Home » Eclipse Projects » Eclipse RT (runtime) » not sure whether we are moving forward or backward?
not sure whether we are moving forward or backward? [message #1117715] Thu, 26 September 2013 14:42 Go to next message
Before when i am using indigo it seems fine. looks stable. now even with kepler when changing views end even sometimes without doing anything it gives "event loop" exception and gets shutdown. This is there from longtime and not have been resolved.
[Updated on: Thu, 26 September 2013 15:20] by Moderator
Re: not sure whether we are moving forward or backward? [message #1118773 is a reply to message #1117715] Fri, 27 September 2013 15:23 Go to previous messageGo to next message
In kepler it is even worse. Every time when i try to put a debug point it throws the error and gets shutdown. Now a days working with eclipse is being a tough job.
The following is the stack trace:-
rg.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4423)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.SWT.error(SWT.java:4283)
at org.eclipse.swt.widgets.Widget.error(Widget.java:472)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:704)
at org.eclipse.swt.widgets.Label.createHandle(Label.java:199)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:744)
at org.eclipse.swt.widgets.Control.<init>(Control.java:112)
at org.eclipse.swt.widgets.Label.<init>(Label.java:101)
at org.eclipse.ui.texteditor.StatusLineContributionItem.fill(StatusLineContributionItem.java:182)
at org.eclipse.jface.action.SubContributionItem.fill(SubContributionItem.java:59)
at org.eclipse.jface.action.StatusLineManager.update(StatusLineManager.java:327)
at org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:287)
at org.eclipse.ui.internal.WorkbenchPage.access$15(WorkbenchPage.java:265)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:194)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run(PartServiceImpl.java:183)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:181)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:595)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:539)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:104)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:59)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1081)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1453)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2334)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4655)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2075)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4990)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2544)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4706)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3141)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
[Updated on: Fri, 27 September 2013 15:31] by Moderator
Re: not sure whether we are moving forward or backward? [message #1121565 is a reply to message #1118773] Mon, 30 September 2013 15:14 Go to previous messageGo to next message
I was having the same issue and, after much thrashing about, I was able to get past the problem by disabling some programs. I'm not sure which of these two programs were causing the issue, but I disabled both and now Eclipse Kepler is running fine. The two programs are iRotate and DisplayFusion.
I've also seen a post over on Stack Overflow that claims HP Protect Tools may also cause this issue. Here is the text of the answer as I can't insert links yet:
I have no ideia how, but right after a uninstalled the HP Protect Tools service, the exact same problem stopped in my notebook... using eclipse kepler on Win7 Pro x64.
Hopefully one of these items is the cause of your issues.
Good luck.
[Updated on: Mon, 30 September 2013 16:33] by Moderator
Re: not sure whether we are moving forward or backward? [message #1124623 is a reply to message #1121565] Thu, 03 October 2013 14:39 Go to previous message
I am not able to find any of those that you specified in eclipse kepler. if they come with the default kepler then please help me out to find them. If you can provide some info on how to find and where they are and how to disable them. It will be a great help. Thanks in advance.
Previous Topic:Single threaded IDE?
Next Topic:not get internal extension PyDev
Current Time: Thu Jul 24 17:59:12 EDT 2025
Powered by FUDForum. Page generated in 0.03639 seconds
