Application.launch() hangs [message #1123105] |
Wed, 02 October 2013 03:47  |
We are trying to make a proof of concept with an OSGi-bundle that launches a JavaFX Application when starting its Activator.
The code is very simple : In the Activator we make a "HelloWorld" object ( HelloWorld extends Application) and call a method to start it. Internally, this method calls Application.launch(). The code hangs at the moment that Application.launch() is called.
We used the preconfigured Eclipse (4.2.2) installation downloaded from (efxclipse.bestsolution.at/install.html#all-in-one) and the target platform from this website ( download.eclipse.org/efxclipse/runtime-nightly/site). We provided this option to OSGi: "-Dosgi.framework.extensions=org.eclipse.fx.osgi"
At this link (docs.google.com/a/motum.be/file/d/0B2aFUSe8nJC0YWVvYThGMGdwbG8/edit?usp=sharing), you can find the source code for this bundle (including the launch configuration) to reproduce this problem.
We are running OS-X (10.8.2) with JDK7_u40.
Thanks in advance for any help,
Filip
PS: Sorry, I had to omit "http://" from all my links, because a some forum constraint since I am relatively new to this forum.
Re: Application.launch() hangs [message #1124188 is a reply to message #1123105] |
Thu, 03 October 2013 05:11  |
Just for reference this was a problem of starting with PDE defaults! See
https://groups.google.com/forum/#!topic/efxclipse/zMlr-famQF0
Tom
On 02.10.13 19:29, FIlip Deleersnijder wrote:
> At this link
> Filip
FUDForum. Page generated in 0.04601 seconds
