Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Developing a eclipse plug-in using acceleo generation within
[Acceleo] Developing a eclipse plug-in using acceleo generation within [message #1115968] Tue, 24 September 2013 16:43 Go to next message
Hi everybody!
I am developing a eclipse plugin wich uses the acceleo generation apart from the acceleo. I'm using a fixed papyrus .uml model and a fixed .mtl file.
My problem is how to load this files and utilize the acceleo generation inside the plug-in development environment. I've already tried the standalone code and such, but I've never found someone with a related problem.
Thanks in advance!
Re: [Acceleo] Developing a eclipse plug-in using acceleo generation within [message #1122094 is a reply to message #1115968] Tue, 01 October 2013 04:20 Go to previous message
I hope this may help you http://lowcoupling.com/post/51877317162/the-acceleo-ui-launcher-project
Previous Topic:[Acceleo] NullPointer when executing junit test from maven
Next Topic:[Acceleo] Get the target generation path on Modules
Current Time: Wed Jul 23 11:52:27 EDT 2025
Powered by FUDForum. Page generated in 1.04759 seconds
