Home » Eclipse Projects » e(fx)clipse » RCP e4 SWT/JavaFX application with Kepler
RCP e4 SWT/JavaFX application with Kepler [message #1116476] Wed, 25 September 2013 10:00 Go to next message
I managed to create an SWT/JavaFX application with Eclipse Juno and e(fx)clipse 0.8.1.
I wanted to do the same now with Kepler and e(fx)clipse 0.9.0 and I'm stuck.
When starting the application (via a product launch config) I get the error message about the missing bundle:
!MESSAGE Bundle at.bestsolution.efxclipse.runtime.osgi not found.
As the bundle apparently isn't part of e(fx)clipse 0.9.0, I downloaded it bundle and at.bestsolution.efxclipse.runtime.javafx from Github into my workspace.
I added theses plug-ins to the products run configuration and added -Dosgi.framework.extensions=at.bestsolution.efxclipse.runtime.osgi to the launch configs VM arguments.
Do I perhaps need to add these plug-ins to my target platform? How would I do that?
Re: RCP e4 SWT/JavaFX application with Kepler [message #1116506 is a reply to message #1116476] Wed, 25 September 2013 10:31 Go to previous messageGo to next message
This won't work because framework adapter hooks are ONLY loaded when
org.eclipse.osgi is in the very same filesystem path.
In 0.9.0 the complete namespace had to be shifted to org.eclipse.fx you
could fix everything by hand but I'd suggest to let the tooling
bootstrap you a new e4 Application and you copy over the relevant stuff
from the 0.8.1 project.
I'm sorry about that but this namespace shift was necessary when moving
to Eclipse.org - so it will never happen again.
Tom
> e(fx)clipse 0.8.1.
> stuck.
> error message about the missing bundle:!MESSAGE Bundle
> my workspace.
> I do that?
Re: RCP e4 SWT/JavaFX application with Kepler [message #1116533 is a reply to message #1116506] Wed, 25 September 2013 11:12 Go to previous messageGo to next message
Well, actually I started from scratch with a sample application. What I did:
  1. installed Eclipse Kepler
  2. installed e(fx)clipse 0.9.0 and e4 tools 0.14
  3. created new Eclipse 4 -> Eclipse 4 Application project (with sample content; product runs fine)
  4. created new target platform from ​http://download.eclipse.org/efxclipse/runtime-nightly/site and added Kepler plug-ins (don't know if I was supposed to do that)
  5. created an FX part injecting BorderPane (everything is fine at compile time)
On running the product I get an ClassNotFoundException at runtime when the parts @PostConstruct method is called.
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-09-25 17:07:43.644
!MESSAGE Unable to create class 'swt.fx.test.app.parts.FXPart' from bundle '5'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javafx/scene/Node
That's when I tried to include the at.bestsolution.* stuff.
[Updated on: Wed, 25 September 2013 11:14] by Moderator
Re: RCP e4 SWT/JavaFX application with Kepler [message #1116591 is a reply to message #1116533] Wed, 25 September 2013 12:28 Go to previous messageGo to next message
Ok so you are creating an e4 SWT application and want to embedd JavaFX?
I assumed from your other question on the e4 forum that you are using
pure JavaFX.
You need to add:
* org.eclipse.fx.javafx
* org.eclipse.fx.osgi
* org.eclipse.fx.ui.di.interopt
to your launch config and also set
-Dosgi.framework.extensions=org.eclipse.fx.osgi and then things should work.
Tom
> did:
> in the application created FX part injecting BorderPane (everything is
> On running the produnct I get an ClassNotFoundException at runtime when
> the parts @PostConstruct method is called.!ENTRY
> bundle '5'
> !STACK 0
Re: RCP e4 SWT/JavaFX application with Kepler [message #1116601 is a reply to message #1116591] Wed, 25 September 2013 12:43 Go to previous messageGo to next message
Thomas Schindl wrote on Wed, 25 September 2013 18:28
pure JavaFX.
Well I'm still unsure if I want to use FX rendering for the whole application or just for some special parts. So I'm experimenting around a bit. Smile
You need to add:
That did the trick. Thanks a lot! Smile
Just one more thing... the way I created the target platform:
Mar Ifla wrote on Wed, 25 September 2013 17:12
... is that the correct way to do it?
[Updated on: Wed, 25 September 2013 12:44] by Moderator
Re: RCP e4 SWT/JavaFX application with Kepler [message #1133053 is a reply to message #1116601] Fri, 11 October 2013 11:22 Go to previous message
I'm still having some problems which I assume result from not having the correct target platform.
How do I create a correct one for an e4 SWT application with embedded JavaFX?
[Updated on: Fri, 11 October 2013 11:22] by Moderator
Previous Topic:Accessing the controller instance when using FXMLLoaderFactory
Next Topic:OSGi: loading an FXML file from another bundle
Current Time: Wed Jul 23 11:48:44 EDT 2025
Powered by FUDForum. Page generated in 0.08335 seconds
