Home » Archived » Jubula » Get current time
Get current time [message #1120961] Mon, 30 September 2013 01:57 Go to next message
Hi Guys,
Is there any way to get the current time in Jubula and store it in a variable ?
Appreciate your help
Bhupendra
Re: Get current time [message #1120992 is a reply to message #1120961] Mon, 30 September 2013 02:41 Go to previous messageGo to next message
You can use a function.
?now()
seems a perfect fit. See chapter 3.12.5 and 3.12.6 in the User Manual for details.
- Achim
Re: Get current time [message #1121254 is a reply to message #1120992] Mon, 30 September 2013 08:31 Go to previous messageGo to next message
Hi Achim,
Thanks for the reply, the function now() seems to be only having support for date viz. day, month and year
http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.jubula.client.ua.help%2Fhtml%2Fmanual%2Fnode128.html
Didn't got any example which will give time (hour/minutes/seconds), will you be able to add here; how to parse the time as well ??
Bhupendra
Re: Get current time [message #1121996 is a reply to message #1121254] Tue, 01 October 2013 02:09 Go to previous messageGo to next message
there's no function to do that right now - but you can add your own (the how to is written in the extension manual).
Alex
Re: Get current time [message #1122012 is a reply to message #1121996] Tue, 01 October 2013 02:30 Go to previous message
Well, just below the description of ?now() (in the link you posted) there is ?formatDate(). In the chapters I mentioned are several examples to work with various combinations of build-in functions. And if that doesn't fit your needs you can always add your own function (like Alex said).
- Achim
Previous Topic:Jubula failed to locate menu bar when executing test on Linux
Next Topic:Using stored values as Test Data of other TCs
Current Time: Fri Jul 18 06:18:01 EDT 2025
Powered by FUDForum. Page generated in 0.07603 seconds
