Home » Modeling » ATL » [ATL /AM3 XML Extractor ]
[ATL /AM3 XML Extractor ] [message #1122211] Tue, 01 October 2013 06:36 Go to next message
I want to know if AM3 is available in kepler.
Thank you,
Re: [ATL /AM3 XML Extractor ] [message #1122350 is a reply to message #1122211] Tue, 01 October 2013 09:24 Go to previous messageGo to next message
No, AM3 plugins are not upgraded anymore.
If you want to use ANT Tasks for chaining ATL transformations, please directly use the ATL ANT Tasks (cf. the ATL User Guide - ATL Tools section).
Re: [ATL /AM3 XML Extractor ] [message #1122388 is a reply to message #1122350] Tue, 01 October 2013 10:12 Go to previous messageGo to next message
Thanks for your reponse.
I want to transforme my model UML + profile To file XML (conform of metamodel Xsd).
I work with Eclipse Kepler.
how to extract XML file?
That you have an example to extract XML file
Re: [ATL /AM3 XML Extractor ] [message #1122413 is a reply to message #1122388] Tue, 01 October 2013 10:46 Go to previous messageGo to next message
We have implemented an XML injector/extractor that can be called directly via the ATL ANT Tasks or API for instance.
To use it, you can download its sources from here and then build the plugin to be included in your Eclipse install (according to your Eclipse version, e.g., Kepler).
Re: [ATL /AM3 XML Extractor ] [message #1122440 is a reply to message #1122413] Tue, 01 October 2013 11:24 Go to previous messageGo to next message
I buil example Table2TabularHTML which contains XML Extractor.
and I replaced am3 by atl in Buil.xml
<project name="Table2TabularHTML" default="transfo">
<!-- Project properties -->
<property file="build.properties" />
<!-- Launches the transformations -->
<target name="transfo" depends="loadModels">
<atl.launch path="${transformations.dir}${source.metamodel.name}2${target.name}.asm">
<inModel name="${source.metamodel.name}" model="${source.metamodel.name}" />
<inModel name="IN" model="${source.model.file}" />
<inModel name="${target.metamodel.name}" model="${target.metamodel.name}" />
<library name="${source.metamodel.name}Helpers" path="${lib.dir}${source.metamodel.name}Helpers.asm" />
<outModel name="OUT" model="${target.model.file}" metamodel="${target.metamodel.name}" />
</atl.launch>
<!--am3.saveModel model="${target.model.file}" path="${models.dir}${target.model.file}" /-->
<atl.launch path="${transformations.dir}${target.metamodel.name}2${xml.metamodel.name}.asm">
<inModel name="IN" model="${target.model.file}" />
<inModel name="${xml.metamodel.name}" model="${xml.metamodel.name}" />
<outModel name="OUT" model="${xml.model.file}" metamodel="${xml.metamodel.name}" />
</atl.launch>
<atl.saveModel model="${xml.model.file}" path="${models.dir}${target.file}">
<extractor name="xml" />
</atl.saveModel>
</target>
<!-- Loads the metamodels and the source model -->
<target name="loadModels">
<atl.loadModel name="${source.metamodel.name}" metamodel="MOF" path="${metamodels.dir}${source.metamodel.name}.ecore" />
<atl.loadModel name="${target.metamodel.name}" metamodel="MOF" path="${metamodels.dir}${target.metamodel.name}.ecore" />
<atl.loadModel name="${xml.metamodel.name}" metamodel="MOF" path="${metamodels.dir}${xml.metamodel.name}.ecore" />
<atl.loadModel name="${source.model.file}" metamodel="${source.metamodel.name}" path="${models.dir}${source.model.file}" />
</target>
</project>
and i have this error:
[atl.saveModel] Saving model example-XML.ecore to file:/C:\Users\aidi\workspace_KeplerR_testAcccelo\Table2TabularHTML\models\example-TabularHTML.html
[atl.saveModel] org.eclipse.m2m.atl.core.ATLCoreException: org.eclipse.m2m.atl.core.extractor xml not found, check the spelling or register it manually
You know the cause of this error?
thanks
Re: [ATL /AM3 XML Extractor ] [message #1122444 is a reply to message #1122440] Tue, 01 October 2013 11:27 Go to previous messageGo to next message
Have you checked that the additional ATL Projectors plugin is correctly loaded into your Eclipse install?
It looks like this is not the case.
Re: [ATL /AM3 XML Extractor ] [message #1122455 is a reply to message #1122444] Tue, 01 October 2013 11:45 Go to previous messageGo to next message
I have loaded this plugins in my workspace:
org.eclipse.gmt.am3
org.eclipse.gmt.am3.core
org.eclipse.gmt.am3.extractor.launchers
org.eclipse.gmt.am3.modelhandler.emf
org.eclipse.gmt.am3.platform.core
org.eclipse.gmt.am3.platform.extension.am34eclipseplugins
org.eclipse.gmt.am3.platform.extension.am34linuxpackages
org.eclipse.gmt.am3.platform.extension.am3navigability
org.eclipse.gmt.am3.platform.extension.globalmodelmanagement
org.eclipse.gmt.am3.platform.extension.gmm4amw
org.eclipse.gmt.am3.platform.extension.gmm4asm
org.eclipse.gmt.am3.platform.extension.gmm4atl
org.eclipse.gmt.am3.platform.extension.gmm4compositetransformations
org.eclipse.gmt.am3.platform.extension.modelintent
org.eclipse.gmt.am3.platform.runtime.core
org.eclipse.gmt.am3.platform.ui
org.eclipse.gmt.am3.repository.lightweight
org.eclipse.m2m.atl.projectors.xml
lien:
/org.eclipse.mdt.modisco/incubation/trunk/am3/plugins/trunk
I have to add other plugings?
Re: [ATL /AM3 XML Extractor ] [message #1122464 is a reply to message #1122455] Tue, 01 October 2013 11:51 Go to previous messageGo to next message
You have to get only the plugin I sent you the link to: i.e., org.eclipse.m2m.atl.projectors.xml
It is a plugin to complement your ATL install with XML projection capabilities.
The other things you need are already included in ATL.
Re: [ATL /AM3 XML Extractor ] [message #1122474 is a reply to message #1122464] Tue, 01 October 2013 12:11 Go to previous messageGo to next message
Just with this pluging org.eclipse.m2m.atl.projectors.xml
I always have same error.
Re: [ATL /AM3 XML Extractor ] [message #1122648 is a reply to message #1122474] Tue, 01 October 2013 16:00 Go to previous messageGo to next message
Re: [ATL /AM3 XML Extractor ] [message #1123224 is a reply to message #1122648] Wed, 02 October 2013 06:26 Go to previous messageGo to next message
I am sure that the plugin is installed ,because I see him in the list of the installed plugins,
Same error:
[atl.saveModel] at org.eclipse.m2m.atl.core.service.CoreService.getExtractor(CoreService.java:272)
[atl.saveModel] at org.eclipse.m2m.atl.core.ant.tasks.SaveModelTask.execute(SaveModelTask.java:105)
[atl.saveModel] at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
[atl.saveModel] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[atl.saveModel] at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
[atl.saveModel] at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
[atl.saveModel] at java.lang.reflect.Method.invoke(Unknown Source)
[atl.saveModel] at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
[atl.saveModel] at org.apache.tools.ant.Task.perform(Task.java:348)
[atl.saveModel] at org.apache.tools.ant.Target.execute(Target.java:392)
[atl.saveModel] at org.apache.tools.ant.Target.performTasks(Target.java:413)
[atl.saveModel] at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
[atl.saveModel] at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
[atl.saveModel] at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
[atl.saveModel] at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:32)
[atl.saveModel] at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
[atl.saveModel] at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:672)
[atl.saveModel] at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:498)
[atl.saveModel] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
[atl.saveModel] at org.eclipse.ant.internal.launching.launchConfigurations.AntLaunchDelegate$1.run(AntLaunchDelegate.java:284)
[atl.saveModel] at java.lang.Thread.run(Unknown Source)
BUILD FAILED
But when I delete this instruction <extractor name="xml" /> , I do not have error.
Re: [ATL /AM3 XML Extractor ] [message #1123406 is a reply to message #1123224] Wed, 02 October 2013 10:30 Go to previous messageGo to next message
Have you tried to use the name "XML" instead of "xml"?
Both the injector and extractor are declared this way in the plugin.xml file of this plugin.
Re: [ATL /AM3 XML Extractor ] [message #1123431 is a reply to message #1123406] Wed, 02 October 2013 10:58 Go to previous messageGo to next message
Thank you for your reponse.
The solution of this problem is to replace XML by xml.
Re: [ATL /AM3 XML Extractor ] [message #1124476 is a reply to message #1123431] Thu, 03 October 2013 11:21 Go to previous messageGo to next message
Hi Hugo,
do you have an example which corresponds this transformation.
Thank you for your help.
Ouafae
Re: [ATL /AM3 XML Extractor ] [message #1124490 is a reply to message #1124476] Thu, 03 October 2013 11:39 Go to previous messageGo to next message
Basically, you have two different options here.
1) You write a specific UML-Profiled to XML transformation (according to the XSD you want to follow) and then you can use the XML extractor to obtain your actual XML document.
2) You use EMF to generate an Ecore (meta)model, let's name it XXX, out of your XSD and then you write the UML-Profiled to XXX transformation (thus using EMF to parameterize the serialization of your XXX model as an XML document corresponding to the initial XSD).
Re: [ATL /AM3 XML Extractor ] [message #1128370 is a reply to message #1124490] Mon, 07 October 2013 12:13 Go to previous messageGo to next message
in this example i use the second method (EMF to generate an Ecore (meta model).
ATL tranformation:
rule Block2MuseXML{
from museml: MMuml!Class(
thisModule.isBlockStereotyped(museml) and
museml.isMuseMLClassDefinitionStereotyped()
to OUT: MMXML!Composite (
name <- museml.name
I want to put the name of the classes stereotyped in name of the composite
and MMXML.ecore
<eClassifiers xsi:type="ecore:EClass" name="Composite" eSuperTypes="#//Muse">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="Composite"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="group2" unique="false"
upperBound="-1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EFeatureMapEntry">
<details key="kind" value="group"/>
<details key="name" value="group:18"/>
</eAnnotations>
</eStructuralFeatures>
but i have this error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Feature name does not exist on Composite
at __applyBlock2MuseXML#14(MuseML2XML.atl[47:7-47:26])
local variables: self=MuseML2XML : ASMModule, link=TransientLink {rule = Block2MuseXML, sourceElements = {museml = org.eclipse.uml2.uml.internal.impl.ClassImpl@12f44f2 (name: Block1, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false) (isActive: false)}, targetElements = {OUT = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@41eb8e (eClass: org.eclipse.emf.ecore.impl.EClassImpl@150dee9 (name: Composite) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}, museml=INuml!Block1, OUT=OUT!<unnamed>
at __exec__#8(MuseML2XML.atl)
Re: [ATL /AM3 XML Extractor ] [message #1827006 is a reply to message #1122413] Wed, 06 May 2020 02:00 Go to previous message
Hugo Bruneliere wrote on Tue, 01 October 2013 14:46
Hi Hugo,
I know this post is quite all but the link you provided is broken.
I would like to ask you if there any xml projector plugin I can add to the current ATL and Eclipse modelling tools.
Paul
Previous Topic:OWL2XML wrong output
Next Topic:UTF-8 encoding problem in output
Current Time: Sat Jul 26 19:22:06 EDT 2025
Powered by FUDForum. Page generated in 0.11300 seconds
