Home » Archived » Eclipse Process Manager (Stardust) » Loading of Preferences in the Business Control Center
Loading of Preferences in the Business Control Center [message #1085773] Tue, 13 August 2013 06:56 Go to next message
We have an application with ~3000 Participants. When we enter as motu and choose the Business Control Center, it looks like stardust loads the preferences for every user
2013/08/13 12:24:11,501 INFO  [org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor] (http--185.12.5.142-8080-19) --> getPreferences
2013/08/13 12:24:11,516 INFO  [org.eclipse.stardust.engine.core.runtime.logging.Security] (http--185.12.5.142-8080-19) Partition: default, Domain: default.
2013/08/13 12:24:11,529 INFO  [org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor] (http--185.12.5.142-8080-19) <-- getPreferences
2013/08/13 12:24:11,543 INFO  [org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor] (http--185.12.5.142-8080-19) --> getPreferences
2013/08/13 12:24:11,562 INFO  [org.eclipse.stardust.engine.core.runtime.logging.Security] (http--185.12.5.142-8080-19) Partition: default, Domain: default.
This takes ~3min and timeout the request.
What exactly happens here? Does it really load every participant and is this needed?
I observed similar behavior in the Webmodeler in another application, everytime I clicked onto the model.
Re: Loading of Preferences in the Business Control Center [message #1100621 is a reply to message #1085773] Tue, 03 September 2013 06:59 Go to previous messageGo to next message
Florian,
Thank you for reporting this. Your observations are correct. We were able to reproduce it and have created a ticket. When fixed the fix will get into the Stardust code base with the next sync.
Best regards
Robert
Re: Loading of Preferences in the Business Control Center [message #1101175 is a reply to message #1100621] Wed, 04 September 2013 01:12 Go to previous messageGo to next message
Bug 416487
https://bugs.eclipse.org/bugs/show_bug.cgi?id=416487
Re: Loading of Preferences in the Business Control Center [message #1116359 is a reply to message #1101175] Wed, 25 September 2013 06:00 Go to previous message
Florian,
the issue has been addressed and the fix will find its way into the Stardust code base as part of the regular syncs.
At this point this has not been tested thoroughly, but I attached the patch to the Bugzilla ticket anyway in case you want to try it.
Best
Rob
Previous Topic:Business Process Monitoring - Event based
Next Topic:Command line tools (sysconsole)
Current Time: Sat Jul 26 12:56:39 EDT 2025
Powered by FUDForum. Page generated in 0.05413 seconds
