Home » Archived » Test and Performance Tools Platform (TPTP) » 'recorder' tptp distibutive/pack?
'recorder' tptp distibutive/pack? [message #111963] Fri, 07 September 2007 08:03 Go to next message
Hi!
Situation: software is running on remote computer that i can't access
over the net. This software is failing with errors which source i cannot
pinpoint based on produced logs.
Should there be network access, i would probably debug program remotely.
But alas, i cant. What i hope to do is to:
1. create some "execution flow recorder"/"black box" tptp pack so i can
configure it for recording locally (recorder package/class/method
filters, execution flow/memory/etc recording type and so on)
2. send it to guys running that program. They'll run that recorder,
press 2-3 buttons and tptp will record program execution for some time.
3. after that recorded results would be sent back to me
Of course I can get somewhat similar results by simply adding printlns
after every code line, but using tptp to analyze execution flow is MUCH
more easier and in the end will save me a lot of time.
So, are there any way to create such an eclipse pack that can to work as
a recorder that can be used by someone not familiar with eclipse or even
java?
Thanks in advance.
Re: 'recorder' tptp distibutive/pack? [message #111976 is a reply to message #111963] Fri, 07 September 2007 10:45 Go to previous messageGo to next message
Originally posted by: alexander.n.alexeev.intel.com
Vadim, if I understand correctly you are trying to debug raw Java
application.
In this case you can use TPTP at stand-alone mode. This allows you to
gather execution sequence information offline and later construct Call
Graph or some other presentation, it depends from type of profiling and
configuration.
Required steps:
1. Download "Agent Controller" archive for target platform
2. Deploy it any appropriate place
3. Configure execution for profiled application
- set environment variables
TPTP_AC_HOME=<<Agent Controller Home>>
JAVA_PROFILER_HOME=%TPTP_AC_HOME%\plugins\org.eclipse.tptp.j avaprofiler
PATH=%JAVA_PROFILER_HOME%;%PATH%;%TPTP_AC_HOME%\bin:%JAVA_HO ME%\bin
or LD_LIBRARY_PATH if you work with Linux
- Configure filters to reduce runtime overhead, trace file size and to
remove clutter. Filter configuration file is simple text with
following
format
"package/class template" "method" INCLUDE/EXCLUDE
Pay attention to order of templates, it affects which information
will be
collected.
4. Run target application on JVM with configured TPTP agent
"java -cp <class path>
-agentlib:JPIBootLoader=JPIAgent:server=standalone,filters=m yFilter.txt;CGProf:execdetails=true
<application class>"
By default information is collected in trace.trcxml, ant it can be changed.
5. After all collected data can be analyzed at Eclipse with TPTP.
For more information see
http://help.eclipse.org/help33/topic/org.eclipse.tptp.platfo rm.doc.user/tasks/teprofsa.htm
Alex.
Re: 'recorder' tptp distibutive/pack? [message #112003 is a reply to message #111976] Fri, 07 September 2007 12:52 Go to previous message
Alexander, thank you very much! It's exactly what I was looking for!
> application. In this case you can use TPTP at stand-alone mode. This
> allows you to gather execution sequence information offline and later
> construct Call Graph or some other presentation, it depends from type of
> profiling and configuration.
> Required steps:
> remove clutter. Filter configuration file is simple text with following
> format
> "package/class template" "method" INCLUDE/EXCLUDE Pay
> attention to order of templates, it affects which information will be
> collected. 4. Run target application on JVM with configured
> TPTP agent "java -cp <class path>
> Alex.
Previous Topic:Linux TPTP - Eclipse Runtime Workspace - Wrong Path - Plugin not recongnized
Next Topic:EXCEPTION_ACCESS_VIOLATION when running
Current Time: Sat Jul 26 18:53:12 EDT 2025
Powered by FUDForum. Page generated in 0.03179 seconds
