proof. When you say "Compute" here, Eclipse automatically fills the list for you, so I really wonder why this is not a default process.
Hope it helps to other people.
FUDForum. Page generated in 0.11353 seconds
