Home » Modeling » TMF (Xtext) » Update Error for Xtext 4.2.3
Update Error for Xtext 4.2.3 [message #1104998] Mon, 09 September 2013 03:53 Go to next message
Hi all ,
I update my Xtext SDK 2.4.3
But I do not generate my grammar .I receive antrl error :can not find İnternalParser
Error is below :
Please use the ANTLR parser generator in version 2.1 or better
java.lang.IllegalStateException: Explicit encoding was set but is not supported by the available version of the AntlrToolRunner.
at org.eclipse.xtext.generator.parser.antlr.AntlrToolFacade.runWithEncodingAndParams(AntlrToolFacade.java:178)
at org.eclipse.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment.generate(XtextAntlrGeneratorFragment.java:47)
at org.eclipse.xtext.generator.CompositeGeneratorFragment.generate(CompositeGeneratorFragment.java:92)
at org.eclipse.xtext.generator.LanguageConfig.generate(LanguageConfig.java:113)
at org.eclipse.xtext.generator.Generator.generate(Generator.java:366)
at org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:132)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
13677 [main] ERROR enerator.CompositeGeneratorFragment - Explicit encoding was set but is not supported by the available version of the AntlrToolRunner.
Re: Update Error for Xtext 4.2.3 [message #1105779 is a reply to message #1104998] Tue, 10 September 2013 05:04 Go to previous messageGo to next message
Hey,
i had the same problem. just delete the org.antlr.runtime in your workspace and reload it while generating the xtext artifacts.
kind regards.
Re: Update Error for Xtext 4.2.3 [message #1105870 is a reply to message #1105779] Tue, 10 September 2013 07:33 Go to previous messageGo to next message
Hi Günther,
I solved this problem with create a new project all over now I do not have an problem but there is epsilon error but not effect me now .thanks for reply
org.eclipse.emf.common.util.WrappedException: java.lang.ClassNotFoundException: org.eclipse.epsilon.emc.emf.virtual.VirtualPackage cannot be found by org.eclipse.epsilon.emc.emf.virtual_1.1.0.201308291543
	at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor.getEPackage(RegistryReader.java:278)
	at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:127)
	at org.eclipse.epsilon.concordance.reporter.metamodel.EPackageRegistryCache.getEPackage(EPackageRegistryCache.java:121)
	at org.eclipse.epsilon.concordance.reporter.metamodel.EPackageRegistryCache.refreshCurrentRegistry(EPackageRegistryCache.java:114)
	at org.eclipse.epsilon.concordance.reporter.metamodel.EPackageRegistryCache.<init>(EPackageRegistryCache.java:37)
	at org.eclipse.epsilon.concordance.reporter.metamodel.MetamodelChangeReporter.<init>(MetamodelChangeReporter.java:25)
	at org.eclipse.epsilon.concordance.dt.ConcordancePlugin.<init>(ConcordancePlugin.java:28)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at java.lang.Class.newInstance0(Unknown Source)
	at java.lang.Class.newInstance(Unknown Source)
Günther Fiedler wrote on Tue, 10 September 2013 12:04
Hey,
kind regards.
Re: Update Error for Xtext 4.2.3 [message #1121368 is a reply to message #1104998] Mon, 30 September 2013 10:53 Go to previous messageGo to next message
Since Kepler SR1 is available I've the same problem with Tycho. Can anybody please help me?
[ERROR] 2391 [main] ERROR enerator.CompositeGeneratorFragment  - Explicit encoding was set but is not supported by the available version of the AntlrToolRunner.
[INFO] Please use the ANTLR parser generator in version 2.1 or better
[INFO] java.lang.IllegalStateException: Explicit encoding was set but is not supported by the available version of the AntlrToolRunner.
[ERROR] 	at org.eclipse.xtext.generator.parser.antlr.AntlrToolFacade.runWithEncodingAndParams(AntlrToolFacade.java:178)
[ERROR] 	at org.eclipse.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment.generate(XtextAntlrGeneratorFragment.java:47)
[ERROR] 	at org.eclipse.xtext.generator.CompositeGeneratorFragment.generate(CompositeGeneratorFragment.java:92)
[ERROR] 	at org.eclipse.xtext.generator.LanguageConfig.generate(LanguageConfig.java:113)
[ERROR] 	at org.eclipse.xtext.generator.Generator.generate(Generator.java:366)
[ERROR] 	at org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:132)
[ERROR] 	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
[ERROR] 	at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
[ERROR] 	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
[ERROR] 	at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
[ERROR] 	at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
[ERROR] 	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
[ERROR] 	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
[ERROR] 	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
[ERROR] 	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
[ERROR] 	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
[ERROR] 2486 [main] ERROR enerator.CompositeGeneratorFragment  - Explicit encoding was set but is not supported by the available version of the AntlrToolRunner.
[ERROR] 	at org.eclipse.xtext.generator.parser.antlr.XtextAntlrUiGeneratorFragment.generate(XtextAntlrUiGeneratorFragment.java:85)
[INFO] 2486 [main] INFO  text.generator.junit.Junit4Fragment  - generating Junit4 Test support classes
[INFO] 2501 [main] INFO  text.generator.junit.Junit4Fragment  - generating Compare Framework infrastructure
[INFO] 2595 [main] INFO  .emf.mwe2.runtime.workflow.Workflow  - Done.
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
Re: Update Error for Xtext 4.2.3 [message #1121372 is a reply to message #1121368] Mon, 30 September 2013 10:59 Go to previous messageGo to next message
hi,
did you try to use the newer version of antlr?
Re: Update Error for Xtext 4.2.3 [message #1121978 is a reply to message #1121372] Tue, 01 October 2013 01:44 Go to previous messageGo to next message
Hi Christian,
I use antlr 3.2.0 as prefered by itemis. Can you recommend a newer version?
Re: Update Error for Xtext 4.2.3 [message #1122103 is a reply to message #1121978] Tue, 01 October 2013 04:26 Go to previous messageGo to next message
for me it looks like during the update process,
in the existing projects something is setting back the "would you like to download ANTLR .." decision.
IMHO, we would need some way to reset this decision
so the next time we run the MWE2 for the *.XTEXT,
we will be prompted again to download ANTLR
Because I had only 5 simple experiments on XTEXT,
I solved it with a new workspace, new projects, ...
Re: Update Error for Xtext 4.2.3 [message #1122129 is a reply to message #1122103] Tue, 01 October 2013 04:57 Go to previous messageGo to next message
The downloaded file can be found in the project (if you did. Download it Once)
Re: Update Error for Xtext 4.2.3 [message #1122158 is a reply to message #1122129] Tue, 01 October 2013 05:27 Go to previous messageGo to next message
Hi Christian,
but after I applied the update, I got for my existing projects (which had a downloaded ANTLR3)
the above error and the recommendation
so something in the update process messed up my once-it-worked projects
Re: Update Error for Xtext 4.2.3 [message #1122170 is a reply to message #1122158] Tue, 01 October 2013 05:38 Go to previous messageGo to next message
as i said: i think the expectation is to delete the downloaded file and redownload it. it searches for a file with name .antlr-generator-3.2.0.jar in the project.
alternatively you can install the antlr from http://download.itemis.de/updates/ and add it to your target platform.
Re: Update Error for Xtext 4.2.3 [message #1122226 is a reply to message #1122170] Tue, 01 October 2013 06:48 Go to previous message
Hi Christian,
this is the solution I was looking for.
The jar is located directly in the project directory.
I was prompted for the download after re-running the MWE2.
Thanks for your help
Previous Topic:Customize the xtext editor itself
Next Topic:DSL file encoding
Current Time: Wed Jul 23 02:04:24 EDT 2025
Powered by FUDForum. Page generated in 0.05947 seconds
