Home » Archived » Hudson » problem with instaling
problem with instaling [message #1114995] Mon, 23 September 2013 10:10 Go to next message
Hi, I have problem. I dowlanded hudson.war and I started Hudson using ( java -jar hudson.war ). Everything was fine but later I want to connect to hudson using locahost:8080 and I can't.
I use Windows Server 2008 R2
why I can not see this ?
http://wiki.eclipse.org/Image:Hudson_Windows_Service_1.png
Re: problem with instaling [message #1115023 is a reply to message #1114995] Mon, 23 September 2013 10:36 Go to previous messageGo to next message
Make sure Windows has opened that port. I don't think it's open by default on Windows Server.
Re: problem with instaling [message #1115586 is a reply to message #1115023] Tue, 24 September 2013 05:48 Go to previous messageGo to next message
I opened a port 8080 and I have the same problem, maybe someone know how to fix it ?
Re: problem with instaling [message #1115883 is a reply to message #1115586] Tue, 24 September 2013 14:22 Go to previous messageGo to next message
I hope you don't have spelling mistake in the URL. In your message it says "locahost:8080". Notice the second "l" missing.
Re: problem with instaling [message #1116373 is a reply to message #1115883] Wed, 25 September 2013 06:27 Go to previous messageGo to next message
When I write : localhost:8080 I only have this : "imgur.com/g9mlLz1"
It is very imprtanat for me, why I can no to install hudson ? I can only extract this .war file.
Re: problem with instaling [message #1116556 is a reply to message #1114995] Wed, 25 September 2013 11:40 Go to previous messageGo to next message
Looks like port 8080 is used by another application (share point). You may have to use another port for Hudson.Try running
java -jar --httpPort=9090
Then use
localhost:9090
Re: problem with instaling [message #1117420 is a reply to message #1116556] Thu, 26 September 2013 08:23 Go to previous messageGo to next message
thanks for fast reply.
I did everything what you wrote and I have still problem. I attach printscreen :
"imgur.com/sAuZTIS"
comend "java -jar --httpPort=9090" also do not work
[Updated on: Thu, 26 September 2013 08:24] by Moderator
Re: problem with instaling [message #1117647 is a reply to message #1117420] Thu, 26 September 2013 13:06 Go to previous messageGo to next message
OOPS, Sorry. I mentioned how to set the port using the flag --httpPort=9090. It was not the full command. If you have downloaded the war from
http://eclipse.org/downloads/download.php?file=/hudson/war/hudson-3.1.0.war
and the war name is hudson-3.1.0.war, then the full command to run the Hudson application in port 9090 is
java -jar --httpPort=9090 hudson-3.1.0.war
Make sure you use the correct war name
Re: problem with instaling [message #1118574 is a reply to message #1117647] Fri, 27 September 2013 10:48 Go to previous messageGo to next message
I did everything what you wrote and error is the same. maybe something else ?
Re: problem with instaling [message #1118696 is a reply to message #1118574] Fri, 27 September 2013 13:35 Go to previous messageGo to next message
Can you post the screenshot with the latest command
[Updated on: Fri, 27 September 2013 13:36] by Moderator
Re: problem with instaling [message #1118705 is a reply to message #1118696] Fri, 27 September 2013 13:41 Go to previous messageGo to next message
Ah my bad. It is the position of the options
When I tried the following I got the same error as you
wjprakash@seaview:Wars$ java -jar --httpPort=9090 hudson-3.1.0.war
Unrecognized option: --httpPort=9090
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
When I tried this, it was ok
wjprakash@seaview:Wars$ java -jar hudson-3.1.0.war --httpPort=9090
/Users/wjprakash/Hudson/Wars/hudson-3.1.0.war
War - /Users/wjprakash/Hudson/Wars/hudson-3.1.0.war
2013-09-27 10:38:57.804:INFO:oejs.Server:jetty-8.1.7.v20120910
2013-09-27 10:38:59.478:INFO:oejw.StandardDescriptorProcessor:NO JSP Support for /, did not find org.apache.jasper.servlet.JspServlet
2013-09-27 10:38:59.575:INFO:oejsh.ContextHandler:started o.e.j.w.WebAppContext{/,file:/Users/wjprakash/.hudson/war/webapp/},file:/Users/wjprakash/Hudson/Wars/hudson-3.1.0.war
Sep 27, 2013 10:39:00 AM org.eclipse.hudson.HudsonServletContextListener contextInitialized
INFO: Home directory: /Users/wjprakash/.hudson
Re: problem with instaling [message #1121281 is a reply to message #1118705] Mon, 30 September 2013 09:04 Go to previous messageGo to next message
Thanks, it helps, this commend is correct.
In cmd it was written " Hudson is installed " but when I go to localhost:9090 it is incorrect address.
Re: problem with instaling [message #1124301 is a reply to message #1121281] Thu, 03 October 2013 07:49 Go to previous messageGo to next message
Maybe diffrent idea for this problem ?
Re: problem with instaling [message #1124755 is a reply to message #1124301] Thu, 03 October 2013 17:56 Go to previous message
Can you post screenshot of CMD window and the browser. It is hard to tell what is going on from your description
Previous Topic:BUILD_ID in Mail content
Next Topic:NoSuchMethodException after upgrading from 1.359 to 3.0.1
Current Time: Sat Jul 26 04:35:29 EDT 2025
Powered by FUDForum. Page generated in 0.04915 seconds
