Home » Eclipse Projects » Remote Application Platform (RAP) » Server-Push/ asyncExec / java.lang.OutOfMemoryError
Server-Push/ asyncExec / java.lang.OutOfMemoryError [message #111654] Mon, 10 November 2008 08:37 Go to next message
I’m trying to accomplish a server-push for my application.
Referring to this http://www.devx.com/webdev/Article/36101/1954 (Another
Eclipse RAP Test Drive: An Online Newsticker)
The current application is working with Spring-RMI for server
communication and is already running.
My results while creating this peace of software for the server push are:
public void createPartControl(Composite parent){
UICallBack.activate("notifierId");
Thread notifierThread = new Thread(createRunnable());
notifierThread.setDaemon(true);
notifierThread.start();
private Runnable createRunnable() {
return new Runnable() {
public void run() {
boolean running = true;
Runnable r = new Runnable(){
public void run() {
//do something
while (running) {
t.getDisplay().asyncExec(r);
t.getDisplay().asyncExec(new Runnable() {
public void run() {
UICallBack.deactivate("notifierId");
Now, my question:
Is that generally the right way to accomplish a server-push?
and:
I am struggling with this exception:
Exception in thread "Thread-6" java.lang.OutOfMemoryError: Java heap space
at java.util.Arrays.copyOf(Unknown Source)
at java.util.ArrayList.ensureCapacity(Unknown Source)
at java.util.ArrayList.add(Unknown Source)
at
org.eclipse.rwt.internal.lifecycle.UICallBackManager.addAsyn c(UICallBackManager.java:114)
at org.eclipse.swt.widgets.Display$1.run(Display.java:614)
at
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 423)
at
org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.asyncExec(Display.java:612)
at rap.view.WorktimesView$6.run(WorktimesView.java:240)
Any ideas what’s going wrong or how to prevent this error?
Konstantin May
Re: Server-Push/ asyncExec / java.lang.OutOfMemoryError [message #112044 is a reply to message #111654] Tue, 11 November 2008 02:39 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
it is probably the endless loop (while(runnning)) that causes the
OutOfMemory. Each call to asyncExec in this loop adds the given
runnable to a list and thus consumes memory.
The recommended way to use background threads in RAP is via the Jobs
API. See org.eclipse.core.runtime.jobs.Job for a start.
HTH
Rüdiger
May wrote:
> public void run() {
> public void run() {
> //do something
> while (running) {
> public void run() {
> Now, my question: Is that generally the right way to accomplish a
> server-push?
> and:
> at
> at
> at
> Konstantin May
Re: Server-Push/ asyncExec / java.lang.OutOfMemoryError [message #112049 is a reply to message #112044] Tue, 11 November 2008 04:33 Go to previous messageGo to next message
Thanks, that is much better to handel.
I have changed the code to this:
public void run() {
Job job = new Job("myJob") {
protected IStatus run(IProgressMonitor monitor) {
// fetch something from Server
t.getDisplay().asyncExec(new Runnable(){
public void run() {
//updated UI
return Status.OK_STATUS;
job.schedule();
while (running) {
job.schedule(1000);
I'm quite a little bit confused, but this doesent't realy look like a
server-push.I suppose that is more similar to server-polling-mechanism.
Is there a better way for getting events from the server?
This solution could produce a massive traffic between server an client.
Thanks in advance,
Konstantin May
Re: Server-Push/ asyncExec / java.lang.OutOfMemoryError [message #112101 is a reply to message #112049] Tue, 11 November 2008 07:00 Go to previous message
Konstantin,
if you want to learn more about how the UI Callback mechanism works
internally, you may want to search the news archive (e.g. ui callback).
One thread related to this is:
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg01751.html
HTH
Rüdiger
> public void run() {
> public void run() {
> //updated UI
> job.schedule();
> while (running) {
> job.schedule(1000);
> Thanks in advance,
> Konstantin May
Previous Topic:Innoopract Webinar Questions - API Differences
Next Topic:Background-Process / runNonUIThreadWithFakeContext
Current Time: Wed Jul 23 12:27:23 EDT 2025
Powered by FUDForum. Page generated in 0.09002 seconds
