Home » Eclipse Projects » Eclipse Scout » Target file problems(Can't find Rayo)
Target file problems [message #1123231] Wed, 02 October 2013 06:36 Go to next message
I wanted to update my current target file from the Kepler release to the current nightly build to do some tests. However, before I even managed to to make the changes to it, I ran into a problem, even though that target used to work flawlessly.
The lines:
<location includeAllPlatforms="false" includeConfigurePhase="true" includeMode="slicer" includeSource="true" type="InstallableUnit">
<unit id="com.bsiag.scout.rt.ui.swing.laf.rayo.feature.feature.group" version="0.0.0"/>
<repository location="http://tools.bsiag.com/marketplace/rayo"/>
</location>
break the resolution of the target, apparently that feature group is no longer available.
Disabling Rayo solved that problem for the time being. However, making the following change:
<unit id="org.eclipse.scout.rt.source.feature.group" version="0.0.0"/>
<unit id="org.eclipse.scout.rt.testing.source.feature.group" version="0.0.0"/>
<unit id="org.eclipse.rap.feature.feature.group" version="0.0.0"/>
<unit id="org.eclipse.scout.rt.rap.source.feature.group" version="0.0.0"/>
<repository location="http://download.eclipse.org/releases/kepler"/>
</location>
to
<repository location="http://download.eclipse.org/scout/nightly"/>
</location>
results in org.eclipse.rap.feature.feature.group not being locatable.
Have those features for some reason changed their names?
Re: Target file problems [message #1123248 is a reply to message #1123231] Wed, 02 October 2013 07:03 Go to previous messageGo to next message
For Rayo for Kepler, use this update site:
http://tools.bsiag.com/marketplace/rayo/3.9
In the update site:
you get all project participating in the release train with Kepler. This is why you find Scout and RAP (2 separate Eclipse projects).
However on our Scout (nightly) Update Site
you find only the Scout plugins. Meaning that you need to get Rap from another Update Site.
Be aware that we have 2 nightly (Luna and Kepler). They are mentioned on this wiki page: Scout Updatesites.
Check the Target Platform of the Demo Applications (for Kepler):
https://github.com/BSI-Business-Systems-Integration-AG/org.eclipsescout.demo/blob/3.9/build/org.eclipsescout.demo.target/s39_e43.target
You have similar files on the master branch for Luna.
I hope this helps.
[Updated on: Wed, 02 October 2013 07:14] by Moderator
Re: Target file problems [message #1123255 is a reply to message #1123248] Wed, 02 October 2013 07:15 Go to previous messageGo to next message
The rayo feature has the id com.bsiag.scout.rt.ui.swing.laf.rayo.feature.group since 3.9.
Re: Target file problems [message #1124061 is a reply to message #1123255] Thu, 03 October 2013 02:30 Go to previous message
Thanks Jeremy and Judith, using the combination of http://tools.bsiag.com/marketplace/rayo/3.9 and com.bsiag.scout.rt.ui.swing.laf.rayo.feature.group brought back rayo.
And thanks for explaining why I need a different update site for RAP. In hindsight, it should have been pretty obvious Smile Thanks also for the link to the update sites, that is useful to have around!
Previous Topic:Best practices for different client types?
Next Topic:AbstractSqlStyle returns different data types in the same column
Current Time: Fri Jul 25 10:24:32 EDT 2025
Powered by FUDForum. Page generated in 0.10767 seconds
