Home » Modeling » ATL » Inject operation in ATL 3.0
Inject operation in ATL 3.0 [message #1120783] Sun, 29 September 2013 21:12 Go to next message
I'm trying to write a HOT transformation for transforming a weaving model into ATL. I want to use "inject" operation in ATL 3.0 (as I saw some examples in ATL 2.0 ) but I'm getting error that the "operation not found" . Does anybody know if inject is supported in ATL 3.0 or not?
BTW I'm using inject for creating the filters for source('from') sections of matched rules and also for creating helpers in the result ATL file.
I really appreciate if you can help me with your advice.
Azadeh
Re: Inject operation in ATL 3.0 [message #1122371 is a reply to message #1120783] Tue, 01 October 2013 09:50 Go to previous messageGo to next message
You can inject an ATL file as an ATL model by using ATL ANT Tasks and the provided ATL injector (cf. ATL User Guide - ATL Tools section for seeing an example).
It is also possible to use the same injector programmatically via the ATL API (cf. corresponding section onto the ATL documentation).
Re: Inject operation in ATL 3.0 [message #1124937 is a reply to message #1122371] Thu, 03 October 2013 22:38 Go to previous messageGo to next message
Thanks Hugo for your reply
But I'm not sure if we are talking about same inject operation. The inject operation I'm trying to use e.g. for adding helpers in my HOT is like :
currentHelper <- 'helper context P1Profile!Element def: isStereotypeApplied(name : String) : Boolean = not self.getAppliedStereotypes()->select(p | p.name=name).isEmpty();'.inject('OUT', 'ebnf2', 'ATL-helper');
currentHelper.module <- thisModule.resolveTemp(AMW!Model.allInstancesFrom('IN').first(), 'atl');
This inject operation in supported in ATL 2.0 but in ATL 3.0 I'm getting error!
thanks,
Azadeh
Re: Inject operation in ATL 3.0 [message #1125396 is a reply to message #1124937] Fri, 04 October 2013 09:11 Go to previous message
Unfortunately, this specific operation/construct is not maintained anymore in ATL 3.x version.
Previous Topic:Organizing logical combination of boolean expressions in a HOT
Next Topic:resolveTemp crashes the ATL module
Current Time: Sat Jul 26 16:59:58 EDT 2025
Powered by FUDForum. Page generated in 0.07288 seconds
