Home » Modeling » EMF » [CDO] NPE in CDOResourceImpl.basicSetResource(occurs in my CDO TED when exiting my RCP application)
[CDO] NPE in CDOResourceImpl.basicSetResource [message #1121603] Mon, 30 September 2013 16:05 Go to next message
Hi all,
I try to build a simple modeler example based an Graphiti with CDO as backend storage.
To achieve this, I followed some topics and the Dawn example.
I now have a CDO transactional editing domain (TED) which works fine until I quit my RCP application.
I then get a NullPointerException in CDOResourceImpl.basicSetResource because of CDOUtil.getViewSet(oldResourceSet) returning null in CDO code.
Adding a "dummy" adapter as follow solves the problem but I don't know why it happens.
@SuppressWarnings("restriction")
public class CDOTransactionalEditingDomainImpl extends TransactionalEditingDomainImpl {
	public static String CDO_TED_ID = "myappsmodeler.CDOEditingDomain";
	public CDOTransactionalEditingDomainImpl(AdapterFactory adapterFactory, TransactionalCommandStack stack, ResourceSet resourceSet) {
		super(adapterFactory, stack, resourceSet);
	protected TransactionChangeRecorder createChangeRecorder(ResourceSet rset)
		return new TransactionChangeRecorder(this, rset) {
			  public void notifyChanged(Notification notification)
			    if (!(notification.getOldValue() instanceof ResourceSet && notification.getNewValue() == null && notification
			        .getEventType() == Notification.SET))
			      if (!(notification instanceof CDODeltaNotification))
			        super.notifyChanged(notification);
	public static class CDOFactoryImpl extends FactoryImpl {
		public synchronized TransactionalEditingDomain createEditingDomain() {
			final ResourceSet resourceSet = new ResourceSetImpl();
			resourceSet.eAdapters().add(new InternalCDOViewSet() {
				// Dummy adapter used when exiting the modeler to avoid a NPE in CDOResourceImpl.basicSetResource
				// because of CDOUtil.getViewSet(oldResourceSet) returning null...
				public CDOView[] getViews() { return null; }
				public CDOResourceFactory getResourceFactory() { return null; }
				public org.eclipse.emf.ecore.EPackage.Registry getPackageRegistry() { return null; }
				public ResourceSet getResourceSet() { return null; }
				public EList<Adapter> eAdapters() { return null; }
				public boolean eDeliver() { return false; }
				public void eSetDeliver(boolean deliver) {}
				public void eNotify(Notification notification) {}
				public void notifyChanged(Notification notification) {}
				public Notifier getTarget() { return null; }
				public void setTarget(Notifier newTarget) {}
				public boolean isAdapterForType(Object type) { return false; }
				public void add(InternalCDOView view) {}
				public void remove(InternalCDOView view) {}
				public InternalCDOView resolveView(String repositoryUUID) { return null; }
				public <V> V executeWithoutNotificationHandling(Callable<V> callable) { return null; }
			final IWorkspaceCommandStack workspaceCommandStack = new GFWorkspaceCommandStackImpl(new DefaultOperationHistory());
			TransactionalEditingDomain result = new CDOTransactionalEditingDomainImpl(
				new ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Registry.INSTANCE),
				workspaceCommandStack, resourceSet);
			mapResourceSet(result);
			return result;
Could somebody tell me what's wrong ?
Kind regards,
Laurent
Re: [CDO] NPE in CDOResourceImpl.basicSetResource [message #1121982 is a reply to message #1121603] Tue, 01 October 2013 01:47 Go to previous messageGo to next message
Hi Laurent,
Some aspects of your problem are unclear to me:
1) Are you actually using Dawn or have you just been inspired by Dawn example code?
2) What's the stack trace of your NPE and what version of CDO are you using?
3) CDOTransactionalEditingDomainImpl and CDOFactoryImpl (the one below) are your own code?
Perhaps you can write a simple test case to demo your problem. Here are examples that use TransactionalEditingDomains:
Bugzilla_362270_Test.java - org.eclipse.emf.cdo.tests/src/org/eclipse/emf/cdo/tests/bugzilla (3 matches)
Bugzilla_362270c_Test.java - org.eclipse.emf.cdo.tests/src/org/eclipse/emf/cdo/tests/bugzilla (3 matches)
Bugzilla_417483_Test.java - org.eclipse.emf.cdo.tests/src/org/eclipse/emf/cdo/tests/bugzilla (7 matches)
If your test reveals a problem in CDO please submit a bugzilla and attach the test case and resulting stack traces to
it. Then I might be able to CC/assign some people who are more experienced with TransactionalEditingDomains.
Cheers
/Eike
http://www.esc-net.de
Am 30.09.2013 22:05, schrieb Laurent Le Moux:
> Hi all,
> @Override
> @Override
> notification
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> return result;
> Kind regards,
> Laurent
Re: [CDO] NPE in CDOResourceImpl.basicSetResource [message #1122048 is a reply to message #1121982] Tue, 01 October 2013 03:19 Go to previous messageGo to next message
Hello Eike,
Thanks for your quick answer.
My code is inspired by Dawn code and a few things I read in the forum.
I'm using CDO 4.2.0 and here's the stack trace :
!ENTRY org.eclipse.net4j.util 0 0 2013-10-01 09:11:58.408
!MESSAGE Problem while deactivating Transaction 1 [MAIN]
!STACK 0
	at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.basicSetResourceSet(CDOResourceImpl.java:1488)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$ResourcesEList.inverseRemove(ResourceSetImpl.java:604)
	at org.eclipse.emf.common.notify.impl.NotifyingListImpl.removeAll(NotifyingListImpl.java:945)
	at org.eclipse.emf.internal.cdo.view.CDOViewSetImpl.remove(CDOViewSetImpl.java:184)
	at org.eclipse.emf.internal.cdo.view.CDOViewImpl.doBeforeDeactivate(CDOViewImpl.java:1179)
	at org.eclipse.net4j.util.lifecycle.Lifecycle.internalDeactivate(Lifecycle.java:121)
	at org.eclipse.net4j.util.lifecycle.Lifecycle.deactivate(Lifecycle.java:167)
	at org.eclipse.net4j.util.lifecycle.LifecycleUtil.deactivate(LifecycleUtil.java:221)
	at org.eclipse.net4j.util.lifecycle.LifecycleUtil.deactivate(LifecycleUtil.java:211)
	at org.eclipse.net4j.util.lifecycle.LifecycleUtil.deactivate(LifecycleUtil.java:237)
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.close(AbstractCDOView.java:1526)
	at myappsmodeler.ApplicationWorkbenchAdvisor.postShutdown(ApplicationWorkbenchAdvisor.java:84)
	at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:2884)
	at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1108)
	at org.eclipse.ui.internal.Workbench.access$19(Workbench.java:1024)
	at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1327)
	at org.eclipse.ui.internal.Workbench.close(Workbench.java:1325)
	at org.eclipse.ui.internal.Workbench.close(Workbench.java:1298)
	at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:1227)
	at org.eclipse.ui.internal.WorkbenchWindow.access$14(WorkbenchWindow.java:1198)
	at org.eclipse.ui.internal.WorkbenchWindow$10.run(WorkbenchWindow.java:1261)
	at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1259)
	at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1271)
	at myappsmodeler.handlers.QuitHandler.execute(QuitHandler.java:14)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:285)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:504)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:555)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:376)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:322)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:84)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1056)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1081)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1108)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
	at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1525)
	at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4723)
	at org.eclipse.swt.widgets.Tree.WM_CHAR(Tree.java:6009)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4611)
	at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:6005)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4990)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2549)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at myappsmodeler.Application.start(Application.java:20)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
And yes, CDOTransactionalEditingDomainImpl and CDOFactoryImpl are my own code.
I'll have a look to your examples and see if I can write a simple test to reproduce my problem.
Re: [CDO] NPE in CDOResourceImpl.basicSetResource [message #1122120 is a reply to message #1122048] Tue, 01 October 2013 04:46 Go to previous messageGo to next message
Am 01.10.2013 09:19, schrieb Laurent Le Moux:
> Hello Eike,
> !STACK 0
The line number does no longer match the code. Can you update to 4.2 SR1, which we've published yesterday?
http://www.eclipse.org/cdo/downloads/
Cheers
/Eike
Re: [CDO] NPE in CDOResourceImpl.basicSetResource [message #1122160 is a reply to message #1122120] Tue, 01 October 2013 05:30 Go to previous messageGo to next message
Eike,
Here's a simple test reproducing the error.
After starting the example, simply quit. It should trigger the exception.
ApplicationWorkbenchAdvisor#preStartup opens a transaction, creates a resource and adds it to the TED.
ApplicationWorkbenchAdvisor#postShutdown closes the transaction which leads to the exception.
Re: [CDO] NPE in CDOResourceImpl.basicSetResource [message #1122194 is a reply to message #1122160] Tue, 01 October 2013 06:13 Go to previous messageGo to next message
Hi Laurent,
The cause of the problem is in your preStartup() method:
transaction = session.openTransaction();
// Access the resource once it's under CDO TED control
TransactionalEditingDomain editingDomain =
TransactionalEditingDomain.Registry.INSTANCE.getEditingDomain(CDOTransactionalEditingDomainImpl.CDO_TED_ID);
res = transaction.getOrCreateResource("TestCDOTED");
editingDomain.getResourceSet().getResources().add(res);
Which should be:
transaction = session.openTransaction(editingDomain.getResourceSet());
Cheers
/Eike
Am 01.10.2013 11:30, schrieb Laurent Le Moux:
> Eike,
Re: [CDO] NPE in CDOResourceImpl.basicSetResource [message #1122345 is a reply to message #1122194] Tue, 01 October 2013 09:19 Go to previous message
Hi Eike,
It indeed solves my problem...but I'm now facing another issue :
java.lang.IllegalStateException: Different object was registered for OID681
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerObject(AbstractCDOView.java:1324)
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:923)
	at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.getObject(CDOTransactionImpl.java:1150)
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.convertIDToObject(AbstractCDOView.java:1255)
	at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertIDToObject(CDOStoreImpl.java:691)
	at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertToEMF(CDOStoreImpl.java:659)
	at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.get(CDOStoreImpl.java:191)
	at org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreEList.delegateGet(EStoreEObjectImpl.java:241)
	at org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEList.java:230)
	at org.eclipse.emf.ecore.util.DelegatingEcoreEList.toArray(DelegatingEcoreEList.java:335)
This seems to be a known problem :
http://www.eclipse.org/forums/index.php/t/369768/
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399956
Unless you can suggest me a better solution, I'll stick to my "workaround" until the bug is adressed in 4.3.
Laurent
Previous Topic:[Teneo] DB Keywords not always escapes
Next Topic:EMF generating compile errors with enums
Current Time: Wed Jul 23 08:14:22 EDT 2025
Powered by FUDForum. Page generated in 0.07211 seconds
