Home » Eclipse Projects » Eclipse Platform » Viewing a single document partition
Viewing a single document partition [message #111698] Mon, 18 August 2003 05:33 Go to next message
Originally posted by: ian.brown.printsoft.de
I have a document which is partitioned into 2 partitions (header and
body).
I have a multi-page editor in which I want to edit the body partition in a
TextEditor in page 1 and I want to edit the header partition via a SWT form
in page 2.
My question is how can I make page 1 (the TextEditor) only display the body
partition. Currently I have the header displayed in a separate colour, but I
cannot see how to make the text editor ignore it completely. Any help or
ideas would be much appreciated.
Ian
Re: Viewing a single document partition [message #111750 is a reply to message #111698] Mon, 18 August 2003 10:29 Go to previous messageGo to next message
Originally posted by: tom.eicher.gmx.ch.nodomain
Currently, the "Show source of selected element" feature of the Java
Editor which lets you display a method at a time is implemented using
the ITextViewer.setVisibleRegion(int, int) method. See how it is
implemented for a start.
You can also have a look at org.eclipse.jface.text.ProjectionDocument
and its usage. There are "projection" source folders in the
org.eclipse.jface.text and org.eclipse.text projects that support the
notion of folded or projected documents.
-tom
Ian Brown wrote:
> body).
> in page 2.
> Ian
Re: Viewing a single document partition [message #111843 is a reply to message #111750] Mon, 18 August 2003 13:38 Go to previous messageGo to next message
Originally posted by: paull.NOSPAMcodetelligence.com
Is using the ITextViewer.setVisibleRegion(int, int) method preferable to
using the TextEditor .showHighlightRangeOnly(true)
..setHighlightRange(offset,length,true)?
Paul
"Tom Eicher" <tom.eicher@gmx.ch.nodomain> wrote in message
news:bhqnst$va0$1@eclipse.org...
> -tom
> Ian Brown wrote:
> > Hi,
> > body).
a
form
> > in page 2.
body
but I
> > Thanks,
> > Ian
Re: Viewing a single document partition [message #112852 is a reply to message #111843] Wed, 20 August 2003 05:09 Go to previous messageGo to next message
If you use setHighlightRange() then this means the user cannot highlight
stuff in the view because you are already using the highlight.
I found a solution to my problem that seems to work. I make a new document
class ... Basically just copied the Document implementation. I then overrode
the set(String text) function to only pass the data following the header to
the textstore and the header. I seems to work at the moment ... I need to do
some clever stuff on saving, but I would need to do that anyhow.
Basically, I added the code below...
public void set(String text) {
int length= getStore().getLength();
DocumentEvent e= new DocumentEvent(this, 0, length, text);
fireDocumentAboutToBeChanged(e);
String str_body = text;
if (text.length() > 5){
// This splits the input on the CRC line (which is the end of the text
header).
String[] split_results = text.split("[\r\n]CRC=[0-9A-F]*[\n\r]+", 2);
str_body = split_results[1];
getStore().set(str_body);
getTracker().set(str_body);
fireDocumentChanged(e);
"Paul L" <paull@NOSPAMcodetelligence.com> wrote in message
news:bhr2vg$bhs$1@eclipse.org...
Re: Viewing a single document partition [message #113327 is a reply to message #112852] Wed, 20 August 2003 17:40 Go to previous message
Maybe I'm missinterpreting what you are saying, but when you use
showHighlightRangeOnly/setHighlightRange() the editor will only display the
text within the range and the user can still highlight what they want within
this text. At least thats how it is working in my editor.
Pul
"Ian Brown" <ian.brown@printsoft.de> wrote in message
news:bhvdoh$6a2$1@eclipse.org...
overrode
to
do
> header).
Previous Topic:disappearing "build project" option
Next Topic:How to add external builders permanently and programmatically
Current Time: Fri Jul 25 10:23:07 EDT 2025
Powered by FUDForum. Page generated in 0.07762 seconds
