Home » Modeling » EMF » [Teneo] DB Keywords not always escapes
[Teneo] DB Keywords not always escapes [message #1121208] |
Mon, 30 September 2013 07:35  |
Hi Martin,
I have stumbled accross an issue that I would like your opinion on. It is a case where a DB key word is used in an EReference as the name. (I have attached an eCore that shows this). In my example I use the keyword "order" as the name that will clash.
I have spent some time debugging into the code and spotted that in most cases when the name is set while generating the hibernate mapping file it will call "MappingContext.trunc()" on the name which at the end of the method has:
return this.escapeCharacter + getSqlNameStrategy().convert(useName, false) +
this.escapeCharacter;
However in the class AbstractAssociationMapper, the methods addManyToOne and addOneToOne only seem to do:
element = getHbmContext().getCurrent().addElement("one-to-one")
.addAttribute("name", assocName).addAttribute(
"entity-name", targetEntity);
When maybe it should do
.addAttribute("name", getHbmContext().trunc(assocName)).addAttribute(
And also in "OneToOneMapper.createOneToOne()" it has:
associationElement.addAttribute("property-ref", getHbmContext().getPropertyName(otherSide));
associationElement.addAttribute("property-ref", getHbmContext().trunc(getHbmContext().getPropertyName(otherSide)));
Does this sound OK to you?
Rob
Re: [Teneo] DB Keywords not always escapes [message #1121226 is a reply to message #1121208] |
Mon, 30 September 2013 07:52   |
Hi Rob,
The attributes you propose to trunc/escape are placed in the HBM file as hibernate properties, so for the hibernate
metadata itself. They do not directly describe the database schema. So I think your proposal won't work. I would expect
the manytoone to have a join column tag with an escaped name in it.
When does this lead to a problem, what exception do you see in what case?
gr. Martin
On 09/30/2013 01:35 PM, Rob Mising name wrote:
> Hi Martin,
> Thanks
> Rob
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] DB Keywords not always escapes [message #1121265 is a reply to message #1121208] |
Mon, 30 September 2013 08:45   |
Hi Martin,
Thanks for the fast reply. Without the changes detailed the attached eCore wil generate the following hibernate output:
<hibernate-mapping auto-import="false">
<class entity-name="BasicProduct" abstract="false" lazy="false" discriminator-value="com.example.umlrelationships.BasicProduct" table="`BDS_1_UMLRELTNSHPS_BASICPRODCT`">
<meta attribute="eclassName">BasicProduct</meta>
<meta attribute="epackage">http://example.com/umlrelationships</meta>
<id name="bdsId" type="java.lang.Long">
<column not-null="true" unique="false" name="`BDS_ID`"/>
<generator class="com.tibco.bds.core.ecore.IdGenerator"/>
</id>
<discriminator column="`DTYPE`" type="string"/>
<version name="bdsVersion" type="java.lang.Long">
<column not-null="false" unique="false" name="`BDS_VERSION`"/>
</version>
<property name="caseIdentifier1" lazy="false" insert="true" update="true" not-null="true" unique="true" type="java.lang.String" index="IDX_1_UMLRELTNSHPS_73F4C160892">
<column not-null="true" unique="true" name="`CASEIDENTIFIER1`" length="400" index="IDX_1_UMLRELTNSHPS_73F4C160892"/>
</property>
</class>
<class entity-name="Order" abstract="false" lazy="false" discriminator-value="com.example.umlrelationships.Order" table="`BDS_1_UMLRELTNSHPS_ORDER`">
<meta attribute="eclassName">Order</meta>
</id>
</version>
<property name="caseIdentifier1" lazy="false" insert="true" update="true" not-null="true" unique="true" type="java.lang.String" index="IDX_1_UMLRELTNSHPS_0812BB55C24">
<column not-null="true" unique="true" name="`CASEIDENTIFIER1`" length="400" index="IDX_1_UMLRELTNSHPS_0812BB55C24"/>
</property>
<one-to-one name="product" entity-name="Product" cascade="merge,persist,save-update,lock,refresh" lazy="false" property-ref="order"/>
</class>
<subclass entity-name="Product" abstract="false" lazy="false" extends="BasicProduct" discriminator-value="com.example.umlrelationships.Product">
<meta attribute="eclassName">Product</meta>
<many-to-one name="order" entity-name="Order" cascade="merge,persist,save-update,lock,refresh" not-null="false" lazy="false" insert="true" update="true"/>
</subclass>
</hibernate-mapping>
Which in turn will produce the following SQL:
create table [BDS_1_UMLRELTNSHPS_BASICPRODCT] ([BDS_ID] numeric(19,0) not null, [DTYPE] nvarchar(255) not null, [BDS_VERSION] numeric(19,0) null, [CASEIDENTIFIER1] nvarchar(400) not null unique, order numeric(19,0) null, primary key ([BDS_ID]));
create table [BDS_1_UMLRELTNSHPS_ORDER] ([BDS_ID] numeric(19,0) not null, [DTYPE] nvarchar(255) not null, [BDS_VERSION] numeric(19,0) null, [CASEIDENTIFIER1] nvarchar(400) not null unique, primary key ([BDS_ID]));
create index IDX_1_UMLRELTNSHPS_73F4C160892 on [BDS_1_UMLRELTNSHPS_BASICPRODCT] ([CASEIDENTIFIER1]);
alter table [BDS_1_UMLRELTNSHPS_BASICPRODCT] add constraint FK1B38D06AAE01E7C foreign key (order) references [BDS_1_UMLRELTNSHPS_ORDER];
create index IDX_1_UMLRELTNSHPS_0812BB55C24 on [BDS_1_UMLRELTNSHPS_ORDER] ([CASEIDENTIFIER1]);
If you look at the first row, it shows "order" which has not been escaped.
Then if you run this SQL script you get the error:
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Incorrect syntax near the keyword 'order'.
If I make the changes detailed the hibernate mapping will look as follows:
</id>
</version>
<property name="caseIdentifier1" lazy="false" insert="true" update="true" not-null="true" unique="true" type="java.lang.String" index="IDX_1_UMLRELTNSHPS_87CB702C46F">
<column not-null="true" unique="true" name="`CASEIDENTIFIER1`" length="400" index="IDX_1_UMLRELTNSHPS_87CB702C46F"/>
</property>
</class>
</id>
</version>
<property name="caseIdentifier1" lazy="false" insert="true" update="true" not-null="true" unique="true" type="java.lang.String" index="IDX_1_UMLRELTNSHPS_8F1FC523670">
<column not-null="true" unique="true" name="`CASEIDENTIFIER1`" length="400" index="IDX_1_UMLRELTNSHPS_8F1FC523670"/>
</property>
<one-to-one name="`PRODUCT`" entity-name="Product" cascade="merge,persist,save-update,lock,refresh" lazy="false" property-ref="`ORDER`"/>
</class>
<many-to-one name="`ORDER`" entity-name="Order" cascade="merge,persist,save-update,lock,refresh" not-null="false" lazy="false" insert="true" update="true"/>
</subclass>
create table [BDS_1_UMLRELTNSHPS_BASICPRODCT] ([BDS_ID] numeric(19,0) not null, [DTYPE] nvarchar(255) not null, [BDS_VERSION] numeric(19,0) null, [CASEIDENTIFIER1] nvarchar(400) not null unique, [ORDER] numeric(19,0) null, primary key ([BDS_ID]));
create index IDX_1_UMLRELTNSHPS_87CB702C46F on [BDS_1_UMLRELTNSHPS_BASICPRODCT] ([CASEIDENTIFIER1]);
alter table [BDS_1_UMLRELTNSHPS_BASICPRODCT] add constraint FK1B38D06A90E265C foreign key ([ORDER]) references [BDS_1_UMLRELTNSHPS_ORDER];
create index IDX_1_UMLRELTNSHPS_8F1FC523670 on [BDS_1_UMLRELTNSHPS_ORDER] ([CASEIDENTIFIER1]);
Which now runs OK, as the Order has been escaped as expected.
I hope this helps, it is very possible that I have added the fix in the incorrect location, and there is a better location to add this.
Thanks, Rob
Re: [Teneo] DB Keywords not always escapes [message #1121422 is a reply to message #1121208] |
Mon, 30 September 2013 11:58   |
Hi Martin,
More research, and a bit better hibernate on my part!
I believe the current line that is generate in the hibernate mapping file:
Needs to actually be:
<many-to-one name="order" entity-name="Order" cascade="merge,persist,save-update,lock,refresh" not-null="false" lazy="false" insert="true" update="true" column="`ORDER`"/>
(So the column=... part)
But I have to say, I'm not quite sure where this would need to be added in the Teneo code - I have tried a few places - but all my solutions are a little hacky - also, I guess we need to pay attention to some naming annotations at this point?
Any ideas?
Thanks for your assistance and patience!
Re: [Teneo] DB Keywords not always escapes [message #1121474 is a reply to message #1121422] |
Mon, 30 September 2013 13:05   |
Hi Rob,
Thanks for your patience :-)! Have you tried to add a @JoinColumn annotation to force a specific column name or let
Teneo escape it?
gr. Martin
On 09/30/2013 05:58 PM, Rob Mising name wrote:
> Hi Martin,
> Any ideas?
The Netherlands
Re: [Teneo] DB Keywords not always escapes [message #1122114 is a reply to message #1121474] |
Tue, 01 October 2013 04:41   |
Martin Taal wrote on Mon, 30 September 2013 18:05
Have you tried to add a @JoinColumn annotation to force a specific column name or let Teneo escape it?
Thanks Martin, I think you may have discovered a much better work around!
1) Without any annotation
2) With: @Column(name="ORDER")
3) With: @JoinColumn(name="ORDER")
<many-to-one name="order" entity-name="Order" cascade="merge,persist,save-update,lock,refresh" not-null="false" lazy="false" insert="true" update="true">
<column not-null="false" unique="false" name="`ORDER`"/>
</many-to-one>
So it looks like @JoinColumn will work for me! So it's now just the case where there is no annotation to set the name where it is missing the escaped column name.
Thank, Rob
Re: [Teneo] DB Keywords not always escapes [message #1122217 is a reply to message #1122114] |
Tue, 01 October 2013 06:35   |
Hi Rob,
Okay good! What I find strange though is that the column tag is not created by default. Afaik Teneo should generate also
all the db schema tags (so no need to set a JoinColumn annotation explicitly). Which version of Teneo are you using?
gr. Martin
> </many-to-one>
> Thank, Rob
The Netherlands
Current Time: Sat Jul 26 21:02:44 EDT 2025
Powered by FUDForum. Page generated in 0.05670 seconds
