Home » Archived » BIRT » mongodb-oda-birt-plugin - JSONPath
mongodb-oda-birt-plugin - JSONPath [message #1112860] |
Fri, 20 September 2013 05:17  |
Hallo,
we need to use Your plugin "mongodb-oda-birt-plugin" for eclipse. But there we need special filtering of data displayed in BIRT report.
More precisely: in mongoDB we have stored documents of tree form - root document contains maps of other documents and those contained
documents contains next document maps - overall three levels. Documents are objects of related classes but not the same classes.
We need to create BIRT report in eclipse from our mongoDB in tree form. The tree report form would be resolvable but we can't select from mongoDB
nested documents in doc tree via through the use of mongodb-oda-birt-plugin.
I would like to ask You if there is possibility to use JSONPath in definition of "Computed Collumns" in Data Set definition.
Here is the our sample BSON database:
/* 0 */
"_id" : ObjectId("5214bb59132bf5b98613c970"),
"className" : "com.fja.ipl.tools.setak.testreport.Bundle",
"failedTests" : {
"AcceptanceTestToolGuiTestSuite->Suite_NaturalPersonsSuite->Suite_CheckNaturalPersons\t\t\t\t->TEST CASE: 'Test_CheckNaturalPersons'" : "expected:<1> but was:<0>",
"AcceptanceTestToolGuiTestSuite\t\t->TEST CASE: 'Test_SearchBusinessPartner'" : "expected:<Bistum Maribor[_]lMdGYF (58076)> but was:<Bistum Maribor[]lMdGYF (58076)>",
"AcceptanceTestToolGuiTestSuite->Suite_NaturalPersonsSuite\t\t\t->TEST CASE: 'Test_EnterNaturalPerson'#1" : "Cannot locate element with text: Hausanschrift\nFor documentation on this error, please visit: \nBuild info: version: 'unknown', revision: 'unknown', time: 'unknown'\nSystem info: os.name: 'Windows 7', os.arch: 'x86', os.version: '6.1', java.version: '1.6.0_35'\nDriver info: driver.version: unknown",
"AcceptanceTestToolGuiTestSuite\t\t->TEST CASE: 'Test_FailureBusinessPartner'" : "expected:<Bistum Maribor[_]lMdGYF (58076)> but was:<Bistum Maribor[]lMdGYF (58076)>",
"AcceptanceTestToolGuiTestSuite->Suite_NaturalPersonsSuite\t\t\t->TEST CASE: 'Test_EnterNaturalPerson'#2" : "Cannot locate element with text: Hausanschrift\nFor documentation on this error, please visit: \nBuild info: version: 'unknown', revision: 'unknown', time: 'unknown'\nSystem info: os.name: 'Windows 7', os.arch: 'x86', os.version: '6.1', java.version: '1.6.0_35'\nDriver info: driver.version: unknown",
"AcceptanceTestToolGuiTestSuite->Suite_NaturalPersonsSuite->Suite_CheckNaturalPersons\t\t\t\t->TEST CASE: 'Test_Login_Superuser'" : "Unable to locate element: {\"method\":\"id\",\"selector\":\"loginUserName\"}\nBuild info: version: 'unknown', revision: 'unknown', time: 'unknown'\nSystem info: os.name: 'Windows 7', os.arch: 'x86', os.version: '6.1', java.version: '1.6.0_35'\nDriver info: driver.version: unknown"
"name" : "Hlavny bundle 2",
"containsChild" : true,
"childPredicates" : {
"AcceptanceTestToolGuiTestSuite" : {
"className" : "com.fja.ipl.tools.setak.testreport.Suite",
"allTests" : 18,
"failedTests" : 6,
"successfulTests" : 12,
"runTime" : "3 min, 57 s",
"name" : "AcceptanceTestToolGuiTestSuite",
"containsChild" : false,
"Suite_TestSuite1" : {
"allTests" : 6,
"failedTests" : 0,
"successfulTests" : 6,
"runTime" : "1 min, 14 s",
"name" : "AcceptanceTestToolGuiTestSuite->Suite_TestSuite1",
"Suite_TestSuite1_2" : {
"allTests" : 3,
"failedTests" : 0,
"successfulTests" : 3,
"runTime" : "0 min, 33 s",
"name" : "AcceptanceTestToolGuiTestSuite->Suite_TestSuite1->Suite_TestSuite1_2",
"Suite_TestSuite1_2_1" : {
"allTests" : 3,
"failedTests" : 0,
"runTime" : "0 min, 32 s",
"name" : "AcceptanceTestToolGuiTestSuite->Suite_TestSuite1->Suite_TestSuite1_2->Suite_TestSuite1_2_1",
"TEST CASE: 'Test_EnterBusinessPartner'#3" : {
"className" : "com.fja.ipl.tools.setak.testreport.Test",
"date" : "Wed Aug 21 15:06:04 CEST 2013",
"name" : "\t\t\t\t\t->TEST CASE: 'Test_EnterBusinessPartner'#3",
"result" : "Passed",
"PREDICATE: 'cidLoginUser'#4" : {
"date" : "Wed Aug 21 15:06:00 CEST 2013",
"name" : "\t\t\t\t\t->PREDICATE: 'cidLoginUser'#4",
"TEST CASE: 'Test_PassingParameters'#2" : {
"date" : "Wed Aug 21 15:06:26 CEST 2013",
"name" : "\t\t\t\t\t->TEST CASE: 'Test_PassingParameters'#2",
"Suite_TestSuite1_1" : {
"allTests" : 3,
"failedTests" : 0,
"runTime" : "0 min, 27 s",
"name" : "AcceptanceTestToolGuiTestSuite->Suite_TestSuite1->Suite_TestSuite1_1",
"TEST CASE: 'Test_EnterBusinessPartner'#2" : {
"date" : "Wed Aug 21 15:05:23 CEST 2013",
"name" : "\t\t\t\t->TEST CASE: 'Test_EnterBusinessPartner'#2",
"TEST CASE: 'Test_PassingParameters'#1" : {
"date" : "Wed Aug 21 15:05:40 CEST 2013",
"name" : "\t\t\t\t->TEST CASE: 'Test_PassingParameters'#1",
"PREDICATE: 'cidLoginUser'#3" : {
"date" : "Wed Aug 21 15:05:19 CEST 2013",
"name" : "\t\t\t\t->PREDICATE: 'cidLoginUser'#3",
"TEST CASE: 'Test_EnterBusinessPartner'#1" : {
"date" : "Wed Aug 21 15:02:45 CEST 2013",
"name" : "\t\t->TEST CASE: 'Test_EnterBusinessPartner'#1",
"Suite_NaturalPersonsSuite" : {
"allTests" : 5,
"failedTests" : 4,
"successfulTests" : 1,
"runTime" : "1 min, 24 s",
"name" : "AcceptanceTestToolGuiTestSuite->Suite_NaturalPersonsSuite",
"Suite_CheckNaturalPersons" : {
"allTests" : 2,
"failedTests" : 2,
"successfulTests" : 0,
"runTime" : "0 min, 24 s",
"name" : "AcceptanceTestToolGuiTestSuite->Suite_NaturalPersonsSuite->Suite_CheckNaturalPersons",
"TEST CASE: 'Test_Login_Superuser'" : {
"date" : "Wed Aug 21 15:04:40 CEST 2013",
"name" : "\t\t\t\t->TEST CASE: 'Test_Login_Superuser'",
"result" : "Failed",
"TEST CASE: 'Test_CheckNaturalPersons'" : {
"date" : "Wed Aug 21 15:04:58 CEST 2013",
"name" : "\t\t\t\t->TEST CASE: 'Test_CheckNaturalPersons'",
"TEST CASE: 'Test_EnterNaturalPerson'#2" : {
"date" : "Wed Aug 21 15:04:12 CEST 2013",
"name" : "\t\t\t->TEST CASE: 'Test_EnterNaturalPerson'#2",
"TEST CASE: 'Test_EnterNaturalPerson'#1" : {
"date" : "Wed Aug 21 15:03:45 CEST 2013",
"name" : "\t\t\t->TEST CASE: 'Test_EnterNaturalPerson'#1",
"PREDICATE: 'cidLoginUser'#2" : {
"date" : "Wed Aug 21 15:03:40 CEST 2013",
"name" : "\t\t\t->PREDICATE: 'cidLoginUser'#2",
"TEST CASE: 'Test_MultipleAssertTabAndPage'" : {
"date" : "Wed Aug 21 15:03:36 CEST 2013",
"name" : "\t\t->TEST CASE: 'Test_MultipleAssertTabAndPage'",
"TEST CASE: 'Test_SearchBusinessPartner'" : {
"date" : "Wed Aug 21 15:03:01 CEST 2013",
"name" : "\t\t->TEST CASE: 'Test_SearchBusinessPartner'",
"TEST CASE: 'Test_FailureBusinessPartner'" : {
"date" : "Wed Aug 21 15:03:12 CEST 2013",
"name" : "\t\t->TEST CASE: 'Test_FailureBusinessPartner'",
"PREDICATE: 'cidLoginUser'#1" : {
"date" : "Wed Aug 21 15:02:36 CEST 2013",
"name" : "\t\t->PREDICATE: 'cidLoginUser'#1",
"TEST CASE: 'Test_CloseMultipleTabs'" : {
"date" : "Wed Aug 21 15:03:25 CEST 2013",
"name" : "\t\t->TEST CASE: 'Test_CloseMultipleTabs'",
"TEST CASE: 'Test_CloseSingleTab'" : {
"date" : "Wed Aug 21 15:02:40 CEST 2013",
"name" : "\t\t->TEST CASE: 'Test_CloseSingleTab'",
/* 1 */
"_id" : ObjectId("5217385e4bcaa8955cb36d49"),
"failedTests" : ["AcceptanceTestsSuite\t\t->TEST CASE: 'Test_CheckFoundBusinessPartner'"],
"childPredicates" : [{
"allTests" : 3,
"failedTests" : 1,
"successfulTests" : 2,
"runTime" : "1 min, 2 s",
"name" : "AcceptanceTestsSuite",
"date" : "Fri Aug 23 12:23:25 CEST 2013",
"result" : "Passed"
"date" : "Fri Aug 23 12:23:41 CEST 2013",
"name" : "\t\t->TEST CASE: 'Test_EnterBusinessPartner'",
"result" : "Passed"
"date" : "Fri Aug 23 12:23:56 CEST 2013",
"name" : "\t\t->TEST CASE: 'Test_CheckFoundBusinessPartner'",
"result" : "Failed"
Thanks in advance for whatever answer.
Attachment: DS.jpg
(Size: 33.69KB, Downloaded 228 times)
Current Time: Sun Jul 27 22:23:42 EDT 2025
Powered by FUDForum. Page generated in 0.04874 seconds
