Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT "/dev/null" driver?(An SWT "implementation" that is "headless")
SWT "/dev/null" driver? [message #1114883] Mon, 23 September 2013 06:57 Go to next message
Hi all,
I was wondering if there exist some sort of "/dev/null" driver for SWT. What I have in mind is a build that links to a library which (instead of calling into GTK, or Cocoa, or whatever actual window system) builds state but "renders nothing". In other words, an in-memory tree of widgets (window, menus, tables, etc) is created with an empty event queue, but nothing really gets drawn on the screen?
I was hoping I would be able to use SWTbot in an actual headless mode (as in running the tests on a Linux which does not even have an X server installed, not just launching the tests from an automated script e.g. using Ant).
I'm not sure if this is even feasible, but I can't seem to find anything like it. I'm wondering if this is an inherently meaningless idea.
I understand that this beats the whole point of actually rendering the GUI for testing, but my actual use case is to be able to run code against the SWT API without an actual display. I can provide more info, but it's just a sad story of some badly designed code that mixes the data model with the view. Imagine having a Table widget which gets populated by some code that does some complex processing of external input (network or file) and needing to get fetch the text placed in each cell to use it in another calculation (without actually displaying anything, or even having an X server running).
Re: SWT "/dev/null" driver? [message #1122402 is a reply to message #1114883] Tue, 01 October 2013 10:30 Go to previous message
SWT's API and non-visual parts are for the most part living within each
of the toolkit implementations, there isn't a separation between these
and the toolkit-specific parts like there is in AWT ("peers"). So SWT
is not structured/able to do what you're asking.
Grant
On 9/23/2013 6:57 AM, Alex Mising name wrote:
> Hi all,
> using Ant).
Previous Topic:CheckboxTableViewer with more than 2 columns?
Next Topic:Flickering panels in SWT_AWT bridge solved!
Current Time: Wed Jul 23 05:32:30 EDT 2025
Powered by FUDForum. Page generated in 0.05104 seconds
