The package is needed but is not accessible from the generator model [message #1116704] |
Wed, 25 September 2013 15:09  |
Hello guys,
I have a file called arquivo.emf that depends on BPMN20.ecore right? The BPMN20.ecore depends on 3 others files called BPMNDI.ecore, DC.ecore and DI.ecore.
When I click on arquivo.emf and after on Eugenia -> Generate GMF Editor, the following problems arise:
The package platform:/resource/tarcisio/model/DI.ecore is needed but is not accessible from the generator model
The package platform:/resource/tarcisio/model/DC.ecore is needed but is not accessible from the generator model
I don't know how to solve this problem.
Thank you.
Re: The package is needed but is not accessible from the generator model [message #1117554 is a reply to message #1116742] |
Thu, 26 September 2013 11:06   |
- Version of Epsilon: 1.0.0.201211082326
- Instructions:
- Import the tarcisio project;
- Copy and paste the arquivo.ecore and arquivo.emf files in the model folder;
- Click in BPMN20.genmodel and click in Generate Model code and after Generate Edit Code;
- From the arquivo.ecore file, generate the arquivo.genmodel file manually.
- After, click in arquivo.genmodel and click in Generate Model code and after Generate Edit Code;
- Some erros will appears, then correct the errors using imports;
- Generate manually all others need files, arquivo.gmfgraph, gmftool, gmfgen, diagram, ect;
- If some erros appears, correct using imports;
- Run the project;
- You will see that when you put a variation point node, the attributes doesn't appears, but if you are using a tree everything works normally;
You can download the tarcisio project here: https://dl.dropboxusercontent.com/u/38248929/tarcisio-model.zip
Thank you!
FUDForum. Page generated in 0.07327 seconds
