Home » Newcomers » Newcomers » Hello World SWT - Could not load SWT library(Can't run the first tutorial )
Hello World SWT - Could not load SWT library [message #754988] Sun, 06 November 2011 07:59 Go to next message
Hello All,
I just "installed" Eclipse for RCP and RAP Developers and wanted to do the "Hello World SWT" tutorial.
I am getting the following error when i run the application.
Exception in thread "main" java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
	no swt-win32-3738 in java.library.path
	no swt-win32 in java.library.path
	Can't load library: C:\Users\Willem\.swt\lib\win32\x86\swt-win32-3738.dll
	Can't load library: C:\Users\Willem\.swt\lib\win32\x86\swt-win32.dll
	at org.eclipse.swt.internal.Library.loadLibrary(Library.java:285)
	at org.eclipse.swt.internal.Library.loadLibrary(Library.java:194)
	at org.eclipse.swt.internal.C.<clinit>(C.java:21)
	at org.eclipse.swt.widgets.Display.<clinit>(Display.java:138)
	at HelloWorldSWT.main(HelloWorldSWT.java:13)
I think this might has something to do with my %PATH% variable, or my runtime environment , but i'm not really sure.
I downloaded the latest java JDK from the oracle site ( Java SE 7u1 )
I updated my eclipse.ini , as suggested in the newcomers sticky .
My eclipse.ini file looks like this:
-startup
plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502
-product
org.eclipse.epp.package.rcp.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
-vm
C:\Program Files\Java\jdk1.7.0_01\bin\javaw.exe
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
I am running windows 7 professional 32 bit.
Any help would be greatly appreciated, thanks in advanced !
[Updated on: Sun, 06 November 2011 09:30] by Moderator
Re: Hello World SWT - Could not load SWT library [message #754994 is a reply to message #754988] Sun, 06 November 2011 09:16 Go to previous messageGo to next message
On 2011.11.06 5:59, willem wrote:
> Hello All,
> [snip]
> -startup
> --launcher.library
> -product
> openFile
> 256M
> -showsplash
> 256m
> openFile
> -vmargs
> -Xms40m
> -Xmx512m
> -vm
> I added the last two lines, but that doesn't seem to do anything.
Hey, this may be a little off-topic (i.e.: it may not cure your original
complaint), but I'm pretty sure that you must put
-vm
before the -vmargs section in eclipse.ini.
Re: Hello World SWT - Could not load SWT library [message #754995 is a reply to message #754994] Sun, 06 November 2011 09:28 Go to previous messageGo to next message
Hi Russell, thanks for noticing that, i changed it, but it doesn't seem to solve the problem.
Re: Hello World SWT - Could not load SWT library [message #761182 is a reply to message #754988] Mon, 05 December 2011 22:28 Go to previous messageGo to next message
Hello
I have got exactly the same problem! Bad for a first SWT example for newbies Confused
Anyway there is a working solution Razz for me (My SDK is eclipse-SDK-3.7.1-win32.zip)
Follow the explanations given on the link below
to add swt-3.7.1-win32-win32-x86.zip to your Eclipse
(in case you are in Windows 32bit)
www.badprog.com/eclipse-standard-widget-toolkit-swt-installation
There are probably other solutions using the java.library.path
lol : I cannot use links until I have posted more than 5 messages so you may have to add h t t p : / / by yourself.
Another collateral damage of the war against spam...
Re: Hello World SWT - Could not load SWT library [message #762787 is a reply to message #761182] Thu, 08 December 2011 11:16 Go to previous messageGo to next message
The solution didn't work for me. First it told me that it couldn't add the project that was already there, org.eclipse.swt. So I deleted org.eclipse.swt and org.eclipse.swt.win32.win32.x86 and tried that import again. But it only added org.eclipse.swt and not org.eclipse.swt.win32.win32.x86, which I still had to add again the way the tutorial tells. Not working, so again I tried just deleting org.eclipse.swt and following the "solution" instructions again.
After another whinge that swt-win32-3738 was not found (even thought it is in Workspace\org.eclipse.swt.win32.win32.x86 as a .dll), I picked on the message
Can't load library: .swt\lib\win32\x86\swt-win32-3738.dll
and copied the file there. Now it works. But something doesn't feel right.
It seems to me that this is not meant to be the solution. If the file belongs there, why wasn't it there in the first place? If it doesn't, my solution is dirty/messy, especially is I have to do the same thing again and again. Anyway, the file is in the root of the project org.eclipse.swt.win32.win32.x86, so why wasn't it used from there? Does it really belong there? Are some paths set wrong? Is the problem in the project itself or in Eclipse?
In short - what is wrong / what am I doing wrong? Help!
Tom
Re: Hello World SWT - Could not load SWT library [message #794878 is a reply to message #762787] Thu, 09 February 2012 15:24 Go to previous messageGo to next message
I found this thread after trying the HelloWorldSWT tutorial myself and coming across the exact same problem.
For me the solution lay in the step of the tutorial titled 'Configure the Java project'. Go into the project Properties and select Java Build Path then make sure you are in the Projects tab where you added the SWT project earlier. Expand the reference to the SWT project. Where is says Native library location I found that when I followed the tutorial it said (None). I clicked Edit and found the SWT project in my workspace obviously when I added it earlier in the tutorial. Select this and click OK.
Your project should now be able to run.
Re: Hello World SWT - Could not load SWT library [message #797514 is a reply to message #794878] Mon, 13 February 2012 10:33 Go to previous messageGo to next message
I need help too
Re: Hello World SWT - Could not load SWT library [message #797517 is a reply to message #797514] Mon, 13 February 2012 10:35 Go to previous messageGo to next message
I'm studying a guide book, a chapter describes a project to add:
Right-click on the package of the project - properties - android - Add..., but does not allow me to add the library. Please Help
Re: Hello World SWT - Could not load SWT library [message #797518 is a reply to message #797517] Mon, 13 February 2012 10:35 Go to previous messageGo to next message
ttp://img607.imageshack.us/img607/7131/immaginexca.jpg
icon14.gif  Re: Hello World SWT - Could not load SWT library [message #824856 is a reply to message #794878] Tue, 20 March 2012 02:35 Go to previous messageGo to next message
Thanks Craig, that fixed it.
icon14.gif  Re: Hello World SWT - Could not load SWT library [message #833776 is a reply to message #794878] Sat, 31 March 2012 21:48 Go to previous messageGo to next message
Thanks from me too -
icon14.gif  Re: Hello World SWT - Could not load SWT library [message #834359 is a reply to message #833776] Sun, 01 April 2012 17:18 Go to previous messageGo to next message
Thanks a lot!
Re: Hello World SWT - Could not load SWT library [message #868522 is a reply to message #834359] Wed, 02 May 2012 02:29 Go to previous messageGo to next message
And another thank you to Craig Williams.
icon14.gif  Re: Hello World SWT - Could not load SWT library [message #870608 is a reply to message #868522] Tue, 08 May 2012 20:36 Go to previous messageGo to next message
Thanks Craig Williams. The problem solved. Was trying to download SWT package to install, but, this is much quicky solution and at least we know the SWT came with the package is not broken.
Re: Hello World SWT - Could not load SWT library [message #876141 is a reply to message #794878] Wed, 23 May 2012 21:36 Go to previous messageGo to next message
Yes, that worked, after several tries. Thank you Craig.
Re: Hello World SWT - Could not load SWT library [message #900079 is a reply to message #754988] Fri, 03 August 2012 16:10 Go to previous messageGo to next message
To Craig Williams..
Thanks! I solved it!
icon14.gif  Re: Hello World SWT - Could not load SWT library [message #901042 is a reply to message #794878] Thu, 09 August 2012 10:07 Go to previous messageGo to next message
Thank you - that did the trick.
icon14.gif  Re: Hello World SWT - Could not load SWT library [message #909027 is a reply to message #754988] Thu, 06 September 2012 08:43 Go to previous messageGo to next message
Thank you Craig Williams
Saved more than necessary head scratching.
Cheers.
Re: Hello World SWT - Could not load SWT library [message #977665 is a reply to message #754988] Fri, 09 November 2012 08:21 Go to previous messageGo to next message
Thank You Craig Williams!
Re: Hello World SWT - Could not load SWT library [message #984306 is a reply to message #977665] Wed, 14 November 2012 10:32 Go to previous messageGo to next message
+1 Craig Williams, although for me it didn't really help - but now I know where that is!
I must of missed an installation step because the default place it was looking for the swt library was
$HOME/.swt/lib/linux/x86
and there weren't any libraries in there. So I did:
find ~/local/eclipse/ -name libswt\*.so -exec cp {} ~/.swt/lib/linux/x86/ \;
and now it runs fine without explicitly setting the location of the shared libs. I could have set the path explictly to where the libs were found in the eclipse directory, but they are at:
eclipse/configuration/org.eclipse.osgi/bundles/193/1/.cp
which is kind of an odd place, hidden directory and all.
-jim
Re: Hello World SWT - Could not load SWT library [message #991761 is a reply to message #794878] Thu, 20 December 2012 01:10 Go to previous messageGo to next message
Craig Williams wrote on Thu, 09 February 2012 15:24
You sir are a godsend. I'm pretty new to CS and I've been wreaking my brain for 3 days trying to figure this out.
Since the instructions were a little vague I'll will try to restate what he said:
In Package Exporer >> Right click your SWT project >> Properties >> On the left pane, select "Java Build Path" >> In the right window go to the "Projects" tab >> Expand the "org.eclipse.swt.win32.win32.x86" project in the box >> Select "Native Library Location" >> Click on "Edit" on the right hand side >> Click on "Workspace" >> Select the "org.eclipse.swt.win32.win32.x86" object (don't expand it) >> click "OK"
Thanks again!
icon14.gif  Re: Hello World SWT - Could not load SWT library [message #1032917 is a reply to message #794878] Wed, 03 April 2013 12:05 Go to previous messageGo to next message
+1 Craig Williams
Re: Hello World SWT - Could not load SWT library [message #1061175 is a reply to message #794878] Thu, 30 May 2013 07:44 Go to previous messageGo to next message
Hello.
How to "Expand the reference to the SWT project"? I'd appreciate it if you could show that in a picture. Thanks so much.
Re: Hello World SWT - Could not load SWT library [message #1116566 is a reply to message #794878] Wed, 25 September 2013 11:53 Go to previous messageGo to next message
Thanks for that, Craig
Re: Hello World SWT - Could not load SWT library [message #1125555 is a reply to message #754988] Fri, 04 October 2013 12:42 Go to previous messageGo to next message
Thank you!!
Re: Hello World SWT - Could not load SWT library [message #1175664 is a reply to message #794878] Thu, 07 November 2013 17:44 Go to previous messageGo to next message
It worked! Thanks a lot!
Re: Hello World SWT - Could not load SWT library [message #1209378 is a reply to message #794878] Mon, 25 November 2013 08:34 Go to previous messageGo to next message
That worked for me! Many thanks.
It appears that the Native Lib Location defaults to blank - needs to be manually set.
Was a little frustrating for a total newb like me, but I learned something. Rolling Eyes
Re: Hello World SWT - Could not load SWT library [message #1215891 is a reply to message #794878] Thu, 28 November 2013 03:28 Go to previous messageGo to next message
Here's adding another thumbs up for Craig Williams!! Thank you.
Re: Hello World SWT - Could not load SWT library [message #1219971 is a reply to message #1215891] Sat, 07 December 2013 12:41 Go to previous messageGo to next message
Good lord! Thanks a bunch to Craig, but his solution was posted over a year ago, and I just installed the latest Kepler and the tutorial is STILL broken.
Re: Hello World SWT - Could not load SWT library [message #1271362 is a reply to message #794878] Fri, 14 March 2014 19:56 Go to previous messageGo to next message
Thank you so much, i have been rubbing my head for an hour or so trying to figure this out, Smile
Re: Hello World SWT - Could not load SWT library [message #1292343 is a reply to message #794878] Fri, 11 April 2014 14:46 Go to previous messageGo to next message
Thanks!
Re: Hello World SWT - Could not load SWT library [message #1388771 is a reply to message #794878] Thu, 26 June 2014 19:24 Go to previous messageGo to next message
Long overdue, sure, but Craig Williams was (is?) genius on this point.
Fixed me!
Re: Hello World SWT - Could not load SWT library [message #1389316 is a reply to message #1388771] Fri, 27 June 2014 12:28 Go to previous message
Topic locked to prevent more "Me too" or "Thanks!" posts.
Previous Topic:How to make your own tab indentation size
Next Topic:Eclipse EGit pushing latest commit hangs plink.exe
Current Time: Sat Jul 19 19:17:55 EDT 2025
Powered by FUDForum. Page generated in 0.45438 seconds
