Home » Archived » Test and Performance Tools Platform (TPTP) » Eclipse -TPTP Error
Eclipse -TPTP Error [message #112136] |
Mon, 10 September 2007 09:29  |
Hi All,
I have installed Eclipse 3.3 with TPTP 4.4 plugins on Windows platform
and the Auto GUI Recorder plugins 4.4.0.1 versions
I have created the Test container as mentioned in the Eclipse TPTP.
I have recorded a few scenarios and then want to run them together in
standard mode of execution which will generate a log file .
The Standard mode of execution involves three stages :
1. Creation of a location file
2.Creation of an artifact file
3. Creation of a Deployment file.
I have followed all the steps but when I launch the test container with
the new configuration and then select the test suit created and the
Deployment file and then click on the Apply Button
The progress of the execution starts and then after a while it stops at 36%
Also a message appears as Preparing and Deploying
After sometime it fails with a message as :
org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
IWAT4039E The Test Execution Harness reported the following
problems:org.eclipse.hyades.internal.execution.local.control .InactiveProcessException
java.lang.RuntimeException:
at
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.handleException(TestExecutionHarnessExecutorStub.j ava:347)
at
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:434)
at
org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2098)
at
org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$2(TestExecutionHarness.java:1830)
at
org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:750)
Caused by:
at
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:422)
.. 4 more
An exception stack trace is not available
Could you please assist me out in trouble shooting this issue.?
In Quick mode , we can select all the earlier recorded tests at a tretch
and then run them together but we dont have a method to verify the log
file as per my understanding.
Thanks & Regards,
Balakrishna.
Re: Eclipse -TPTP Error [message #112197 is a reply to message #112136] |
Tue, 11 September 2007 04:36   |
Hi Balakrishna,
you don't necessarily have to use deployment files.
If you want to use the recording instance of TPTP also as executing context:
- In the Launch Config dialog, select the default "local_deployment" option
- In the test suite's overview tab, checkmark "Use current workbench as
context"
If you want to use a different Eclipse installation on the same host as
execution context:
- Make sure the test candidate is "loaded" with TPTP capabilities.
One convenient way to achieve this is following:
- In the test candidate's eclipse folder, create a folder "links"
- In folder "links", create a file "tptp.link" (as an example)
- Edit file "tptp.link" to contain following line:
path=C:/path/to/tptp_installdir
After starting the test candidate, the Manage Configurations dialog
should show the TPTP plug-ins.
- In the test suite's overview tab:
- Uncheckmark "Use current workbench as context"
- As Eclipse Location specify the absolute path to the test
candidate's Equinox launcher plug-in, e.g.
C:\Eclipse3.3\eclipse\plugins\org.eclipse.equinox.launcher_1 .0.0.wr.jar
HTH,
Matthias
Balakrishna wrote:
> Hi All,
> Also a message appears as �Preparing and Deploying�
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by:
> at
> . 4 more
> and then run them together but we don�t have a method to verify the log
> Thanks & Regards,
> Balakrishna.
Re: Eclipse -TPTP Error [message #112750 is a reply to message #112197] |
Wed, 19 September 2007 09:22   |
Originally posted by: martina.varsanyi.hu
I've the same problem, that Balakrishna has, whenn I try to follow the
steps of
http://www.eclipse.org/tptp/test/documents/userguides/auto-g ui-viewlet/auto-gui-viewlet_viewlet_swf.html.
Since I'm very new to Eclipse TPTP, I'd like to see/know how it works, and
what I can use of it, and what it isn't necessary.
I see as a big problem, that - following this step-by-step instructions -
I'm not only unable afford the same result, but I get an error message.
Martina Varsanyi
Matthias Wiskow wrote:
> Hi Balakrishna,
> context"
> execution context:
> C:Eclipse3.3eclipsepluginsorg.eclipse.equinox.launcher_1.0.0 .wr.jar
> HTH,
> Matthias
Re: Eclipse -TPTP Error [message #112854 is a reply to message #112750] |
Thu, 20 September 2007 02:48   |
Hi Martina,
if you expect help, please provide more details:
- Which step-by-step instructions do you mean? Those I gave in my
previous post or those of the viewlet?
- Which steps did you take?
- Which result do you get?
- Which error message do you get?
Matthias
> steps of
> and what I can use of it, and what it isn't necessary.
> - I'm not only unable afford the same result, but I get an error message.
> Best regards,
> Martina Varsanyi
>> Hi Balakrishna,
>> context:
>> option
>> as context"
>> as execution context:
>> dialog should show the TPTP plug-ins.
>> option
>> HTH,
>> Matthias
Re: Eclipse -TPTP Error [message #112879 is a reply to message #112854] |
Thu, 20 September 2007 06:20   |
Hi Matthias,
my answers are after your questions,
I also made a small flash, to show what I do.
http://howtos.varsanyi.hu/eclipse_tptp/
thanks for your time,
Martina
> Hi Martina,
Those in viewlet.
I also tried this:
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html
since yesterday.
I came to frame 99 at the viewlet. I got the same result, when I try to do
2.2.3 in
(I tried both example in a separate workspace)
Try to run my TPTP test suite standalone, compiling runs until 36%, than
breaks down.
> Best regards,
> Matthias
>> steps of
>> Best regards,
>> Martina Varsanyi
>>> Hi Balakrishna,
>>> context:
>>> option
>>> as context"
>>> option
>>> HTH,
>>> Matthias
Re: Eclipse -TPTP Error [message #112919 is a reply to message #112879] |
Thu, 20 September 2007 09:13   |
Hi Martina,
thanks for the flash and the information.
I reproduced your steps on my Win XP host in a fresh workspace. For me
it works well.
Flash shows as problem of the first launch the error "Connection refused
on host localhost".
AFAIK this indicates a problem with the Agent Controller (AC) or with
the ports AC uses.
The same problem may be true for the second launch, despite of the
different error message.
Are you using integrated AC or standalone AC?
If you are using standalone AC, did you run SetConfig.bat?
Are ports 10002, 10003, 10005 blocked somehow (e.g. firewall)?
HTH,
Matthias
> Hi Matthias,
> Martina
>> Hi Martina,
> Those in viewlet.
> I also tried this:
> since yesterday.
> do 2.2.3 in
> breaks down.
>> Best regards,
>> Matthias
>>> the steps of
>>> works, and what I can use of it, and what it isn't necessary.
>>> instructions - I'm not only unable afford the same result, but I get
>>> an error message.
>>> Best regards,
>>> Martina Varsanyi
>>>> Hi Balakrishna,
>>>> context:
>>>> option
>>>> as context"
>>>> option
>>>> HTH,
>>>> Matthias
Re: Eclipse -TPTP Error [message #113606 is a reply to message #112750] |
Mon, 01 October 2007 07:09   |
Hi Martina,
Are you running Java 6? If so, you may be affected by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=199237. If not, please open a
defect:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20T esting
Component: Test.Execution.AutoGUIRunner
Paul
"Martina Varsanyi" <martina@varsanyi.hu> wrote in message
news:af61628b5e7705abec8dbf184a6323df$1@www.eclipse.org...
> steps of
> Best regards,
> Martina Varsanyi
>> Hi Balakrishna,
>> context:
>> option
>> context"
>> execution context:
>> option
>> HTH,
>> Matthias
Re: Eclipse -TPTP Error [message #114280 is a reply to message #112919] |
Fri, 05 October 2007 07:46   |
Originally posted by: chris.varsanyi.hu
Hi Matthias,
sorry for the late answer, I has some issues with my notebook :(
I use a standalone AC, running as a service. I did run setConfig.bat. I
don't use any firewall on the PC (of course we are sitting behind a
firewall).
Martina
> Hi Martina,
> it works well.
> on host localhost".
> the ports AC uses.
> HTH,
> Matthias
Current Time: Sat Jul 26 18:07:10 EDT 2025
Powered by FUDForum. Page generated in 0.04987 seconds
