Re: Jubula failed to locate menu bar when executing test on Linux [message #1122004 is a reply to message #1121292] |
Tue, 01 October 2013 02:16  |
The problem under linux is new to me - can either of you confirm whether the unbound modules also cause the same issue?
Jiajian - the point you mention in your post about the lack of synchronization is exactly one of the reasons why we suggest using the unbound modules. Any test that is recorded (with any tool) will have to be made robust, reusable and readable: there will always be adaptations necessary after recording. In fact, the effort to make a recorded test good is probably the same (maybe even less) than writing it from scratch using e.g. the unbound modules. Anyway, lesson over - for your case, you'll probably want to write a module that clicks next, waits for some cue (a window title, a component, a text, ...) that means the test can continue.
Alex
FUDForum. Page generated in 0.33857 seconds
