Home » Eclipse Projects » Remote Application Platform (RAP) » add bookmark/favorit using javascript
add bookmark/favorit using javascript [message #1115698] Tue, 24 September 2013 08:52 Go to next message
Hello
I have an application where I open RAP editors containing a browser with certain URL.
Now I would like to provide a handler which adds the current URL to the browsers bookmakrs/favorits.
I only want to provide this function for IE.
This is what I came up with:
String script = "window.external.AddFavorite(\"" + url + "\", \"" + label + "\");";
org.eclipse.rwt.internal.widgets.JSExecutor.executeJS(script);
If I execute this nothing happens, no warning, exception or anything.
Executing javascript else works, for example I have this zoom function:
String script = "if(window.parent.document.body.style.zoom!=0) window.parent.document.body.style.zoom*=0.8; else window.parent.document.body.style.zoom=0.8;";
I also tested the plain "window.external.AddFavorite..." outside of RAP, which also works, Favorit Dialog is opened.
Any idea on how I can solve this? Am I executing the script wrong?
greets and thanks for any help
Flavio
[Updated on: Tue, 24 September 2013 08:53] by Moderator
Re: add bookmark/favorit using javascript [message #1116419 is a reply to message #1115698] Wed, 25 September 2013 08:08 Go to previous messageGo to next message
Hi.
My guess is this:
"For security reasons, the AddFavorite method must be called as a
response to a user-initiated action, such a mouse click. If called from
a different context, such as the onload event of the body element, the
AddFavorite method fails silently." [1]
There are may ways to work around this. For example you could use a
Browser widget to create a button or link that does this on the client.
(The button would probably not look like other RAP buttons.) Other ways
would be to use ClientScripting, the MARKUP_ENABLED feature or a custom
widget.
Greetings,
Tim
[1] http://msdn.microsoft.com/en-us/library/ms535926%28v=vs.85%29.aspx
Am 24.09.2013 14:52, schrieb Flavio Donze:
> Hello
> certain URL.
> label + "\");";
> Flavio
Tim Buschtöns
Twitter: @EclipseRAP
Re: add bookmark/favorit using javascript [message #1117530 is a reply to message #1116419] Thu, 26 September 2013 10:42 Go to previous message
Hi Tim
Thanks for your reply, since I'm still using RAP 1.4.2 I ended up using the Browser widget.
Thank you very much for your help!
Flavio
[Updated on: Thu, 26 September 2013 10:42] by Moderator
Previous Topic:SWTException in CoolBarManager on disposed CoolItem
Next Topic:Can I ensure that third party code uses my configured SettngStore
Current Time: Wed Jul 23 05:49:33 EDT 2025
Powered by FUDForum. Page generated in 0.08093 seconds
