Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] OutOfMemory error
[Teneo] OutOfMemory error [message #111853] Wed, 06 February 2008 09:20 Go to next message
Martin has helped me get this far with a large model. I now get
log4j:WARN No appenders could be found for logger
(org.eclipse.emf.teneo.hibernate.HbHelper).
log4j:WARN Please initialize the log4j system properly.
Exception in thread "main" java.lang.OutOfMemoryError: Java heap space
I have eclipse set top run with these parameters
D:\eclipse\eclipse.exe -vmargs -Xmx1024M -XX:PermSize=64M
-XX:MaxPermSize=128M
I am using the latest (as of Monday) version of Teneo. I notice the
process doing the work when running my Hib DataStore init (as below)
only uses 100MB. It there some way of increasing the memory available to
this process? There are over 1000 tables being generated.
There is nothing in the error log window from the time I run this.
// the name of the datastore
String hbName = "MyGenSec";
// the name of the database, this database should exist but does not
need to contain tables
String dbName = "gensechib";
// Set the database information, Environment is
org.hibernate.cfg.Environment
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, "root");
props.setProperty(Environment.PASS, "passw0rd");
props.setProperty(Environment.URL, "jdbc:mysql://192.168.0.3:3306/" +
dbName);
props.setProperty(Environment.DIALECT,
org.hibernate.dialect.MySQLInnoDBDialect.class.getName());
// props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_K EY,
"false");
// create the HbDataStore
HbDataStore hbds = HbHelper.INSTANCE.createRegisterDataStore(hbName);
// sets its epackages stored in this datastore
hbds.setEPackages(new EPackage[]{GensecPackage.eINSTANCE});
// set the relational database to use and other properties
// to set Teneo specific options call hbds.setPersistenceProperties
hbds.setHibernateProperties(props);
// initialize, also creates the database tables
hbds.initialize(); }
David
Re: [Teneo] OutOfMemory error [message #111857 is a reply to message #111853] Wed, 06 February 2008 09:27 Go to previous messageGo to next message
Have you tried with a larger maxpermsize?
gr. Martin
david wrote:
> not need to contain tables
> "jdbc:mysql://192.168.0.3:3306/" + dbName);
> props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_K EY, "false");
> HbDataStore hbds =
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] OutOfMemory error [message #111860 is a reply to message #111857] Wed, 06 February 2008 10:12 Go to previous messageGo to next message
Yes I tried 256M and 384M and the size of the process doing the work
remains at about 101MB until it gets that OutOfMemoryException, which
made me think the PermSize is not the issue.
What I do not get is that I know you had success ( partial at least
until MySQL threw in the towel) withthe same model?
David
Martin Taal wrote:
> gr. Martin
> david wrote:
>> Hi,
>> to this process? There are over 1000 tables being generated.
>> does not need to contain tables
>> HbDataStore hbds =
>> David
Re: [Teneo] OutOfMemory error [message #111862 is a reply to message #111860] Wed, 06 February 2008 10:26 Go to previous messageGo to next message
Hi David,
I should have thought about this earlier: I am not sure how you start the test run but when you do
this from within Eclipse (like with right-mouse click run-ass) then you need to set the -Xmx setting
in the run dialog (so not in the eclipse startup). In Eclipse open the run dialog (under the run
menu), your test program should be listed somewhere, select it and in the second tab (arguments) add
the correct parameters to the VM Arguments field. Press apply and run, normally with subsequent runs
Eclipse will automatically re-use the run settings.
gr. Martin
david wrote:
> David
> Martin Taal wrote:
>> Hi,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> "false");
>>> HbDataStore hbds =
>>> David
The Netherlands
Re: [Teneo] silent error, no logging [message #111863 is a reply to message #111862] Wed, 06 February 2008 11:49 Go to previous messageGo to next message
I gave it -Xmx768M and watched the process as it ran it took up to 268MB
and then failed silently. Nothing in Error log either.
Still getting this
Even after adding the HbHelper to the log4j.properties in the project
src directory
# Set root logger level to DEBUG and its only appender to A1.
log4j.rootCategory=DEBUG, A1
# A1 is set to be a ConsoleAppender.
log4j.appender.A1=org.apache.log4j.ConsoleAppender
# A1 uses PatternLayout.
log4j.appender.A1.layout=org.apache.log4j.PatternLayout
log4j.appender.A1.layout.ConversionPattern=%-4r [%t] %-5p %c %x - %m%n
#log4j.logger.org.hibernate=info
log4j.logger.org.hibernate=debug
### log HQL query parser activity
#log4j.logger.org.hibernate.hql.ast.AST=debug
### log just the SQL
log4j.logger.org.hibernate.SQL=debug
### log JDBC bind parameters ###
log4j.logger.org.hibernate.type=debug
#log4j.logger.org.hibernate.type=debug
### log schema export/update ###
log4j.logger.org.hibernate.tool.hbm2ddl=debug
### log HQL parse trees
log4j.logger.org.hibernate.hql=debug
### log cache activity ###
log4j.logger.org.hibernate.cache=debug
### log transaction activity
log4j.logger.org.hibernate.transaction=debug
### log JDBC resource acquisition
log4j.logger.org.hibernate.jdbc=debug
log4j.logger.org.eclipse.emf.teneo.hibernate.mapper.Generate HBM=debug
log4j.logger.org.eclipse.emf.teneo.hibernate.HbHelper=debug
Thx.
David
Martin Taal wrote:
> Hi David,
> the test run but when you do this from within Eclipse (like with
> right-mouse click run-ass) then you need to set the -Xmx setting in the
> dialog (under the run menu), your test program should be listed
> somewhere, select it and in the second tab (arguments) add the correct
> subsequent runs Eclipse will automatically re-use the run settings.
> gr. Martin
> david wrote:
>> Hi,
>> David
>> Martin Taal wrote:
>>> Hi,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> available to this process? There are over 1000 tables being generated.
>>>> "false");
>>>> HbDataStore hbds =
>>>> David
Re: [Teneo] silent error, no logging [message #111864 is a reply to message #111863] Wed, 06 February 2008 12:25 Go to previous messageGo to next message
Hi David,
Are you sure that log4j.properties is copied to the output folder?
If you have a plugin project then my experience is that the log4j.properties has to be specifically
selected in the build.properties (to be part of the binary build).
What I find strange is that the console does not show an exception (as you are not mentioning it).
How do you know that the initialize step actually failed?
gr. Martin
david wrote:
> Still getting this
> src directory
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> run dialog (under the run menu), your test program should be listed
>> with subsequent runs Eclipse will automatically re-use the run settings.
>> gr. Martin
>> david wrote:
>>> Hi,
>>> David
>>> Martin Taal wrote:
>>>> Hi,
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> below) only uses 100MB. It there some way of increasing the memory
>>>>> "false");
>>>>> HbDataStore hbds =
>>>>> David
The Netherlands
Re: [Teneo] silent error, no logging [message #111869 is a reply to message #111864] Thu, 07 February 2008 04:40 Go to previous messageGo to next message
Firstly I was following the instructions on the EMF Hibernate
Troubleshooting page and it says :"This file should be placed directly
in the src directory of your EMF Model project." When I moved
log4j.properties to the bin directory, bingo logging worked and so did
everything else it seems so far.
It has now been running for 45 minutes, creating tables etc. I note lots
of ERROR messages in the log, will investigate these when it is done. I
also note that it produces so many log messages that the Console in
Eclipse does not respond, so will set a RollingFileAppender next time.
Thx.
David
Martin Taal wrote:
> Hi David,
> log4j.properties has to be specifically selected in the build.properties
> you are not mentioning it). How do you know that the initialize step
> actually failed?
> gr. Martin
> david wrote:
>> Hi,
>> 268MB and then failed silently. Nothing in Error log either.
>> Still getting this
>> src directory
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> normally with subsequent runs Eclipse will automatically re-use the
>>> run settings.
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> which made me think the PermSize is not the issue.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi,
>>>>> gr. Martin
>>>>> david wrote:
>>>>>> Hi,
>>>>>> space
>>>>>> the process doing the work when running my Hib DataStore init (as
>>>>>> generated.
>>>>>> but does not need to contain tables
>>>>>> "false");
>>>>>> HbDataStore hbds =
>>>>>> David
Re: [Teneo] silent error, no logging [message #111870 is a reply to message #111869] Thu, 07 February 2008 04:55 Go to previous message
Hi David,
Yes you need to place it in the src directory and then you need to tell Eclipse to copy it to the
bin (or build) directory when building. I have added this to the docs, will be visible in the next
release.
I also noticed a lot of errors related to index creation. Often these occur because a table was not
created or because of other database constraints.
gr. Martin
david wrote:
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> actually failed?
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Still getting this
>>> src directory
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> start the test run but when you do this from within Eclipse (like
>>>> setting in the run dialog (so not in the eclipse startup). In
>>>> Eclipse open the run dialog (under the run menu), your test program
>>>> (arguments) add the correct parameters to the VM Arguments field.
>>>> Press apply and run, normally with subsequent runs Eclipse will
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> work remains at about 101MB until it gets that
>>>>> OutOfMemoryException, which made me think the PermSize is not the
>>>>> issue.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi,
>>>>>> gr. Martin
>>>>>> david wrote:
>>>>>>> Hi,
>>>>>>> space
>>>>>>> memory available to this process? There are over 1000 tables
>>>>>>> being generated.
>>>>>>> "false");
>>>>>>> HbDataStore hbds =
>>>>>>> David
The Netherlands
Re: [Teneo] OutOfMemory error [message #615410 is a reply to message #111853] Wed, 06 February 2008 09:27 Go to previous message
gr. Martin
david wrote:
> HbDataStore hbds =
> David
The Netherlands
Re: [Teneo] OutOfMemory error [message #615411 is a reply to message #111857] Wed, 06 February 2008 10:12 Go to previous message
David
Martin Taal wrote:
> gr. Martin
> david wrote:
>> Hi,
>> HbDataStore hbds =
>> David
Re: [Teneo] OutOfMemory error [message #615412 is a reply to message #111860] Wed, 06 February 2008 10:26 Go to previous message
Hi David,
gr. Martin
david wrote:
> David
> Martin Taal wrote:
>> Hi,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> "false");
>>> HbDataStore hbds =
>>> David
The Netherlands
Re: [Teneo] silent error, no logging [message #615413 is a reply to message #111862] Wed, 06 February 2008 11:49 Go to previous message
Still getting this
src directory
Thx.
David
Martin Taal wrote:
> Hi David,
> gr. Martin
> david wrote:
>> Hi,
>> David
>> Martin Taal wrote:
>>> Hi,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> "false");
>>>> HbDataStore hbds =
>>>> David
Re: [Teneo] silent error, no logging [message #615414 is a reply to message #111863] Wed, 06 February 2008 12:25 Go to previous message
Hi David,
gr. Martin
david wrote:
> Still getting this
> src directory
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> David
>>> Martin Taal wrote:
>>>> Hi,
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> "false");
>>>>> HbDataStore hbds =
>>>>> David
The Netherlands
Re: [Teneo] silent error, no logging [message #615419 is a reply to message #111864] Thu, 07 February 2008 04:40 Go to previous message
Thx.
David
Martin Taal wrote:
> Hi David,
> actually failed?
> gr. Martin
> david wrote:
>> Hi,
>> Still getting this
>> src directory
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> run settings.
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi,
>>>>> gr. Martin
>>>>> david wrote:
>>>>>> Hi,
>>>>>> space
>>>>>> generated.
>>>>>> "false");
>>>>>> HbDataStore hbds =
>>>>>> David
Re: [Teneo] silent error, no logging [message #615420 is a reply to message #111869] Thu, 07 February 2008 04:55 Go to previous message
Hi David,
release.
gr. Martin
david wrote:
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> actually failed?
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Still getting this
>>> src directory
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> issue.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi,
>>>>>> gr. Martin
>>>>>> david wrote:
>>>>>>> Hi,
>>>>>>> space
>>>>>>> being generated.
>>>>>>> "false");
>>>>>>> HbDataStore hbds =
>>>>>>> David
The Netherlands
Previous Topic:[Teneo] Retrieving the teneo version at runtime
Next Topic:[Teneo] Generated identifier names too long
Current Time: Thu Jul 24 21:30:43 EDT 2025
Powered by FUDForum. Page generated in 0.50680 seconds
