Home » Language IDEs » ServerTools (WTP) » Tomcat Server - ${catalina.base}/lib(How to define instance specific jars)
Tomcat Server - ${catalina.base}/lib [message #1117260] Thu, 26 September 2013 04:51 Go to next message
Hi.
When defining a Tomcat 6 Server in Juno, my understanding is that this definition essentially sets up a CATALINA_BASE instance, which refers to a CATALINA_HOME installation. The server definition allows me to set up the config files for the CATALINA_BASE instance and this gets deployed to a location under the .metadata folder.
My question is - Is it possible to define a CATALINA_BASE/lib directory as part of the server definition?
Specific use-case: I need to deploy v2.2 of the Expression Language jars, el-api.2.2.jar and el-impl.2.2.jar.
I cannot place them in my WEB-INF/lib folder as then both el-api.2.2.jar from the webapp and el-api.jar from CATALINA_HOME/lib get loaded and I get conflicting class definitions.
I do not want to place them in CATALINA_HOME/lib as it's another thing to maintain (in fact the only thing to have to maintain and replace manually) if I upgrade CATALINA_HOME. I'd rather not touch CATALINA_HOME at all.
CATALINA_BASE/lib seems the correct place to put them and indeed this works on a manual deployment, but I can't find a way to set this up in an Eclipse Tomcat Server defintion.
Thanks, Gordon
Re: Tomcat Server - ${catalina.base}/lib [message #1117618 is a reply to message #1117260] Thu, 26 September 2013 12:34 Go to previous messageGo to next message
On 9/26/2013 7:27 AM, Gordon Little wrote:
> Hi.
No. But there would be no problem creating a lib folder manually where
CATALINA_BASE points and placing jars there.
> jars, el-api.2.2.jar and el-impl.2.2.jar. I cannot place them in my
> definitions.
> at all.
When the WTP Tomcat support creates a new server instance, it creates a
number of folder, but a lib folder isn't one of them. However, once the
instance area was created you could create a "lib" folder manually and
add the jars you wanted. This does mean that you would still be on the
hook for manual maintenance if you recreated server instances or created
new ones.
Larry
> Thanks, Gordon
Re: Tomcat Server - ${catalina.base}/lib [message #1117656 is a reply to message #1117618] Thu, 26 September 2013 13:20 Go to previous message
Thanks Larry.
That makes sense. While I've managed to blitz a number of server instances recently trying to understand the setup, that should calm down now I think I get it.
Thanks again.
Previous Topic:Web Page editor plugin for eclipse 3.2
Next Topic:Cannot Install New Tomcat 7 Server After Removing It
Current Time: Fri Jul 25 22:49:44 EDT 2025
Powered by FUDForum. Page generated in 0.06790 seconds
