Home » Eclipse Projects » Eclipse 4 » Add a ShellListener
Add a ShellListener [message #1123100] Wed, 02 October 2013 03:42 Go to next message
I would like to add a Shell listener to my app (full E4), to be notified when the main shell is activated and deactivated.
When is the first/best moment when this is possible?
I have a class that is linked to the lifeCycleURI of my product, but its @PostContruct method is called before any shell is created.
An addon is called to early, too.
Obviously, the Activator is also called to early.
Can anybody help? Thanks! Smile
EDIT: to make thinks clearer: I used to have an WorkbenchWindowAdvisor, whose method postWindowCreate() was perfect for this job. Is there something similar in E4?
[Updated on: Wed, 02 October 2013 03:58] by Moderator
Re: Add a ShellListener [message #1123104 is a reply to message #1123100] Wed, 02 October 2013 03:46 Go to previous messageGo to next message
Listen to the UIEvents.UILifeCycle.APP_STARTUP_COMPLETE event
Re: Add a ShellListener [message #1123113 is a reply to message #1123104] Wed, 02 October 2013 03:58 Go to previous messageGo to next message
Ok I'll try that right away, thanks! Smile
Re: Add a ShellListener [message #1123137 is a reply to message #1123113] Wed, 02 October 2013 04:27 Go to previous message
It worked perfectly, thanks!
Previous Topic:Sash size and closed parts not persisted when added by a fragment
Next Topic:Calling Command from Code in Kepler (4.3)
Current Time: Sun Jul 27 21:46:25 EDT 2025
Powered by FUDForum. Page generated in 0.07128 seconds
