Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Database ends up with group when it is 1:m not n:m associations
Database ends up with group when it is 1:m not n:m associations [message #111921] Fri, 08 February 2008 12:56 Go to next message
The schema I am using has a particular approach to minimise the size of
XML messages.
Here is a small excerpt
<xsd:complexType name="InstrumentDomain">
<xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="1" ref="mddl:when" />
<xsd:choice minOccurs="0" maxOccurs="unbounded">
<xsd:choice minOccurs="1" maxOccurs="1">
<xsd:element ref="mddl:agencyRankings" />
</xsd:choice>
<xsd:element ref="mddl:agencyRatings" />
</xsd:choice>
etc.
I end up with
PKTABLE_NAME PKCOLUMN_NAME FKTABLE_NAME FKCOLUMN_NAME
agencyratings id instrumentdomain_group group_agencyratings
in the database generated.
The real world model here is that instrumentDomain has a 1:1
relationship with agencyRankings and agencyRatings. Is the generation
of a group table and the inclusion of these entities due to the fact
they used a xsd:sequence with xsd:choice inside it? I assume the
maxOccurs="1" are not being taken into account.
Is there a way of changing the generated output to accommodate these
maxOccur"1" within the xsd:choice? Or is the XSD model structure going
to force the creation of the n:m group?
Thx,
David
Re: Database ends up with group when it is 1:m not n:m associations [message #112006 is a reply to message #111921] Fri, 08 February 2008 14:31 Go to previous messageGo to next message
Hi David,
The group is created because of the <xsd:choice minOccurs="0" maxOccurs="unbounded">. Because of
unbounded (actually anything above 1) it means that on the java side it is modeled with a list and
in the database with a table.
If I understand your correctly then the model could also be described as such:
<xsd:sequence>
<xsd:element ref="mddl:agencyRankings" minOccurs="0" maxOccurs="1"/>
<xsd:element ref="mddl:agencyRatings" minOccurs="0" maxOccurs="1"/>
the only difference is that the order of the agencyRankings and agencyRatings is not flexible (if
they would occur at the same time).
This simpler xsd would result in a database model without the group table. Also emf will generate a
simpler class model.
btw, for my curiosity why have the choice with minOccurs="1" maxOccurs="1" around the agencyRankings
and agencyRatings elements?
gr. Martin
david wrote:
> XML messages.
> <xsd:sequence>
> </xsd:choice>
> </xsd:choice>
> etc.
> I end up with
> Thx,
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Database ends up with group when it is 1:m not n:m associations [message #112105 is a reply to message #112006] Mon, 11 February 2008 05:54 Go to previous messageGo to next message
I am not sure why the working group that developed this standard XSD
have a lot of the 1:n associations, also why they use 1:1 for many of
these associations too, I am trying to find out. I am also altering them
to be more straightforward associations instead of the unusual
constructs they have used.
Another thing I noticed is that even with
props.setProperty(PersistenceOptions.ALWAYS_VERSION, "false");
I am getting e_version columns generated on some tables.
David
Martin Taal wrote:
> Hi David,
> maxOccurs="unbounded">. Because of unbounded (actually anything above 1)
> it means that on the java side it is modeled with a list and in the
> such:
> <xsd:sequence>
> agencyRatings is not flexible (if they would occur at the same time).
> table. Also emf will generate a simpler class model.
> maxOccurs="1" around the agencyRankings and agencyRatings elements?
> gr. Martin
> david wrote:
>> Hi,
>> of XML messages.
>> <xsd:sequence>
>> </xsd:choice>
>> </xsd:choice>
>> etc.
>> I end up with
>> Thx,
>> David
Re: Database ends up with group when it is 1:m not n:m associations [message #112148 is a reply to message #112105] Mon, 11 February 2008 07:00 Go to previous messageGo to next message
Hi David,
On which table/type are they still added? Then I can repair that.
gr. Martin
david wrote:
> Regards,
> David
> Martin Taal wrote:
>> Hi David,
>> 1) it means that on the java side it is modeled with a list and in the
>> as such:
>> <xsd:sequence>
>> maxOccurs="1"/>
>> maxOccurs="1"/>
>> gr. Martin
>> david wrote:
>>> Hi,
>>> of XML messages.
>>> <xsd:sequence>
>>> </xsd:choice>
>>> </xsd:choice>
>>> etc.
>>> I end up with
>>> generation of a group table and the inclusion of these entities due
>>> to the fact they used a xsd:sequence with xsd:choice inside it? I
>>> assume the maxOccurs="1" are not being taken into account.
>>> going to force the creation of the n:m group?
>>> Thx,
>>> David
The Netherlands
Re: Database ends up with group when it is 1:m not n:m associations [message #112161 is a reply to message #112148] Mon, 11 February 2008 10:14 Go to previous messageGo to next message
Martin,
All *children named entities have the e_version.
David
Martin Taal wrote:
> Hi David,
> gr. Martin
> david wrote:
>> Hi,
>> them to be more straightforward associations instead of the unusual
>> Regards,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> as such:
>>> <xsd:sequence>
>>> maxOccurs="1"/>
>>> maxOccurs="1"/>
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> of XML messages.
>>>> <xsd:sequence>
>>>> </xsd:choice>
>>>> </xsd:choice>
>>>> etc.
>>>> I end up with
>>>> Thx,
>>>> David
Re: Database ends up with group when it is 1:m not n:m associations [message #112174 is a reply to message #112161] Mon, 11 February 2008 10:34 Go to previous messageGo to next message
Martin,
Also all *_group entities have a e_version column added.
David
david wrote:
> Martin,
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Regards,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> and in the database with a table.
>>>> described as such:
>>>> <xsd:sequence>
>>>> maxOccurs="1"/>
>>>> maxOccurs="1"/>
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> size of XML messages.
>>>>> <xsd:sequence>
>>>>> </xsd:choice>
>>>>> </xsd:choice>
>>>>> etc.
>>>>> I end up with
>>>>> these maxOccur"1" within the xsd:choice? Or is the XSD model
>>>>> structure going to force the creation of the n:m group?
>>>>> Thx,
>>>>> David
Re: Database ends up with group when it is 1:m not n:m associations [message #112187 is a reply to message #112174] Mon, 11 February 2008 10:37 Go to previous messageGo to next message
Hi David,
Ok, I know where to look then. I'll solve this in the next build.
gr. Martin
david wrote:
> Martin,
> David
> david wrote:
>> Martin,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> of these associations too, I am trying to find out. I am also
>>>> altering them to be more straightforward associations instead of the
>>>> unusual constructs they have used.
>>>> Regards,
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> described as such:
>>>>> <xsd:sequence>
>>>>> maxOccurs="1"/>
>>>>> maxOccurs="1"/>
>>>>> gr. Martin
>>>>> david wrote:
>>>>>> Hi,
>>>>>> <xsd:sequence>
>>>>>> </xsd:choice>
>>>>>> </xsd:choice>
>>>>>> etc.
>>>>>> I end up with
>>>>>> due to the fact they used a xsd:sequence with xsd:choice inside
>>>>>> it? I assume the maxOccurs="1" are not being taken into account.
>>>>>> Thx,
>>>>>> David
The Netherlands
Re: Database ends up with group when it is 1:m not n:m associations [message #112199 is a reply to message #112161] Mon, 11 February 2008 10:44 Go to previous messageGo to next message
Martin,
I am still not understanding the reason behind the n:m association
generation when it appears to me to require 1:n.
Say we have this
<xsd:complexType name="CashDomain">
<xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="1" ref="gensec:when" />
<xsd:element ref="gensec:instrumentIdentifier" />
</xsd:choice>
<xsd:element minOccurs="0" maxOccurs="1" ref="gensec:source" />
<xsd:element minOccurs="0" maxOccurs="1" ref="gensec:other" />
</xsd:sequence>
<xsd:attribute name="id" type="xsd:ID" use="optional" />
</xsd:complexType>
<xsd:element name="cashDomain" type="gensec:CashDomain" />
And the gensec:instrumentIdentifier looks like this
<xsd:complexType name="InstrumentIdentifier">
<xsd:sequence minOccurs="0" maxOccurs="1">
<xsd:group minOccurs="0" maxOccurs="unbounded"
ref="gensec:InstrumentIdentifier.children" />
<xsd:choice minOccurs="0" maxOccurs="1">
<xsd:element ref="gensec:source" />
</xsd:choice>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="instrumentIdentifier"
type="gensec:InstrumentIdentifier" />
This looks like to me there is a 1:n relationship between cashDomain and
instrumentIdentifier. But I end up with a n:m supported through a
table called cashdomain_group.
What can I do to the XSD to force a 1:n association in the database for
these?
David
david wrote:
> Martin,
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Regards,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> described as such:
>>>> <xsd:sequence>
>>>> maxOccurs="1"/>
>>>> maxOccurs="1"/>
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> <xsd:sequence>
>>>>> </xsd:choice>
>>>>> </xsd:choice>
>>>>> etc.
>>>>> I end up with
>>>>> Thx,
>>>>> David
Re: Database ends up with group when it is 1:m not n:m associations [message #112212 is a reply to message #112199] Mon, 11 February 2008 11:27 Go to previous message
David,
I think it is caused by the <xsd:choice minOccurs="0" maxOccurs="unbounded"> choice. Can you try
something like this:
<xsd:sequence>
<xsd:element ref="gensec:instrumentIdentifier" minOccurs="0" maxOccurs="unbounded"/>
</xsd:sequence>
</xsd:complexType>
btw, you can check if your change will result in a different mapping by looking at the generated
java code, it should not generate a group member in CashDomain (at least not if you want 1:n).
gr. Martin
david wrote:
> Martin,
> Say we have this
> <xsd:sequence>
> </xsd:choice>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:choice>
> </xsd:sequence>
> </xsd:complexType>
> instrumentIdentifier. But I end up with a n:m supported through a table
> these?
> David
> david wrote:
>> Martin,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> Regards,
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> described as such:
>>>>> <xsd:sequence>
>>>>> maxOccurs="1"/>
>>>>> maxOccurs="1"/>
>>>>> gr. Martin
>>>>> david wrote:
>>>>>> Hi,
>>>>>> <xsd:sequence>
>>>>>> </xsd:choice>
>>>>>> </xsd:choice>
>>>>>> etc.
>>>>>> I end up with
>>>>>> Thx,
>>>>>> David
The Netherlands
Re: Database ends up with group when it is 1:m not n:m associations [message #615472 is a reply to message #111921] Fri, 08 February 2008 14:31 Go to previous message
Hi David,
<xsd:sequence>
gr. Martin
david wrote:
> XML messages.
> <xsd:sequence>
> </xsd:choice>
> </xsd:choice>
> etc.
> I end up with
> Thx,
> David
The Netherlands
Re: Database ends up with group when it is 1:m not n:m associations [message #615478 is a reply to message #112006] Mon, 11 February 2008 05:54 Go to previous message
David
Martin Taal wrote:
> Hi David,
> such:
> <xsd:sequence>
> gr. Martin
> david wrote:
>> Hi,
>> of XML messages.
>> <xsd:sequence>
>> </xsd:choice>
>> </xsd:choice>
>> etc.
>> I end up with
>> Thx,
>> David
Re: Database ends up with group when it is 1:m not n:m associations [message #615482 is a reply to message #112105] Mon, 11 February 2008 07:00 Go to previous message
Hi David,
gr. Martin
david wrote:
> Regards,
> David
> Martin Taal wrote:
>> Hi David,
>> as such:
>> <xsd:sequence>
>> maxOccurs="1"/>
>> maxOccurs="1"/>
>> gr. Martin
>> david wrote:
>>> Hi,
>>> of XML messages.
>>> <xsd:sequence>
>>> </xsd:choice>
>>> </xsd:choice>
>>> etc.
>>> I end up with
>>> Thx,
>>> David
The Netherlands
Re: Database ends up with group when it is 1:m not n:m associations [message #615483 is a reply to message #112148] Mon, 11 February 2008 10:14 Go to previous message
Martin,
David
Martin Taal wrote:
> Hi David,
> gr. Martin
> david wrote:
>> Hi,
>> Regards,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> as such:
>>> <xsd:sequence>
>>> maxOccurs="1"/>
>>> maxOccurs="1"/>
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> of XML messages.
>>>> <xsd:sequence>
>>>> </xsd:choice>
>>>> </xsd:choice>
>>>> etc.
>>>> I end up with
>>>> Thx,
>>>> David
Re: Database ends up with group when it is 1:m not n:m associations [message #615484 is a reply to message #112161] Mon, 11 February 2008 10:34 Go to previous message
Martin,
David
david wrote:
> Martin,
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Regards,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> described as such:
>>>> <xsd:sequence>
>>>> maxOccurs="1"/>
>>>> maxOccurs="1"/>
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> <xsd:sequence>
>>>>> </xsd:choice>
>>>>> </xsd:choice>
>>>>> etc.
>>>>> I end up with
>>>>> Thx,
>>>>> David
Re: Database ends up with group when it is 1:m not n:m associations [message #615485 is a reply to message #112174] Mon, 11 February 2008 10:37 Go to previous message
Hi David,
gr. Martin
david wrote:
> Martin,
> David
> david wrote:
>> Martin,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> Regards,
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> described as such:
>>>>> <xsd:sequence>
>>>>> maxOccurs="1"/>
>>>>> maxOccurs="1"/>
>>>>> gr. Martin
>>>>> david wrote:
>>>>>> Hi,
>>>>>> <xsd:sequence>
>>>>>> </xsd:choice>
>>>>>> </xsd:choice>
>>>>>> etc.
>>>>>> I end up with
>>>>>> Thx,
>>>>>> David
The Netherlands
Re: Database ends up with group when it is 1:m not n:m associations [message #615486 is a reply to message #112161] Mon, 11 February 2008 10:44 Go to previous message
Martin,
Say we have this
<xsd:sequence>
</xsd:choice>
</xsd:sequence>
</xsd:complexType>
</xsd:choice>
</xsd:sequence>
</xsd:complexType>
these?
David
david wrote:
> Martin,
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Regards,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> described as such:
>>>> <xsd:sequence>
>>>> maxOccurs="1"/>
>>>> maxOccurs="1"/>
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> <xsd:sequence>
>>>>> </xsd:choice>
>>>>> </xsd:choice>
>>>>> etc.
>>>>> I end up with
>>>>> Thx,
>>>>> David
Re: Database ends up with group when it is 1:m not n:m associations [message #615487 is a reply to message #112199] Mon, 11 February 2008 11:27 Go to previous message
David,
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
gr. Martin
david wrote:
> Martin,
> Say we have this
> <xsd:sequence>
> </xsd:choice>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:choice>
> </xsd:sequence>
> </xsd:complexType>
> these?
> David
> david wrote:
>> Martin,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> Regards,
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> described as such:
>>>>> <xsd:sequence>
>>>>> maxOccurs="1"/>
>>>>> maxOccurs="1"/>
>>>>> gr. Martin
>>>>> david wrote:
>>>>>> Hi,
>>>>>> <xsd:sequence>
>>>>>> </xsd:choice>
>>>>>> </xsd:choice>
>>>>>> etc.
>>>>>> I end up with
>>>>>> Thx,
>>>>>> David
The Netherlands
Previous Topic:ECF and CDO technologies.
Next Topic:Obtaing Value
Current Time: Sun Jul 27 11:12:00 EDT 2025
Powered by FUDForum. Page generated in 0.07622 seconds
