Background-Process / runNonUIThreadWithFakeContext [message #112060] |
Tue, 11 November 2008 05:38  |
I try to implement a Runnable, which need to interact with the GUI. In
other Messages i have allready read about the problems to start Threads
which want to interact with the session-based components. To handle this,
i use UICallBack#runNonUIThreadWithFakeContext(display, runnable). But now
i have the problem that i can not longer interact with the GUI, if my
process is running (My process is a Listener with an endless while-Loop).
My Question is, are there other possibilities to uses Threads in RAP, Or
is my solution wrong?
PS: with Job it is the self Problem like with Runnable.
Re: Background-Process / runNonUIThreadWithFakeContext [message #112252 is a reply to message #112204] |
Wed, 12 November 2008 05:03   |
Hello Rüdiger,
no, with Display#asyncExec the GUI doesn't even load. I just see the
Background from RAP with the blue stripe at the Top.
I add some Code snippets:
public class WorkbenchWindowAdvisorImpl extends WorkbenchWindowAdvisor {
public void postWindowOpen() {
final Shell shell = getWindowConfigurer().getWindow().getShell();
Runnable runnable = new Runnable(){
public void run(){
while(true){
if(Event.waitFor()){
MessageDialog.openInformation(shell,"Titel","Message");
shell.getDisplay().asyncExec(runnable);
Mfg Oliver
Rüdiger Herrmann wrote:
> Oliver,
> to interact with the UI (i.e. run code on the UI thread) you can use
> Display#asyncExec/syncExec. Is it that what you were looking for?
> HTH
> Rüdiger
> Oliver Koch wrote:
>> Hi,
>> this, i use UICallBack#runNonUIThreadWithFakeContext(display, runnable).
>> But now i have the problem that i can not longer interact with the GUI,
>> if my process is running (My process is a Listener with an endless
>> while-Loop). My Question is, are there other possibilities to uses
>> Threads in RAP, Or is my solution wrong?
Re: Background-Process / runNonUIThreadWithFakeContext [message #112290 is a reply to message #112252] |
Wed, 12 November 2008 09:16   |
Ok...i found the problem...
I use a CallableStatment from the Oracle JDBC-Driver in the loop. If i
start the thread with #asyncExec(), the Instanc Methode #execute() needs
2-3 Minutes to get through. But without #asyncExec(), it just need <1
Second. (??????) I don't understand this behavior.
Mfg
Oliver
Oliver Koch wrote:
> Hello Rüdiger,
> public void run(){
> while(true){
> Mfg Oliver
>> Oliver,
>> HTH
>> Rüdiger
>> Oliver Koch wrote:
>>> Hi,
FUDForum. Page generated in 1.03903 seconds
