How to edit unknow feature. [message #1118143] |
Fri, 27 September 2013 01:30  |
I use the iption "OPTION_RECORD_UNKNOWN_FEATUR" to record unknown featurs .I want to know how to change the value of such features on the editor.
Resource resource=eobject.eResource();
AnyType type=getEObjectExtension(eobject);
FeatureMap featureMap= type.getAnyAttribute();
EStructuralFeature feature= entry.getEStructuralFeature();
if(property.equals("value")){
//EObject obj=feature.eContainer();
//SetCommand.create(domain, obj, feature, value);
featureMap.set(entry.getEStructuralFeature(), value);
The code featureMap.set(entry.getEStructuralFeature(), value); can change the value,but the editor's status is not dirty.then i try to create a SetCommand but failed.
I want to add/remove unkown feature to a eobject dynamically ,too。
[Updated on: Fri, 27 September 2013 01:30] by Moderator
Re: How to edit unknow feature. [message #1118208 is a reply to message #1118143] |
Fri, 27 September 2013 03:03  |
Javen,
Comments below.
> the editor.
> Resource resource=eobject.eResource(); AnyType
How did you get entry?
What is property?
Here obj is no doubt the EClass that contains the EStructuralFeature.
That's not what you want to be changing.
What's value?
> change the value,but thi editor's statud is not dirty.then i try to
It's hard to comment on the incomplete code above, but clearly some
parts are wrong. To get it working, keep in mind that the feature map
is a list and that you can operate on it like any other list. So you can
determine the index of the feature map entry you want to replace, use
FeatureMapUtil to create a new replacement entry, and use a set command
to replace the current entry in the feature map with the new entry at
the index of the old entry.
All such things operate on the feature map in the same way.
FUDForum. Page generated in 0.03778 seconds
