Home » Modeling » EMF » [CDO/Net4j] Sound check if TCPAcceptor could have been activated
[CDO/Net4j] Sound check if TCPAcceptor could have been activated [message #1063471] |
Thu, 13 June 2013 05:20  |
Hi @all,
For using CDO I create a simple server using the following (TCP) acceptor:
IAcceptor acceptor = (IAcceptor) container.getElement(
"org.eclipse.net4j.acceptors", "tcp",
"0.0.0.0");
// check if ok...
if (LifecycleUtil.isActive(acceptor)) { /* ... */ } // <--- not meaningful, continue reading
Of course, the whole process fails, if I try to start two servers. Then, I get the followign exception:
ERROR [TCPSelector]: Address already in use: bind
java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind(Native Method)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:124)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:59)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:52)
at org.eclipse.net4j.internal.tcp.TCPAcceptor.handleRegistration(TCPAcceptor.java:136)
at org.eclipse.net4j.internal.tcp.TCPSelector.executeRegistration(TCPSelector.java:389)
at org.eclipse.net4j.internal.tcp.TCPSelector.access$0(TCPSelector.java:380)
at org.eclipse.net4j.internal.tcp.TCPSelector$1.run(TCPSelector.java:71)
at org.eclipse.net4j.internal.tcp.TCPSelector.processOperations(TCPSelector.java:376)
at org.eclipse.net4j.internal.tcp.TCPSelector.run(TCPSelector.java:158)
at java.lang.Thread.run(Thread.java:662)
After this exception the acceptor will be deactivated (Net4j code)... asynchronously! Before this usually happens the acceptor is activated and seems to be fine (however, the server is obviously not running). This method is called on exception:
protected void deactivateAsync()
// Cancel the selection immediately
cancelSelectionKey();
// Do the rest of the deactivation asynchronously
getConfig().getReceiveExecutor().execute(new Runnable()
public void run()
deactivate();
My question: how can I process all this asynchronous stuff before I do other stuff assuming that the server start is fine? Or: how can I determine that the server is actually running (ignoring the fact that the binding could collapse at any time)? Please see the comment in the first code.
Thanks in advance!
Re: [CDO/Net4j] Sound check if TCPAcceptor could have been activated [message #1063753 is a reply to message #1063471] |
Fri, 14 June 2013 02:28   |
Am 13.06.2013 11:20, schrieb Kirsten M. Z.:
> Hi @all,
> "0.0.0.0");
> // check if ok...
Perhaps you should bind to different specific network addresses or different ports, e.g., 2036 and 2037.
> exception:
> public void run()
> deactivate();
> fine?
There's LifecycleUtil.waitForActive(Object, long) and LifecycleUtil.waitForInactive(Object, long).
The term "server" is a little vague, but I would define it as the "set of repositories and acceptors" in it. There's
LifecycleUtil.isActive(Object.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO/Net4j] Sound check if TCPAcceptor could have been activated [message #1121753 is a reply to message #1121442] |
Mon, 30 September 2013 19:41  |
> My own priority to work on this is probably not very high, as noone else has
> suffered from this problem during the last ten years and a workaround (check
> if the port is available before activating the acceptor) seems trivial.
Yes, for sure. Also using a delay is basically a workaround.
LifecycleUtil.waitForActive(acceptor, BASIC_TIME_OUT);
Thread.sleep(SOME_MS);
if (!LifecycleUtil.isActive(acceptor)) {
// ok, it failed, I got it...
However, I always have a bad feeling using something like that. After "waitForActive" I really expect that the acceptor is active, e.g., there is no "exception pending synchronously", which sets it inactive again. I think, this was your expectation (giving me the first answer) as well.
I will raise a bugzilla, and I will try to explain the problem. I cannot provide a real fix, because I think it is a general problem in asynchronous error handling, so maybe a architectural fix is needed? As a quick hack, just wait until it is performed, use a delay etc.
Current Time: Wed Jul 23 01:55:32 EDT 2025
Powered by FUDForum. Page generated in 0.08794 seconds
