Home » Archived » Test and Performance Tools Platform (TPTP) » Linux TPTP - Eclipse Runtime Workspace - Wrong Path - Plugin not recongnized
Linux TPTP - Eclipse Runtime Workspace - Wrong Path - Plugin not recongnized [message #111567] Thu, 06 September 2007 12:50 Go to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
hi all,
I've spend 2 days trying to get my TPTP working. I have a GMF Project I
want to profile, therefore I test it as an Runtime(RT) Eclipse
application. My problem now is that my plugin is not recongnized. I
assume the reason for this is that the path to my runtime workspace is
wrong.
For normal RT launch and for debugging launch the path is:
/home/qn/runtime-EclipseApplication/Test
For TPTP:
/home/qn/"/home/qn/runtime-EclipseApplication"/Test
I've got no idea where to change this.
By the way, I installed everything similar on a Windows machine and
there everything is fine.
My configuration is:
Linux - Gentoo 2007.0
Sun JDK 1.6.0.02 [sun-jdk-1.6]
Eclipse 3.3 Europa (Several Plugins like GEF,GMF,EMF ...)
TPTP 4.4.0.2
Setup
Downloaded Eclipse, installed all plugins from the update-sites.
Installed TPTP from europa update site, installed 4.4.0.1 afterwards,
then 4.4.0.2. Changed all files in
eclipse-3.3-SDK/plugins/org.eclipse.tptp.platform.ac.linux_i a32_4.4.0.v200706020100/agent_controller/bin
to executeable.
Btw. I can't run SetConfig.sh :
ERROR: The Java Runtime in use does not contain a suitable JAXP feature
RESOLUTION: Use a JRE which supports the JAXP feature
Strange is that "JAXP 1.3 is included in (...) Java SE 5.0". Anyway I
don't think it's important for my problem.
Thanks for help I'm really stuck here,
stefan
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFG4C/CIYVWjMSpDwwRAkslAJ4wanJknCkdoCEGyQSN/py6tSPz9gCf aFqK
SdpYedbcTVasZVRZFAX6vsA=
=M1MC
-----END PGP SIGNATURE-----
Re: Linux TPTP - Eclipse Runtime Workspace - Wrong Path - Plugin not recongnized [message #111578 is a reply to message #111567] Fri, 07 September 2007 04:39 Go to previous messageGo to next message
Originally posted by: cyril.jaquier.[nospam]bluewin.ch
Hi all,
I'm trying to get TPTP working on my Linux box for quite a while without
success. I tried again with Eclipse 3.3 and TPTP 4.4 without more
success. I wish you good luck with it ;)
If you look at SetConfig.sh you will see that the test fails here:
java -classpath ../lib/config.jar
org.eclipse.tptp.platform.agentcontroller.config.TestJAXP > /dev/null 2>&1
And that will ALWAYS fail because... config.jar does not exist in
lib/... I will try to download the AC from the TPTP website because the
one in org.eclipse.tptp.platform.ac.linux_ia32_4.4.0.v200706020100/
seems to be incomplete.
Cyril Jaquier
Re: Linux TPTP - Eclipse Runtime Workspace - Wrong Path - Plugin not recongnized [message #111981 is a reply to message #111578] Fri, 07 September 2007 11:21 Go to previous messageGo to next message
Hash: SHA1
well, then I wonder why they offically support it ...
- -stefan :(
Cyril Jaquier schrieb:
> Hi all,
> Regards,
> Cyril Jaquier
iD8DBQFG4WyMIYVWjMSpDwwRAgS2AKDXX0bEV5Spm7A3LvMubHaHH1CjFgCg tVIy
Kxc9ma2FNaw+aLCWv5vUfKw=
=2Am1
Re: Linux TPTP - Eclipse Runtime Workspace - Wrong Path - Plugin not recongnized [message #111985 is a reply to message #111567] Fri, 07 September 2007 11:30 Go to previous messageGo to next message
> For TPTP:
This is this bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=197512
Which should be fixed in the latest nightly build of the TPTP with agent
controller. I'd have a go with that version if I were you.
James
Re: Linux TPTP - Eclipse Runtime Workspace - Wrong Path - Plugin not recongnized [message #111990 is a reply to message #111985] Fri, 07 September 2007 11:32 Go to previous message
And by latest nightly, I meant the 4.4.1 branch.
James
"James Blackburn" <james.blackburn@broadcom.com> wrote in message
news:fbrqpq$8ul$1@build.eclipse.org...
> Hi
>> For TPTP:
> James
Previous Topic:Unable to profile
Next Topic:'recorder' tptp distibutive/pack?
Current Time: Thu Jul 24 21:20:20 EDT 2025
Powered by FUDForum. Page generated in 1.09255 seconds
