Home » Modeling » Epsilon » Problem Opening Wizard
Problem Opening Wizard [message #1118517] Fri, 27 September 2013 09:40 Go to next message
Guys, when I try to create a diagram, the following error happen:
The selected wizard could not be started.
Plug-in tarcisio.diagram was unable to load class arquivo.diagram.part.ArquivoCreationWizard.
An error occurred while automatically activating bundle tarcisio.diagram (1119).
Re: Problem Opening Wizard [message #1121443 is a reply to message #1118517] Mon, 30 September 2013 12:25 Go to previous message
That means that the plug-in implementing your wizard could not be started. It could be due to many different reasons. Have you tried using the Error Log or OSGi Console views to see why it couldn't be activated?
[Updated on: Mon, 30 September 2013 12:25] by Moderator
Previous Topic:EObjectValidator.validate() is called multiple times for models that are based on several packages
Next Topic:New Pallet
Current Time: Sun Jul 27 22:58:06 EDT 2025
Powered by FUDForum. Page generated in 0.03973 seconds
